iom1281.h
1
7 /*
8  * Copyright (c) 2005 Anatoly Sokolov
9  * All rights reserved.
10  *
11  * Redistribution and use in source and binary forms, with or without
12  * modification, are permitted provided that the following conditions are met:
13  *
14  * * Redistributions of source code must retain the above copyright
15  * notice, this list of conditions and the following disclaimer.
16  *
17  * * Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in
19  * the documentation and/or other materials provided with the
20  * distribution.
21  *
22  * * Neither the name of the copyright holders nor the names of
23  * contributors may be used to endorse or promote products derived
24  * from this software without specific prior written permission.
25  *
26  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36  * POSSIBILITY OF SUCH DAMAGE.
37  */
38
39
40 #ifndef _AVR_IOM1281_H_
41 #define _AVR_IOM1281_H_ 1
42
50 #include <avr/iomxx0_1.h>
51
52 /* Constants */
53 #define SPM_PAGESIZE 256
54 #define RAMEND 0x21FF
55 #define XRAMEND 0xFFFF
56 #define E2END 0xFFF
57 #define E2PAGESIZE 8
58 #define FLASHEND 0x1FFFF
59
60
61 /* Fuses */
62
63 #define FUSE_MEMORY_SIZE 3
64
65 /* Low Fuse Byte */
66 #define FUSE_CKSEL0 (unsigned char)~_BV(0)
67 #define FUSE_CKSEL1 (unsigned char)~_BV(1)
68 #define FUSE_CKSEL2 (unsigned char)~_BV(2)
69 #define FUSE_CKSEL3 (unsigned char)~_BV(3)
70 #define FUSE_SUT0 (unsigned char)~_BV(4)
71 #define FUSE_SUT1 (unsigned char)~_BV(5)
72 #define FUSE_CKOUT (unsigned char)~_BV(6)
73 #define FUSE_CKDIV8 (unsigned char)~_BV(7)
74 #define LFUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
75
76 /* High Fuse Byte */
77 #define FUSE_BOOTRST (unsigned char)~_BV(0)
78 #define FUSE_BOOTSZ0 (unsigned char)~_BV(1)
79 #define FUSE_BOOTSZ1 (unsigned char)~_BV(2)
80 #define FUSE_EESAVE (unsigned char)~_BV(3)
81 #define FUSE_WDTON (unsigned char)~_BV(4)
82 #define FUSE_SPIEN (unsigned char)~_BV(5)
83 #define FUSE_JTAGEN (unsigned char)~_BV(6)
84 #define FUSE_OCDEN (unsigned char)~_BV(7)
85 #define HFUSE_DEFAULT (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
86
87 /* Extended Fuse Byte */
88 #define FUSE_BODLEVEL0 (unsigned char)~_BV(0)
89 #define FUSE_BODLEVEL1 (unsigned char)~_BV(1)
90 #define FUSE_BODLEVEL2 (unsigned char)~_BV(2)
91 #define EFUSE_DEFAULT (0xFF)
92
93
94 /* Lock Bits */
95 #define __LOCK_BITS_EXIST
96 #define __BOOT_LOCK_BITS_0_EXIST
97 #define __BOOT_LOCK_BITS_1_EXIST
98
99
100 /* Signature */
101 #define SIGNATURE_0 0x1E
102 #define SIGNATURE_1 0x97
103 #define SIGNATURE_2 0x04
104
106 #endif /* _AVR_IOM1281_H_ */
Definitions for ATmega640/1280/1281/2560/2561.
