#define | IFM_ETHER 0x00000020 |
#define | IFM_10_T 3 /* 10BaseT - RJ45 */ |
#define | IFM_10_2 4 /* 10Base2 - Thinnet */ |
#define | IFM_10_5 5 /* 10Base5 - AUI */ |
#define | IFM_100_TX 6 /* 100BaseTX - RJ45 */ |
#define | IFM_100_FX 7 /* 100BaseFX - Fiber */ |
#define | IFM_100_T4 8 /* 100BaseT4 - 4 pair cat 3 */ |
#define | IFM_100_VG 9 /* 100VG-AnyLAN */ |
#define | IFM_100_T2 10 /* 100BaseT2 */ |
#define | IFM_1000_SX 11 /* 1000BaseSX - multi-mode fiber */ |
#define | IFM_10_STP 12 /* 10BaseT over shielded TP */ |
#define | IFM_10_FL 13 /* 10BaseFL - Fiber */ |
#define | IFM_1000_LX 14 /* 1000baseLX - single-mode fiber */ |
#define | IFM_1000_CX 15 /* 1000baseCX - 150ohm STP */ |
#define | IFM_1000_T 16 /* 1000baseT - 4 pair cat 5 */ |
#define | IFM_HPNA_1 17 /* HomePNA 1.0 (1Mb/s) */ |
#define | IFM_ETH_MASTER 0x00000100 /* master mode (1000baseT) */ |
#define | IFM_TOKEN 0x00000040 |
#define | IFM_TOK_STP4 3 /* Shielded twisted pair 4m - DB9 */ |
#define | IFM_TOK_STP16 4 /* Shielded twisted pair 16m - DB9 */ |
#define | IFM_TOK_UTP4 5 /* Unshielded twisted pair 4m - RJ45 */ |
#define | IFM_TOK_UTP16 6 /* Unshielded twisted pair 16m - RJ45 */ |
#define | IFM_TOK_STP100 7 /* Shielded twisted pair 100m - DB9 */ |
#define | IFM_TOK_UTP100 8 /* Unshielded twisted pair 100m - RJ45 */ |
#define | IFM_TOK_ETR 0x00000200 /* Early token release */ |
#define | IFM_TOK_SRCRT 0x00000400 /* Enable source routing features */ |
#define | IFM_TOK_ALLR 0x00000800 /* All routes / Single route bcast */ |
#define | IFM_TOK_DTR 0x00002000 /* Dedicated token ring */ |
#define | IFM_TOK_CLASSIC 0x00004000 /* Classic token ring */ |
#define | IFM_TOK_AUTO 0x00008000 /* Automatic Dedicate/Classic token ring */ |
#define | IFM_FDDI 0x00000060 |
#define | IFM_FDDI_SMF 3 /* Single-mode fiber */ |
#define | IFM_FDDI_MMF 4 /* Multi-mode fiber */ |
#define | IFM_FDDI_UTP 5 /* CDDI / UTP */ |
#define | IFM_FDDI_DA 0x00000100 /* Dual attach / single attach */ |
#define | IFM_IEEE80211 0x00000080 |
#define | IFM_IEEE80211_FH1 3 /* Frequency Hopping 1Mbps */ |
#define | IFM_IEEE80211_FH2 4 /* Frequency Hopping 2Mbps */ |
#define | IFM_IEEE80211_DS1 5 /* Direct Sequence 1Mbps */ |
#define | IFM_IEEE80211_DS2 6 /* Direct Sequence 2Mbps */ |
#define | IFM_IEEE80211_DS5 7 /* Direct Sequence 5.5Mbps */ |
#define | IFM_IEEE80211_DS11 8 /* Direct Sequence 11Mbps */ |
#define | IFM_IEEE80211_DS22 9 /* Direct Sequence 22Mbps */ |
#define | IFM_IEEE80211_OFDM6 10 /* OFDM 6Mbps */ |
#define | IFM_IEEE80211_OFDM9 11 /* OFDM 9Mbps */ |
#define | IFM_IEEE80211_OFDM12 12 /* OFDM 12Mbps */ |
#define | IFM_IEEE80211_OFDM18 13 /* OFDM 18Mbps */ |
#define | IFM_IEEE80211_OFDM24 14 /* OFDM 24Mbps */ |
#define | IFM_IEEE80211_OFDM36 15 /* OFDM 36Mbps */ |
#define | IFM_IEEE80211_OFDM48 16 /* OFDM 48Mbps */ |
#define | IFM_IEEE80211_OFDM54 17 /* OFDM 54Mbps */ |
#define | IFM_IEEE80211_OFDM72 18 /* OFDM 72Mbps */ |
#define | IFM_IEEE80211_ADHOC 0x00000100 /* Operate in Adhoc mode */ |
#define | IFM_IEEE80211_HOSTAP 0x00000200 /* Operate in Host AP mode */ |
#define | IFM_IEEE80211_IBSS 0x00000400 /* Operate in IBSS mode */ |
#define | IFM_IEEE80211_IBSSMASTER 0x00000800 /* Operate as an IBSS master */ |
#define | IFM_IEEE80211_TURBO 0x00001000 /* Operate in turbo mode */ |
#define | IFM_IEEE80211_MONITOR 0x00002000 /* Operate in monitor mode */ |
#define | IFM_IEEE80211_11A 0x00010000 /* 5Ghz, OFDM mode */ |
#define | IFM_IEEE80211_11B 0x00020000 /* Direct Sequence mode */ |
#define | IFM_IEEE80211_11G 0x00030000 /* 2Ghz, CCK mode */ |
#define | IFM_IEEE80211_FH 0x00040000 /* 2Ghz, GFSK mode */ |
#define | IFM_ATM 0x000000a0 |
#define | IFM_ATM_UNKNOWN 3 |
#define | IFM_ATM_UTP_25 4 |
#define | IFM_ATM_TAXI_100 5 |
#define | IFM_ATM_TAXI_140 6 |
#define | IFM_ATM_MM_155 7 |
#define | IFM_ATM_SM_155 8 |
#define | IFM_ATM_UTP_155 9 |
#define | IFM_ATM_MM_622 10 |
#define | IFM_ATM_SM_622 11 |
#define | IFM_ATM_VIRTUAL 12 |
#define | IFM_ATM_SDH 0x00000100 /* SDH instead of SONET */ |
#define | IFM_ATM_NOSCRAMB 0x00000200 /* no scrambling */ |
#define | IFM_ATM_UNASSIGNED 0x00000400 /* unassigned cells */ |
#define | IFM_AUTO 0 /* Autoselect best media */ |
#define | IFM_MANUAL 1 /* Jumper/dipswitch selects media */ |
#define | IFM_NONE 2 /* Deselect all media */ |
#define | IFM_FDX 0x00100000 /* Force full duplex */ |
#define | IFM_HDX 0x00200000 /* Force half duplex */ |
#define | IFM_FLAG0 0x01000000 /* Driver defined flag */ |
#define | IFM_FLAG1 0x02000000 /* Driver defined flag */ |
#define | IFM_FLAG2 0x04000000 /* Driver defined flag */ |
#define | IFM_LOOP 0x08000000 /* Put hardware in loopback */ |
#define | IFM_NMASK 0x000000e0 /* Network type */ |
#define | IFM_TMASK 0x0000001f /* Media sub-type */ |
#define | IFM_IMASK 0xf0000000 /* Instance */ |
#define | IFM_ISHIFT 28 /* Instance shift */ |
#define | IFM_OMASK 0x0000ff00 /* Type specific options */ |
#define | IFM_MMASK 0x00070000 /* Mode */ |
#define | IFM_MSHIFT 16 /* Mode shift */ |
#define | IFM_GMASK 0x0ff00000 /* Global options */ |
#define | IFM_AVALID IFM_FLAG0 /* Active bit valid */ |
#define | IFM_ACTIVE IFM_FLAG0 /* Interface attached to working net */ |
#define | IFM_TYPE(x) ((x) & IFM_NMASK) |
#define | IFM_SUBTYPE(x) ((x) & IFM_TMASK) |
#define | IFM_TYPE_OPTIONS(x) ((x) & IFM_OMASK) |
#define | IFM_INST(x) (((x) & IFM_IMASK) >> IFM_ISHIFT) |
#define | IFM_OPTIONS(x) ((x) & (IFM_OMASK|IFM_GMASK)) |
#define | IFM_MODE(x) ((x) & IFM_MMASK) |
#define | IFM_INST_MAX IFM_INST(IFM_IMASK) |
#define | IFM_MAKEWORD(type, subtype, options, instance) ((type) | (subtype) | (options) | ((uint32_t)(instance) << IFM_ISHIFT)) |
#define | IFM_MAKEMODE(mode) (((mode) << IFM_MSHIFT) & IFM_MMASK) |
| #define | IFM_TYPE_DESCRIPTIONS |
| #define | IFM_SUBTYPE_ETHERNET_DESCRIPTIONS |
| #define | IFM_SUBTYPE_ETHERNET_ALIASES |
| #define | IFM_SUBTYPE_ETHERNET_OPTION_DESCRIPTIONS |
| #define | IFM_SUBTYPE_TOKENRING_DESCRIPTIONS |
| #define | IFM_SUBTYPE_TOKENRING_ALIASES |
| #define | IFM_SUBTYPE_TOKENRING_OPTION_DESCRIPTIONS |
| #define | IFM_SUBTYPE_FDDI_DESCRIPTIONS |
| #define | IFM_SUBTYPE_FDDI_ALIASES |
| #define | IFM_SUBTYPE_FDDI_OPTION_DESCRIPTIONS |
| #define | IFM_SUBTYPE_IEEE80211_DESCRIPTIONS |
| #define | IFM_SUBTYPE_IEEE80211_ALIASES |
| #define | IFM_SUBTYPE_IEEE80211_OPTION_DESCRIPTIONS |
| #define | IFM_SUBTYPE_IEEE80211_MODE_DESCRIPTIONS |
| #define | IFM_SUBTYPE_IEEE80211_MODE_ALIASES |
| #define | IFM_SUBTYPE_ATM_DESCRIPTIONS |
| #define | IFM_SUBTYPE_ATM_ALIASES |
| #define | IFM_SUBTYPE_ATM_OPTION_DESCRIPTIONS |
| #define | IFM_SUBTYPE_SHARED_DESCRIPTIONS |
| #define | IFM_SUBTYPE_SHARED_ALIASES |
| #define | IFM_SHARED_OPTION_DESCRIPTIONS |
