iom48.h File Reference
Definitions for iom48. More...
#include <avr/iomx8.h>
Include dependency graph for iom48.h:
#define SPM_PAGESIZE   64
#define RAMEND   0x2FF
#define XRAMEND   RAMEND
#define E2END   0xFF
#define E2PAGESIZE   4
#define FLASHEND   0xFFF
#define FUSE_MEMORY_SIZE   3
#define FUSE_CKSEL0   (unsigned char)~_BV(0) /* Select Clock Source */
#define FUSE_CKSEL1   (unsigned char)~_BV(1) /* Select Clock Source */
#define FUSE_CKSEL2   (unsigned char)~_BV(2) /* Select Clock Source */
#define FUSE_CKSEL3   (unsigned char)~_BV(3) /* Select Clock Source */
#define FUSE_SUT0   (unsigned char)~_BV(4) /* Select start-up time */
#define FUSE_SUT1   (unsigned char)~_BV(5) /* Select start-up time */
#define FUSE_CKOUT   (unsigned char)~_BV(6) /* Clock output */
#define FUSE_CKDIV8   (unsigned char)~_BV(7) /* Divide clock by 8 */
#define LFUSE_DEFAULT   (FUSE_CKDIV8 & FUSE_SUT0 & FUSE_CKSEL3 & FUSE_CKSEL2 & FUSE_CKSEL0)
#define FUSE_BODLEVEL0   (unsigned char)~_BV(0) /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL1   (unsigned char)~_BV(1) /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL2   (unsigned char)~_BV(2) /* Brown-out Detector trigger level */
#define FUSE_EESAVE   (unsigned char)~_BV(3) /* EEPROM memory is preserved through chip erase */
#define FUSE_WDTON   (unsigned char)~_BV(4) /* Watchdog Timer Always On */
#define FUSE_SPIEN   (unsigned char)~_BV(5) /* Enable Serial programming and Data Downloading */
#define FUSE_DWEN   (unsigned char)~_BV(6) /* debugWIRE Enable */
#define FUSE_RSTDISBL   (unsigned char)~_BV(7) /* External reset disable */
#define HFUSE_DEFAULT   (FUSE_SPIEN)
#define FUSE_SELFPRGEN   (unsigned char)~_BV(0) /* Self Programming Enable */
#define EFUSE_DEFAULT   (0xFF)
#define __LOCK_BITS_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x92
#define SIGNATURE_2   0x05
