ATmega162 Definitions
#define _AVR_IOXXX_H_   "iom162.h"
#define TCCR3A   _SFR_MEM8(0x8B)
#define TCCR3B   _SFR_MEM8(0x8A)
#define TCNT3H   _SFR_MEM8(0x89)
#define TCNT3L   _SFR_MEM8(0x88)
#define TCNT3   _SFR_MEM16(0x88)
#define OCR3AH   _SFR_MEM8(0x87)
#define OCR3AL   _SFR_MEM8(0x86)
#define OCR3A   _SFR_MEM16(0x86)
#define OCR3BH   _SFR_MEM8(0x85)
#define OCR3BL   _SFR_MEM8(0x84)
#define OCR3B   _SFR_MEM16(0x84)
#define ICR3H   _SFR_MEM8(0x81)
#define ICR3L   _SFR_MEM8(0x80)
#define ICR3   _SFR_MEM16(0x80)
#define ETIMSK   _SFR_MEM8(0x7D)
#define ETIFR   _SFR_MEM8(0x7C)
#define PCMSK1   _SFR_MEM8(0x6C)
#define PCMSK0   _SFR_MEM8(0x6B)
#define CLKPR   _SFR_MEM8(0x61)
#define UBRR1H   _SFR_IO8(0x3C) /* USART 1 Baud Rate Register High Byte, Shared with UCSR1C */
#define UCSR1C   _SFR_IO8(0x3C) /* USART 1 Control and Status Register, Shared with UBRR1H */
#define GICR   _SFR_IO8(0x3B) /* General Interrupt Control Register */
#define GIFR   _SFR_IO8(0x3A) /* General Interrupt Flag Register */
#define TIMSK   _SFR_IO8(0x39) /* Timer Interrupt Mask */
#define TIFR   _SFR_IO8(0x38) /* Timer Interrupt Flag Register */
#define SPMCR   _SFR_IO8(0x37) /* Store Program Memory Control Register */
#define EMCUCR   _SFR_IO8(0x36) /* Extended MCU Control Register */
#define MCUCR   _SFR_IO8(0x35) /* MCU Control Register */
#define MCUCSR   _SFR_IO8(0x34) /* MCU Control and Status Register */
#define TCCR0   _SFR_IO8(0x33) /* Timer/Counter 0 Control Register */
#define TCNT0   _SFR_IO8(0x32) /* TImer/Counter 0 */
#define OCR0   _SFR_IO8(0x31) /* Output Compare Register 0 */
#define SFIOR   _SFR_IO8(0x30) /* Special Function I/O Register */
#define TCCR1A   _SFR_IO8(0x2F) /* Timer/Counter 1 Control Register A */
#define TCCR1B   _SFR_IO8(0x2E) /* Timer/Counter 1 Control Register A */
#define TCNT1H   _SFR_IO8(0x2D) /* Timer/Counter 1 High Byte */
#define TCNT1L   _SFR_IO8(0x2C) /* Timer/Counter 1 Low Byte */
#define TCNT1   _SFR_IO16(0x2C) /* Timer/Counter 1 */
#define OCR1AH   _SFR_IO8(0x2B) /* Timer/Counter 1 Output Compare Register A High Byte */
#define OCR1AL   _SFR_IO8(0x2A) /* Timer/Counter 1 Output Compare Register A Low Byte */
#define OCR1A   _SFR_IO16(0x2A) /* Timer/Counter 1 Output Compare Register A */
#define OCR1BH   _SFR_IO8(0x29) /* Timer/Counter 1 Output Compare Register B High Byte */
#define OCR1BL   _SFR_IO8(0x28) /* Timer/Counter 1 Output Compare Register B Low Byte */
#define OCR1B   _SFR_IO16(0x28) /* Timer/Counter 1 Output Compare Register B */
#define TCCR2   _SFR_IO8(0x27) /* Timer/Counter 2 Control Register */
#define ASSR   _SFR_IO8(0x26) /* Asynchronous Status Register */
#define ICR1H   _SFR_IO8(0x25) /* Input Capture Register 1 High Byte */
#define ICR1L   _SFR_IO8(0x24) /* Input Capture Register 1 Low Byte */
#define ICR1   _SFR_IO16(0x24) /* Input Capture Register 1 */
#define TCNT2   _SFR_IO8(0x23) /* Timer/Counter 2 */
#define OCR2   _SFR_IO8(0x22) /* Timer/Counter 2 Output Compare Register */
#define WDTCR   _SFR_IO8(0x21) /* Watchdow Timer Control Register */
#define UBRR0H   _SFR_IO8(0x20) /* USART 0 Baud-Rate Register High Byte, Shared with UCSR0C */
#define UCSR0C   _SFR_IO8(0x20) /* USART 0 Control and Status Register C, Shared with UBRR0H */
#define EEARH   _SFR_IO8(0x1F) /* EEPROM Address Register High Byte */
#define EEARL   _SFR_IO8(0x1E) /* EEPROM Address Register Low Byte */
#define EEAR   _SFR_IO16(0x1E) /* EEPROM Address Register */
#define EEDR   _SFR_IO8(0x1D) /* EEPROM Data Register */
#define EECR   _SFR_IO8(0x1C) /* EEPROM Control Register */
#define PORTA   _SFR_IO8(0x1B) /* Port A */
#define DDRA   _SFR_IO8(0x1A) /* Port A Data Direction Register */
#define PINA   _SFR_IO8(0x19) /* Port A Pin Register */
#define PORTB   _SFR_IO8(0x18) /* Port B */
#define DDRB   _SFR_IO8(0x17) /* Port B Data Direction Register */
#define PINB   _SFR_IO8(0x16) /* Port B Pin Register */
#define PORTC   _SFR_IO8(0x15) /* Port C */
#define DDRC   _SFR_IO8(0x14) /* Port C Data Direction Register */
#define PINC   _SFR_IO8(0x13) /* Port C Pin Register */
#define PORTD   _SFR_IO8(0x12) /* Port D */
#define DDRD   _SFR_IO8(0x11) /* Port D Data Direction Register */
#define PIND   _SFR_IO8(0x10) /* Port D Pin Register */
#define SPDR   _SFR_IO8(0x0F) /* SPI Data Register */
#define SPSR   _SFR_IO8(0x0E) /* SPI Status Register */
#define SPCR   _SFR_IO8(0x0D) /* SPI Control Register */
#define UDR0   _SFR_IO8(0x0C) /* USART 0 Data Register */
#define UCSR0A   _SFR_IO8(0x0B) /* USART 0 Control and Status Register A */
#define UCSR0B   _SFR_IO8(0x0A) /* USART 0 Control and Status Register B */
#define UBRR0L   _SFR_IO8(0x09) /* USART 0 Baud-Rate Register Low Byte */
#define ACSR   _SFR_IO8(0x08) /* Analog Comparator Status Register */
#define PORTE   _SFR_IO8(0x07) /* Port E */
#define DDRE   _SFR_IO8(0x06) /* Port E Data Direction Register */
#define PINE   _SFR_IO8(0x05) /* Port E Pin Register */
#define OSCCAL   _SFR_IO8(0x04) /* Oscillator Calibration, Shared with OCDR */
#define OCDR   _SFR_IO8(0x04) /* On-Chip Debug Register, Shared with OSCCAL */
#define UDR1   _SFR_IO8(0x03) /* USART 1 Data Register */
#define UCSR1A   _SFR_IO8(0x02) /* USART 1 Control and Status Register A */
#define UCSR1B   _SFR_IO8(0x01) /* USART 1 Control and Status Register B */
#define UBRR1L   _SFR_IO8(0x00) /* USART 0 Baud Rate Register High Byte */
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define INT1_vect   _VECTOR(2)
#define SIG_INTERRUPT1   _VECTOR(2)
#define INT2_vect   _VECTOR(3)
#define SIG_INTERRUPT2   _VECTOR(3)
#define PCINT0_vect   _VECTOR(4)
#define SIG_PIN_CHANGE0   _VECTOR(4)
#define PCINT1_vect   _VECTOR(5)
#define SIG_PIN_CHANGE1   _VECTOR(5)
#define TIMER3_CAPT_vect   _VECTOR(6)
#define SIG_INPUT_CAPTURE3   _VECTOR(6)
#define TIMER3_COMPA_vect   _VECTOR(7)
#define SIG_OUTPUT_COMPARE3A   _VECTOR(7)
#define TIMER3_COMPB_vect   _VECTOR(8)
#define SIG_OUTPUT_COMPARE3B   _VECTOR(8)
#define TIMER3_OVF_vect   _VECTOR(9)
#define SIG_OVERFLOW3   _VECTOR(9)
#define TIMER2_COMP_vect   _VECTOR(10)
#define SIG_OUTPUT_COMPARE2   _VECTOR(10)
#define TIMER2_OVF_vect   _VECTOR(11)
#define SIG_OVERFLOW2   _VECTOR(11)
#define TIMER1_CAPT_vect   _VECTOR(12)
#define SIG_INPUT_CAPTURE1   _VECTOR(12)
#define TIMER1_COMPA_vect   _VECTOR(13)
#define SIG_OUTPUT_COMPARE1A   _VECTOR(13)
#define TIMER1_COMPB_vect   _VECTOR(14)
#define SIG_OUTPUT_COMPARE1B   _VECTOR(14)
#define TIMER1_OVF_vect   _VECTOR(15)
#define SIG_OVERFLOW1   _VECTOR(15)
#define TIMER0_COMP_vect   _VECTOR(16)
#define SIG_OUTPUT_COMPARE0   _VECTOR(16)
#define TIMER0_OVF_vect   _VECTOR(17)
#define SIG_OVERFLOW0   _VECTOR(17)
#define SPI_STC_vect   _VECTOR(18)
#define SIG_SPI   _VECTOR(18)
#define USART0_RXC_vect   _VECTOR(19)
#define SIG_USART0_RECV   _VECTOR(19)
#define USART1_RXC_vect   _VECTOR(20)
#define SIG_USART1_RECV   _VECTOR(20)
#define USART0_UDRE_vect   _VECTOR(21)
#define SIG_USART0_DATA   _VECTOR(21)
#define USART1_UDRE_vect   _VECTOR(22)
#define SIG_USART1_DATA   _VECTOR(22)
#define USART0_TXC_vect   _VECTOR(23)
#define SIG_USART0_TRANS   _VECTOR(23)
#define USART1_TXC_vect   _VECTOR(24)
#define SIG_USART1_TRANS   _VECTOR(24)
#define EE_RDY_vect   _VECTOR(25)
#define SIG_EEPROM_READY   _VECTOR(25)
#define ANA_COMP_vect   _VECTOR(26)
#define SIG_COMPARATOR   _VECTOR(26)
#define SPM_RDY_vect   _VECTOR(27)
#define SIG_SPM_READY   _VECTOR(27)
#define _VECTORS_SIZE   112 /* = (num vec+1) * 4 */
#define ICNC3   7
#define ICES3   6
#define WGM33   4
#define WGM32   3
#define CS32   2
#define CS31   1
#define CS30   0
#define COM3A1   7
#define COM3A0   6
#define COM3B1   5
#define COM3B0   4
#define FOC3A   3
#define FOC3B   2
#define WGM31   1
#define WGM30   0
#define TICIE3   5
#define OCIE3A   4
#define OCIE3B   3
#define TOIE3   2
#define ICF3   5
#define OCF3A   4
#define OCF3B   3
#define TOV3   2
#define PCINT15   7
#define PCINT14   6
#define PCINT13   5
#define PCINT12   4
#define PCINT11   3
#define PCINT10   2
#define PCINT9   1
#define PCINT8   0
#define PCINT7   7
#define PCINT6   6
#define PCINT5   5
#define PCINT4   4
#define PCINT3   3
#define PCINT2   2
#define PCINT1   1
#define PCINT0   0
#define CLKPCE   7
#define CLKPS3   3
#define CLKPS2   2
#define CLKPS1   1
#define CLKPS0   0
#define SP15   15
#define SP14   14
#define SP13   13
#define SP12   12
#define SP11   11
#define SP10   10
#define SP9   9
#define SP8   8
#define SP7   7
#define SP6   6
#define SP5   5
#define SP4   4
#define SP3   3
#define SP2   2
#define SP1   1
#define SP0   0
#define URSEL1   7
#define URSEL1   7
#define UBRR111   3
#define UBRR110   2
#define UBRR19   1
#define UBRR18   0
#define UMSEL1   6
#define UPM11   5
#define UPM10   4
#define USBS1   3
#define UCSZ11   2
#define UCSZ10   1
#define UCPOL1   0
#define INT1   7
#define INT0   6
#define INT2   5
#define PCIE1   4
#define PCIE0   3
#define IVSEL   1
#define IVCE   0
#define INTF1   7
#define INTF0   6
#define INTF2   5
#define PCIF1   4
#define PCIF0   3
#define TOIE1   7
#define OCIE1A   6
#define OCIE1B   5
#define OCIE2   4
#define TICIE1   3
#define TOIE2   2
#define TOIE0   1
#define OCIE0   0
#define TOV1   7
#define OCF1A   6
#define OCF1B   5
#define OCF2   4
#define ICF1   3
#define TOV2   2
#define TOV0   1
#define OCF0   0
#define SPMIE   7
#define RWWSB   6
#define RWWSRE   4
#define BLBSET   3
#define PGWRT   2
#define PGERS   1
#define SPMEN   0
#define SM0   7
#define SRL2   6
#define SRL1   5
#define SRL0   4
#define SRW01   3
#define SRW00   2
#define SRW11   1
#define ISC2   0
#define SRE   7
#define SRW10   6
#define SE   5
#define SM1   4
#define ISC11   3
#define ISC10   2
#define ISC01   1
#define ISC00   0
#define JTD   7
#define SM2   5
#define JTRF   4
#define WDRF   3
#define BORF   2
#define EXTRF   1
#define PORF   0
#define FOC0   7
#define WGM00   6
#define COM01   5
#define COM00   4
#define WGM01   3
#define CS02   2
#define CS01   1
#define CS00   0
#define TSM   7
#define XMBK   6
#define XMM2   5
#define XMM1   4
#define XMM0   3
#define PUD   2
#define PSR2   1
#define PSR310   0
#define COM1A1   7
#define COM1A0   6
#define COM1B1   5
#define COM1B0   4
#define FOC1A   3
#define FOC1B   2
#define WGM11   1
#define WGM10   0
#define ICNC1   7 /* Input Capture Noise Canceler */
#define ICES1   6 /* Input Capture Edge Select */
#define WGM13   4 /* Waveform Generation Mode 3 */
#define WGM12   3 /* Waveform Generation Mode 2 */
#define CS12   2 /* Clock Select 2 */
#define CS11   1 /* Clock Select 1 */
#define CS10   0 /* Clock Select 0 */
#define FOC2   7
#define WGM20   6
#define COM21   5
#define COM20   4
#define WGM21   3
#define CS22   2
#define CS21   1
#define CS20   0
#define AS2   3
#define TCN2UB   2
#define TCON2UB   2 /* Kept for backwards compatibility. */
#define OCR2UB   1
#define TCR2UB   0
#define WDCE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define URSEL0   7
#define URSEL0   7
#define UBRR011   3
#define UBRR010   2
#define UBRR09   1
#define UBRR08   0
#define UMSEL0   6
#define UPM01   5
#define UPM00   4
#define USBS0   3
#define UCSZ01   2
#define UCSZ00   1
#define UCPOL0   0
#define EEAR8   0
#define EERIE   3
#define EEMWE   2
#define EEWE   1
#define EERE   0
#define PA7   7
#define PA6   6
#define PA5   5
#define PA4   4
#define PA3   3
#define PA2   2
#define PA1   1
#define PA0   0
#define DDA7   7
#define DDA6   6
#define DDA5   5
#define DDA4   4
#define DDA3   3
#define DDA2   2
#define DDA1   1
#define DDA0   0
#define PINA7   7
#define PINA6   6
#define PINA5   5
#define PINA4   4
#define PINA3   3
#define PINA2   2
#define PINA1   1
#define PINA0   0
#define PB7   7
#define PB6   6
#define PB5   5
#define PB4   4
#define PB3   3
#define PB2   2
#define PB1   1
#define PB0   0
#define DDB7   7
#define DDB6   6
#define DDB5   5
#define DDB4   4
#define DDB3   3
#define DDB2   2
#define DDB1   1
#define DDB0   0
#define PINB7   7
#define PINB6   6
#define PINB5   5
#define PINB4   4
#define PINB3   3
#define PINB2   2
#define PINB1   1
#define PINB0   0
#define PC7   7
#define PC6   6
#define PC5   5
#define PC4   4
#define PC3   3
#define PC2   2
#define PC1   1
#define PC0   0
#define DDC7   7
#define DDC6   6
#define DDC5   5
#define DDC4   4
#define DDC3   3
#define DDC2   2
#define DDC1   1
#define DDC0   0
#define PINC7   7
#define PINC6   6
#define PINC5   5
#define PINC4   4
#define PINC3   3
#define PINC2   2
#define PINC1   1
#define PINC0   0
#define PD7   7
#define PD6   6
#define PD5   5
#define PD4   4
#define PD3   3
#define PD2   2
#define PD1   1
#define PD0   0
#define DDD7   7
#define DDD6   6
#define DDD5   5
#define DDD4   4
#define DDD3   3
#define DDD2   2
#define DDD1   1
#define DDD0   0
#define PIND7   7
#define PIND6   6
#define PIND5   5
#define PIND4   4
#define PIND3   3
#define PIND2   2
#define PIND1   1
#define PIND0   0
#define SPIF   7
#define WCOL   6
#define SPI2X   0
#define SPIE   7
#define SPE   6
#define DORD   5
#define MSTR   4
#define CPOL   3
#define CPHA   2
#define SPR1   1
#define SPR0   0
#define RXC0   7
#define TXC0   6
#define UDRE0   5
#define FE0   4
#define DOR0   3
#define UPE0   2
#define U2X0   1
#define MPCM0   0
#define RXCIE0   7
#define TXCIE0   6
#define UDRIE0   5
#define RXEN0   4
#define TXEN0   3
#define UCSZ02   2
#define RXB80   1
#define TXB80   0
#define ACD   7
#define ACBG   6
#define ACO   5
#define ACI   4
#define ACIE   3
#define ACIC   2
#define ACIS1   1
#define ACIS0   0
#define PE2   2
#define PE1   1
#define PE0   0
#define DDE2   2
#define DDE1   1
#define DDE0   0
#define PINE2   2
#define PINE1   1
#define PINE0   0
#define RXC1   7
#define TXC1   6
#define UDRE1   5
#define FE1   4
#define DOR1   3
#define UPE1   2
#define U2X1   1
#define MPCM1   0
#define RXCIE1   7
#define TXCIE1   6
#define UDRIE1   5
#define RXEN1   4
#define TXEN1   3
#define UCSZ12   2
#define RXB81   1
#define TXB81   0
#define SPM_PAGESIZE   128
#define RAMEND   0x4FF
#define XRAMEND   0xFFFF
#define E2END   0x1FF
#define E2PAGESIZE   4
#define FLASHEND   0x3FFF
#define FUSE_MEMORY_SIZE   3
#define FUSE_CKSEL0   (unsigned char)~_BV(0)
#define FUSE_CKSEL1   (unsigned char)~_BV(1)
#define FUSE_CKSEL2   (unsigned char)~_BV(2)
#define FUSE_CKSEL3   (unsigned char)~_BV(3)
#define FUSE_SUT0   (unsigned char)~_BV(4)
#define FUSE_SUT1   (unsigned char)~_BV(5)
#define FUSE_CKOUT   (unsigned char)~_BV(6)
#define FUSE_CKDIV8   (unsigned char)~_BV(7)
#define LFUSE_DEFAULT   (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
#define FUSE_BOOTRST   (unsigned char)~_BV(0)
#define FUSE_BOOTSZ0   (unsigned char)~_BV(1)
#define FUSE_BOOTSZ1   (unsigned char)~_BV(2)
#define FUSE_EESAVE   (unsigned char)~_BV(3)
#define FUSE_WDTON   (unsigned char)~_BV(4)
#define FUSE_SPIEN   (unsigned char)~_BV(5)
#define FUSE_JTAGEN   (unsigned char)~_BV(6)
#define FUSE_OCDEN   (unsigned char)~_BV(7)
#define HFUSE_DEFAULT   (FUSE_BOOTSZ0 & FUSE_BOOTSZ1 & FUSE_SPIEN & FUSE_JTAGEN)
#define FUSE_BODLEVEL0   (unsigned char)~_BV(1)
#define FUSE_BODLEVEL1   (unsigned char)~_BV(2)
#define FUSE_BODLEVEL2   (unsigned char)~_BV(3)
#define FUSE_M161C   (unsigned char)~_BV(4)
#define EFUSE_DEFAULT   (0xFF)
#define __LOCK_BITS_EXIST
#define __BOOT_LOCK_BITS_0_EXIST
#define __BOOT_LOCK_BITS_1_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x94
#define SIGNATURE_2   0x04
