Data Structures | Macros
if_ppp.h File Reference
#include <net/ppp_defs.h>
#include <net/if.h>
Include dependency graph for if_ppp.h:
struct  npioctl
struct  ppp_option_data
struct  ifpppstatsreq
struct  ifpppcstatsreq
#define PPP_MTU   1500 /* Default MTU (size of Info field) */
#define PPP_MAXMRU   65000 /* Largest MRU we allow */
#define PPP_MAXMTU   16384 /* Largest MTU we allow */
#define SC_COMP_PROT   0x00000001 /* protocol compression (output) */
#define SC_COMP_AC   0x00000002 /* header compression (output) */
#define SC_COMP_TCP   0x00000004 /* TCP (VJ) compression (output) */
#define SC_NO_TCP_CCID   0x00000008 /* disable VJ connection-id comp. */
#define SC_REJ_COMP_AC   0x00000010 /* reject adrs/ctrl comp. on input */
#define SC_REJ_COMP_TCP   0x00000020 /* reject TCP (VJ) comp. on input */
#define SC_CCP_OPEN   0x00000040 /* Look at CCP packets */
#define SC_CCP_UP   0x00000080 /* May send/recv compressed packets */
#define SC_DEBUG   0x00010000 /* enable debug messages */
#define SC_LOG_INPKT   0x00020000 /* log contents of good pkts recvd */
#define SC_LOG_OUTPKT   0x00040000 /* log contents of pkts sent */
#define SC_LOG_RAWIN   0x00080000 /* log all chars received */
#define SC_LOG_FLUSH   0x00100000 /* log all chars flushed */
#define SC_RCV_B7_0   0x01000000 /* have rcvd char with bit 7 = 0 */
#define SC_RCV_B7_1   0x02000000 /* have rcvd char with bit 7 = 1 */
#define SC_RCV_EVNP   0x04000000 /* have rcvd char with even parity */
#define SC_RCV_ODDP   0x08000000 /* have rcvd char with odd parity */
#define SC_SYNC   0x00200000 /* use synchronous HDLC framing */
#define SC_MASK   0x0fff00ff /* bits that user can change */
#define SC_TIMEOUT   0x00000400 /* timeout is currently pending */
#define SC_VJ_RESET   0x00000800 /* need to reset VJ decomp */
#define SC_COMP_RUN   0x00001000 /* compressor has been initiated */
#define SC_DECOMP_RUN   0x00002000 /* decompressor has been initiated */
#define SC_DC_ERROR   0x00004000 /* non-fatal decomp error detected */
#define SC_DC_FERROR   0x00008000 /* fatal decomp error detected */
#define SC_TBUSY   0x10000000 /* xmitter doesn't need a packet yet */
#define SC_PKTLOST   0x20000000 /* have lost or dropped a packet */
#define SC_FLUSH   0x40000000 /* flush input until next PPP_FLAG */
#define SC_ESCAPED   0x80000000 /* saw a PPP_ESCAPE */
#define PPPIOCSTASK   _IOW('t', 91, int) /* set pppd task id */
#define PPPIOCGFLAGS   _IOR('t', 90, int) /* get configuration flags */
#define PPPIOCSFLAGS   _IOW('t', 89, int) /* set configuration flags */
#define PPPIOCGASYNCMAP   _IOR('t', 88, int) /* get async map */
#define PPPIOCSASYNCMAP   _IOW('t', 87, int) /* set async map */
#define PPPIOCGUNIT   _IOR('t', 86, int) /* get ppp unit number */
#define PPPIOCGRASYNCMAP   _IOR('t', 85, int) /* get receive async map */
#define PPPIOCSRASYNCMAP   _IOW('t', 84, int) /* set receive async map */
#define PPPIOCGMRU   _IOR('t', 83, int) /* get max receive unit */
#define PPPIOCSMRU   _IOW('t', 82, int) /* set max receive unit */
#define PPPIOCSMAXCID   _IOW('t', 81, int) /* set VJ max slot ID */
#define PPPIOCGXASYNCMAP   _IOR('t', 80, ext_accm) /* get extended ACCM */
#define PPPIOCSXASYNCMAP   _IOW('t', 79, ext_accm) /* set extended ACCM */
#define PPPIOCXFERUNIT   _IO('t', 78) /* transfer PPP unit */
#define PPPIOCSCOMPRESS   _IOW('t', 77, struct ppp_option_data)
#define PPPIOCGNPMODE   _IOWR('t', 76, struct npioctl) /* get NP mode */
#define PPPIOCSNPMODE   _IOW('t', 75, struct npioctl) /* set NP mode */
#define PPPIOCGIDLE   _IOR('t', 74, struct ppp_idle) /* get idle time */
#define PPPIOCGMTU   _IOR('t', 73, int) /* get interface MTU */
#define PPPIOCSMTU   _IOW('t', 72, int) /* set interface MTU */
#define SIOCGPPPSTATS   _IOWR('i', 123, struct ifpppstatsreq)
#define SIOCGPPPCSTATS   _IOWR('i', 122, struct ifpppcstatsreq)
#define ifr_mtu   ifr_ifru.ifru_metric
