ATtiny13 Definitions
#define _AVR_IOXXX_H_   "iotn13.h"
#define ADCSRB   _SFR_IO8(0x03)
#define ACME   6
#define ADTS2   2
#define ADTS1   1
#define ADTS0   0
#define ADC   _SFR_IO16 (0x04)
#define ADCW   _SFR_IO16 (0x04)
#define ADCL   _SFR_IO8(0x04)
#define ADCH   _SFR_IO8(0x05)
#define ADCSRA   _SFR_IO8(0x06)
#define ADEN   7
#define ADSC   6
#define ADATE   5
#define ADIF   4
#define ADIE   3
#define ADPS2   2
#define ADPS1   1
#define ADPS0   0
#define ADMUX   _SFR_IO8(0x07)
#define REFS0   6
#define ADLAR   5
#define MUX1   1
#define MUX0   0
#define ACSR   _SFR_IO8(0x08)
#define ACD   7
#define ACBG   6
#define ACO   5
#define ACI   4
#define ACIE   3
#define ACIS1   1
#define ACIS0   0
#define DIDR0   _SFR_IO8(0x14)
#define ADC0D   5
#define ADC2D   4
#define ADC3D   3
#define ADC1D   2
#define AIN1D   1
#define AIN0D   0
#define PCMSK   _SFR_IO8(0x15)
#define PCINT5   5
#define PCINT4   4
#define PCINT3   3
#define PCINT2   2
#define PCINT1   1
#define PCINT0   0
#define PINB   _SFR_IO8(0x16)
#define PINB5   5
#define PINB4   4
#define PINB3   3
#define PINB2   2
#define PINB1   1
#define PINB0   0
#define DDRB   _SFR_IO8(0x17)
#define DDB5   5
#define DDB4   4
#define DDB3   3
#define DDB2   2
#define DDB1   1
#define DDB0   0
#define PORTB   _SFR_IO8(0x18)
#define PB5   5
#define PB4   4
#define PB3   3
#define PB2   2
#define PB1   1
#define PB0   0
#define EECR   _SFR_IO8(0x1C)
#define EEPM1   5
#define EEPM0   4
#define EERIE   3
#define EEMPE   2
#define EEPE   1
#define EERE   0
#define EEDR   _SFR_IO8(0x1D)
#define EEAR   _SFR_IO8(0x1E)
#define EEARL   _SFR_IO8(0x1E)
#define WDTCR   _SFR_IO8(0x21)
#define WDTIF   7
#define WDTIE   6
#define WDP3   5
#define WDCE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define CLKPR   _SFR_IO8(0x26)
#define CLKPCE   7
#define CLKPS3   3
#define CLKPS2   2
#define CLKPS1   1
#define CLKPS0   0
#define GTCCR   _SFR_IO8(0x28)
#define TSM   7
#define PSR10   0
#define OCR0B   _SFR_IO8(0x29)
#define DWDR   _SFR_IO8(0x2e)
#define TCCR0A   _SFR_IO8(0x2f)
#define COM0A1   7
#define COM0A0   6
#define COM0B1   5
#define COM0B0   4
#define WGM01   1
#define WGM00   0
#define OSCCAL   _SFR_IO8(0x31)
#define TCNT0   _SFR_IO8(0x32)
#define TCCR0B   _SFR_IO8(0x33)
#define FOC0A   7
#define FOC0B   6
#define WGM02   3
#define CS02   2
#define CS01   1
#define CS00   0
#define MCUSR   _SFR_IO8(0x34)
#define WDRF   3
#define BORF   2
#define EXTRF   1
#define PORF   0
#define MCUCR   _SFR_IO8(0x35)
#define PUD   6
#define SE   5
#define SM1   4
#define SM0   3
#define ISC01   1
#define ISC00   0
#define OCR0A   _SFR_IO8(0x36)
#define SPMCSR   _SFR_IO8(0x37)
#define CTPB   4
#define RFLB   3
#define PGWRT   2
#define PGERS   1
#define SPMEN   0
#define SELFPRGEN   0
#define TIFR0   _SFR_IO8(0x38)
#define OCF0B   3
#define OCF0A   2
#define TOV0   1
#define TIMSK0   _SFR_IO8(0x39)
#define OCIE0B   3
#define OCIE0A   2
#define TOIE0   1
#define GIFR   _SFR_IO8(0x3a)
#define INTF0   6
#define PCIF   5
#define GIMSK   _SFR_IO8(0x3b)
#define INT0   6
#define PCIE   5
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define PCINT0_vect   _VECTOR(2)
#define SIG_PIN_CHANGE0   _VECTOR(2)
#define TIM0_OVF_vect   _VECTOR(3)
#define SIG_OVERFLOW0   _VECTOR(3)
#define EE_RDY_vect   _VECTOR(4)
#define SIG_EEPROM_READY   _VECTOR(4)
#define ANA_COMP_vect   _VECTOR(5)
#define SIG_COMPARATOR   _VECTOR(5)
#define TIM0_COMPA_vect   _VECTOR(6)
#define SIG_OUTPUT_COMPARE0A   _VECTOR(6)
#define TIM0_COMPB_vect   _VECTOR(7)
#define SIG_OUTPUT_COMPARE0B   _VECTOR(7)
#define WDT_vect   _VECTOR(8)
#define SIG_WATCHDOG_TIMEOUT   _VECTOR(8)
#define ADC_vect   _VECTOR(9)
#define SIG_ADC   _VECTOR(9)
#define _VECTORS_SIZE   20
#define SPM_PAGESIZE   32
#define RAMEND   0x9F
#define XRAMEND   RAMEND
#define E2END   0x3F
#define E2PAGESIZE   4
#define FLASHEND   0x3FF
#define FUSE_MEMORY_SIZE   2
#define FUSE_CKSEL0   (unsigned char)~_BV(0)
#define FUSE_CKSEL1   (unsigned char)~_BV(1)
#define FUSE_SUT0   (unsigned char)~_BV(2)
#define FUSE_SUT1   (unsigned char)~_BV(3)
#define FUSE_CKDIV8   (unsigned char)~_BV(4)
#define FUSE_WDTON   (unsigned char)~_BV(5)
#define FUSE_EESAVE   (unsigned char)~_BV(6)
#define FUSE_SPIEN   (unsigned char)~_BV(7)
#define LFUSE_DEFAULT   (FUSE_CKSEL0 & FUSE_SUT0 & FUSE_CKDIV8 & FUSE_SPIEN)
#define FUSE_RSTDISBL   (unsigned char)~_BV(0)
#define FUSE_BODLEVEL0   (unsigned char)~_BV(1)
#define FUSE_BODLEVEL1   (unsigned char)~_BV(2)
#define FUSE_DWEN   (unsigned char)~_BV(3)
#define FUSE_SPMEN   (unsigned char)~_BV(4)
#define HFUSE_DEFAULT   (0xFF)
#define __LOCK_BITS_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x90
#define SIGNATURE_2   0x07
