Macros | Functions
in_cksum_arm.h File Reference
#include <sys/param.h>
#include <sys/systm.h>
#include <sys/mbuf.h>
#include <netinet/in.h>
#include <netinet/in_systm.h>
#include <netinet/ip.h>
#include <netinet/ip_var.h>
Include dependency graph for in_cksum_arm.h:
#define ADD64
#define ADD32
#define ADD16
#define ADD8
#define ADD4
#define REDUCE
#define ADDCARRY   {if (sum > 0xffff) sum -= 0xffff;}
#define ROL   {sum = sum << 8;} /* depends on recent REDUCE */
#define ADDBYTE   {ROL; sum += (*w << 8); byte_swapped ^= 1;}
#define ADDSHORT   {sum += *(u_short *)w;}
#define ADVANCE(n)   {w += n; mlen -= n;}
#define ADVANCEML(n)   {mlen -= n;}
int in_cksum (struct mbuf *m, int len)
int in4_cksum (struct mbuf *m, u_int8_t nxt, int off, int len)
◆ ADD16
#define ADD16
Value:
__asm __volatile(" \n\ ldmia %0!, {%2, %3, %4, %5} \n\ adds %1,%7,%2; adcs %1,%1,%3 \n\ adcs %1,%1,%4; adcs %1,%1,%5 \n\ adcs %1,%1,#0\n" \
: "=r" (w), "=r" (sum), "=&r" (tmp1), "=&r" (tmp2), "=&r" (tmp3), "=&r" (tmp4) \
: "0" (w), "r" (sum) \
: "cc")
◆ ADD32
#define ADD32
Value:
__asm __volatile(" \n\ ldmia %0!, {%2, %3, %4, %5} \n\ adds %1,%7,%2; adcs %1,%1,%3 \n\ adcs %1,%1,%4; adcs %1,%1,%5 \n\ ldmia %0!, {%2, %3, %4, %5} \n\ adcs %1,%1,%2; adcs %1,%1,%3 \n\ adcs %1,%1,%4; adcs %1,%1,%5 \n\ adcs %1,%1,#0\n" \
: "cc")
◆ ADD4
#define ADD4
Value:
__asm __volatile(" \n\ ldr %2,[%0],#4 \n\ adds %1,%4,%2 \n\ adcs %1,%1,#0\n" \
: "=r" (w), "=r" (sum), "=&r" (tmp1) \
: "cc")
◆ ADD64
#define ADD64
Value:
__asm __volatile(" \n\ ldmia %0!, {%2, %3, %4, %5} \n\ adds %1,%7,%2; adcs %1,%1,%3 \n\ adcs %1,%1,%4; adcs %1,%1,%5 \n\ ldmia %0!, {%2, %3, %4, %5} \n\ adcs %1,%1,%2; adcs %1,%1,%3 \n\ adcs %1,%1,%4; adcs %1,%1,%5 \n\ ldmia %0!, {%2, %3, %4, %5} \n\ adcs %1,%1,%2; adcs %1,%1,%3 \n\ adcs %1,%1,%4; adcs %1,%1,%5 \n\ ldmia %0!, {%2, %3, %4, %5} \n\ adcs %1,%1,%2; adcs %1,%1,%3 \n\ adcs %1,%1,%4; adcs %1,%1,%5 \n\ adcs %1,%1,#0\n" \
: "cc")
◆ ADD8
#define ADD8
Value:
__asm __volatile(" \n\ ldmia %0!, {%2, %3} \n\ adds %1,%5,%2; adcs %1,%1,%3 \n\ adcs %1,%1,#0\n" \
: "=r" (w), "=r" (sum), "=&r" (tmp1), "=&r" (tmp2) \
: "cc" )
◆ REDUCE
#define REDUCE
Value:
__asm __volatile(" \n\ mov %2, #0x00ff \n\ orr %2, %2, #0xff00 \n\ and %2, %0, %2 \n\ add %0, %2, %0, lsr #16\n" \
: "=r" (sum) \
: "0" (sum), "r" (tmp1))
