Data Structures | Macros | Typedefs | Enumerations | Functions
hexdump.h File Reference
#include <wchar.h>
#include <setjmp.h>
Include dependency graph for hexdump.h:
struct  _pr
struct  _fu
struct  _fs
struct  rtems_shell_hexdump_globals_t
#define F_ADDRESS   0x001 /* print offset */
#define F_BPAD   0x002 /* blank pad */
#define F_C   0x004 /* %_c */
#define F_CHAR   0x008 /* %c */
#define F_DBL   0x010 /* %[EefGf] */
#define F_INT   0x020 /* %[di] */
#define F_P   0x040 /* %_p */
#define F_STR   0x080 /* %s */
#define F_U   0x100 /* %_u */
#define F_UINT   0x200 /* %[ouXx] */
#define F_TEXT   0x400 /* no conversions */
#define F_IGNORE   0x01 /* %_A */
#define F_SETREP   0x02 /* rep count set, not default */
#define fshead   globals->fshead
#define endfu   globals->endfu
#define blocksize   globals->blocksize
#define exitval   globals->exitval
#define odmode   globals->odmode
#define length   globals->length
#define skip   globals->skip
#define vflag   globals->vflag
#define address   globals->address
#define eaddress   globals->eaddress
#define ateof   globals->ateof
#define curp   globals->curp
#define savp   globals->savp
#define done   globals->done
#define hdstdin   globals->hdstdin
#define exit_jump   &(globals->exit_jmp)
#define add   rtems_shell_hexdump_add
#define addfile   rtems_shell_hexdump_addfile
#define badcnt   rtems_shell_hexdump_badcnt
#define badconv   rtems_shell_hexdump_badconv
#define badfmt   rtems_shell_hexdump_badfmt
#define badsfmt   rtems_shell_hexdump_badsfmt
#define bpad   rtems_shell_hexdump_bpad
#define conv_c   rtems_shell_hexdump_conv_c
#define conv_u   rtems_shell_hexdump_conv_u
#define display   rtems_shell_hexdump_display
#define doskip   rtems_shell_hexdump_doskip
#define escape   rtems_shell_hexdump_escape
#define get   rtems_shell_hexdump_get
#define newsyntax   rtems_shell_hexdump_newsyntax
#define next   rtems_shell_hexdump_next
#define nomem   rtems_shell_hexdump_nomem
#define oldsyntax   rtems_shell_hexdump_oldsyntax
#define peek   rtems_shell_hexdump_peek
#define rewrite   rtems_shell_hexdump_rewrite
#define size   rtems_shell_hexdump_size
#define usage   rtems_shell_hexdump_usage
#define exit(ec)   rtems_shell_hexdump_exit(globals, ec)
typedef struct _pr PR
typedef struct _fu FU
typedef struct _fs FS
typedef struct rtems_shell_hexdump_globals_t rtems_shell_hexdump_globals
enum  _vflag { ALL, DUP, FIRST, WAIT }
void add (rtems_shell_hexdump_globals *, const char *)
void addfile (rtems_shell_hexdump_globals *, char *)
void badcnt (rtems_shell_hexdump_globals *, char *)
void badconv (rtems_shell_hexdump_globals *, char *)
void badfmt (rtems_shell_hexdump_globals *, const char *)
void badsfmt (rtems_shell_hexdump_globals *)
void bpad (PR *)
void conv_c (rtems_shell_hexdump_globals *, PR *, u_char *, size_t)
void conv_u (rtems_shell_hexdump_globals *, PR *, u_char *)
void display (rtems_shell_hexdump_globals *)
void doskip (rtems_shell_hexdump_globals *, const char *, int)
void escape (char *)
u_char * get (rtems_shell_hexdump_globals *)
void newsyntax (rtems_shell_hexdump_globals *, int, char ***)
int next (rtems_shell_hexdump_globals *, char **)
void nomem (void)
void oldsyntax (rtems_shell_hexdump_globals *, int, char ***)
size_t peek (rtems_shell_hexdump_globals *, u_char *, size_t)
void rewrite (rtems_shell_hexdump_globals *, FS *)
int size (rtems_shell_hexdump_globals *, FS *)
void usage (rtems_shell_hexdump_globals *)
void rtems_shell_hexdump_exit (rtems_shell_hexdump_globals *globals, int code)
