if_arp.h
1 /*
2  * Copyright (c) 1986, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)if_arp.h 8.1 (Berkeley) 6/10/93
30  * $FreeBSD: src/sys/net/if_arp.h,v 1.21 2005/01/07 01:45:34 imp Exp $
31  */
32
33
34 #ifndef _NET_IF_ARP_H_
35 #define _NET_IF_ARP_H_
36
37 #include <sys/socket.h> /* struct sockaddr */
38
39 /*
40  * Address Resolution Protocol.
41  *
42  * See RFC 826 for protocol description. ARP packets are variable
43  * in size; the arphdr structure defines the fixed-length portion.
44  * Protocol type values are the same as those for 10 Mb/s Ethernet.
45  * It is followed by the variable-sized fields ar_sha, arp_spa,
46  * arp_tha and arp_tpa in that order, according to the lengths
47  * specified. Field names used correspond to RFC 826.
48  */
49 struct arphdr {
50  u_short ar_hrd; /* format of hardware address */
51 #define ARPHRD_ETHER 1 /* ethernet hardware format */
52 #define ARPHRD_IEEE802 6 /* token-ring hardware format */
53 #define ARPHRD_ARCNET 7 /* arcnet hardware format */
54 #define ARPHRD_FRELAY 15 /* frame relay hardware format */
55 #define ARPHRD_IEEE1394 24 /* firewire hardware format */
56  u_short ar_pro; /* format of protocol address */
57  u_char ar_hln; /* length of hardware address */
58  u_char ar_pln; /* length of protocol address */
59  u_short ar_op; /* one of: */
60 #define ARPOP_REQUEST 1 /* request to resolve address */
61 #define ARPOP_REPLY 2 /* response to previous request */
62 #define ARPOP_REVREQUEST 3 /* request protocol address given hardware */
63 #define ARPOP_REVREPLY 4 /* response giving protocol address */
64 #define ARPOP_INVREQUEST 8 /* request to identify peer */
65 #define ARPOP_INVREPLY 9 /* response identifying peer */
66 /*
67  * The remaining fields are variable in size,
68  * according to the sizes above.
69  */
70 #ifdef COMMENT_ONLY
71  u_char ar_sha[]; /* sender hardware address */
72  u_char ar_spa[]; /* sender protocol address */
73  u_char ar_tha[]; /* target hardware address */
74  u_char ar_tpa[]; /* target protocol address */
75 #endif
76 };
77
78 #define ar_sha(ap) (((caddr_t)((ap)+1)) + 0)
79 #define ar_spa(ap) (((caddr_t)((ap)+1)) + (ap)->ar_hln)
80 #define ar_tha(ap) (((caddr_t)((ap)+1)) + (ap)->ar_hln + (ap)->ar_pln)
81 #define ar_tpa(ap) (((caddr_t)((ap)+1)) + 2*(ap)->ar_hln + (ap)->ar_pln)
82
83 #define arphdr_len2(ar_hln, ar_pln) \
84  (sizeof(struct arphdr) + 2*(ar_hln) + 2*(ar_pln))
85 #define arphdr_len(ap) (arphdr_len2((ap)->ar_hln, (ap)->ar_pln))
86
87 /*
88  * ARP ioctl request
89  */
90 struct arpreq {
91  struct sockaddr arp_pa; /* protocol address */
92  struct sockaddr arp_ha; /* hardware address */
93  int arp_flags; /* flags */
94 };
95 /* arp_flags and at_flags field values */
96 #define ATF_INUSE 0x01 /* entry in use */
97 #define ATF_COM 0x02 /* completed entry (enaddr valid) */
98 #define ATF_PERM 0x04 /* permanent entry */
99 #define ATF_PUBL 0x08 /* publish entry (respond for other host) */
100 #define ATF_USETRAILERS 0x10 /* has requested trailers */
101
102 #ifdef _KERNEL
103 /*
104  * Structure shared between the ethernet driver modules and
105  * the address resolution code. For example, each ec_softc or il_softc
106  * begins with this structure.
107  * The code is written so that each *_softc _must_ begin with a
108  * struct arpcom, which in turn _must_ begin with a struct ifnet.
109  */
110 struct arpcom {
111  /*
112  * The ifnet struct _must_ be at the head of this structure.
113  */
114  struct ifnet ac_if; /* network-visible interface */
115  u_char ac_enaddr[6]; /* ethernet hardware address */
116 #if defined(__rtems__)
117 /* Cruft from ancient BSD - should be removed once RTEMS is updated */
118  struct ether_multi *ac_multiaddrs; /* list of ether multicast addrs */
119  int ac_multicnt; /* length of ac_multiaddrs list */
120 #else
121  int now_unused; /* XXX was length of ac_multiaddrs list */
122  void *ac_netgraph; /* ng_ether(4) netgraph node info */
123 #endif
124 };
125 #define IFP2AC(ifp) ((struct arpcom *)(ifp))
126
127 #endif
128
129 #endif /* !_NET_IF_ARP_H_ */
Definition: if_arp.h:50
Definition: socket.h:180
Definition: if_var.h:99
Definition: if_arp.h:91
