AT94K Series FPSLIC(tm) Definitions
#define UBRR1   _SFR_IO8(0x00)
#define UCSR1B   _SFR_IO8(0x01)
#define UCSR1A   _SFR_IO8(0x02)
#define UDR1   _SFR_IO8(0x03)
#define PINE   _SFR_IO8(0x05)
#define DDRE   _SFR_IO8(0x06)
#define PORTE   _SFR_IO8(0x07)
#define OCDR   _SFR_IO8(0x08)
#define UBRR0   _SFR_IO8(0x09)
#define UCSR0B   _SFR_IO8(0x0A)
#define UCSR0A   _SFR_IO8(0x0B)
#define UDR0   _SFR_IO8(0x0C)
#define PIND   _SFR_IO8(0x10)
#define DDRD   _SFR_IO8(0x11)
#define PORTD   _SFR_IO8(0x12)
#define FISCR   _SFR_IO8(0x13)
#define FISUA   _SFR_IO8(0x14)
#define FISUB   _SFR_IO8(0x15)
#define FISUC   _SFR_IO8(0x16)
#define FISUD   _SFR_IO8(0x17)
#define FPGAX   _SFR_IO8(0x18)
#define FPGAY   _SFR_IO8(0x19)
#define FPGAZ   _SFR_IO8(0x1A)
#define FPGAD   _SFR_IO8(0x1B)
#define TWBR   _SFR_IO8(0x1C)
#define TWSR   _SFR_IO8(0x1D)
#define TWAR   _SFR_IO8(0x1E)
#define TWDR   _SFR_IO8(0x1F)
#define UBRRH   _SFR_IO8(0x20)
#define UBRRHI   UBRRH /* New name in datasheet (1138F-FPSLI-06/02) */
#define WDTCR   _SFR_IO8(0x21)
#define OCR2   _SFR_IO8(0x22)
#define TCNT2   _SFR_IO8(0x23)
#define ICR1   _SFR_IO16(0x24)
#define ICR1L   _SFR_IO8(0x24)
#define ICR1H   _SFR_IO8(0x25)
#define ASSR   _SFR_IO8(0x26)
#define TCCR2   _SFR_IO8(0x27)
#define OCR1B   _SFR_IO16(0x28)
#define OCR1BL   _SFR_IO8(0x28)
#define OCR1BH   _SFR_IO8(0x29)
#define OCR1A   _SFR_IO16(0x2A)
#define OCR1AL   _SFR_IO8(0x2A)
#define OCR1AH   _SFR_IO8(0x2B)
#define TCNT1   _SFR_IO16(0x2C)
#define TCNT1L   _SFR_IO8(0x2C)
#define TCNT1H   _SFR_IO8(0x2D)
#define TCCR1B   _SFR_IO8(0x2E)
#define TCCR1A   _SFR_IO8(0x2F)
#define SFIOR   _SFR_IO8(0x30)
#define OCR0   _SFR_IO8(0x31)
#define TCNT0   _SFR_IO8(0x32)
#define TCCR0   _SFR_IO8(0x33)
#define MCUR   _SFR_IO8(0x35)
#define TWCR   _SFR_IO8(0x36)
#define TIFR   _SFR_IO8(0x38)
#define TIMSK   _SFR_IO8(0x39)
#define SFTCR   _SFR_IO8(0x3A)
#define EIMF   _SFR_IO8(0x3B)
#define SIG_FPGA_INTERRUPT0   _VECTOR(1) /* FPGA_INT0 */
#define SIG_INTERRUPT0   _VECTOR(2) /* EXT_INT0 */
#define SIG_FPGA_INTERRUPT1   _VECTOR(3) /* FPGA_INT1 */
#define SIG_INTERRUPT1   _VECTOR(4) /* EXT_INT1 */
#define SIG_FPGA_INTERRUPT2   _VECTOR(5) /* FPGA_INT2 */
#define SIG_INTERRUPT2   _VECTOR(6) /* EXT_INT2 */
#define SIG_FPGA_INTERRUPT3   _VECTOR(7) /* FPGA_INT3 */
#define SIG_INTERRUPT3   _VECTOR(8) /* EXT_INT3 */
#define SIG_OUTPUT_COMPARE2   _VECTOR(9) /* TIM2_COMP */
#define SIG_OVERFLOW2   _VECTOR(10) /* TIM2_OVF */
#define SIG_INPUT_CAPTURE1   _VECTOR(11) /* TIM1_CAPT */
#define SIG_OUTPUT_COMPARE1A   _VECTOR(12) /* TIM1_COMPA */
#define SIG_OUTPUT_COMPARE1B   _VECTOR(13) /* TIM1_COMPB */
#define SIG_OVERFLOW1   _VECTOR(14) /* TIM1_OVF */
#define SIG_OUTPUT_COMPARE0   _VECTOR(15) /* TIM0_COMP */
#define SIG_OVERFLOW0   _VECTOR(16) /* TIM0_OVF */
#define SIG_FPGA_INTERRUPT4   _VECTOR(17) /* FPGA_INT4 */
#define SIG_FPGA_INTERRUPT5   _VECTOR(18) /* FPGA_INT5 */
#define SIG_FPGA_INTERRUPT6   _VECTOR(19) /* FPGA_INT6 */
#define SIG_FPGA_INTERRUPT7   _VECTOR(20) /* FPGA_INT7 */
#define SIG_UART0_RECV   _VECTOR(21) /* UART0_RXC */
#define SIG_UART0_DATA   _VECTOR(22) /* UART0_DRE */
#define SIG_UART0_TRANS   _VECTOR(23) /* UART0_TXC */
#define SIG_FPGA_INTERRUPT8   _VECTOR(24) /* FPGA_INT8 */
#define SIG_FPGA_INTERRUPT9   _VECTOR(25) /* FPGA_INT9 */
#define SIG_FPGA_INTERRUPT10   _VECTOR(26) /* FPGA_INT10 */
#define SIG_FPGA_INTERRUPT11   _VECTOR(27) /* FPGA_INT11 */
#define SIG_UART1_RECV   _VECTOR(28) /* UART1_RXC */
#define SIG_UART1_DATA   _VECTOR(29) /* UART1_DRE */
#define SIG_UART1_TRANS   _VECTOR(30) /* UART1_TXC */
#define SIG_FPGA_INTERRUPT12   _VECTOR(31) /* FPGA_INT12 */
#define SIG_FPGA_INTERRUPT13   _VECTOR(32) /* FPGA_INT13 */
#define SIG_FPGA_INTERRUPT14   _VECTOR(33) /* FPGA_INT14 */
#define SIG_FPGA_INTERRUPT15   _VECTOR(34) /* FPGA_INT15 */
#define SIG_2WIRE_SERIAL   _VECTOR(35) /* TWS_INT */
#define _VECTORS_SIZE   144
#define AS2   3
#define TCN2UB   2
#define OCR2UB   1
#define TCR2UB   0
#define DDD7   7
#define DDD6   6
#define DDD5   5
#define DDD4   4
#define DDD3   3
#define DDD2   2
#define DDD1   1
#define DDD0   0
#define DDE7   7
#define DDE6   6
#define DDE5   5
#define DDE4   4
#define DDE3   3
#define DDE2   2
#define DDE1   1
#define DDE0   0
#define INTF3   7
#define INTF2   6
#define INTF1   5
#define INTF0   4
#define INT3   3
#define INT2   2
#define INT1   1
#define INT0   0
#define FIADR   7
#define XFIS1   1
#define XFIS0   0
#define FIF3   7
#define FIF2   6
#define FIF1   5
#define FIF0   4
#define FINT3   3
#define FINT2   2
#define FINT1   1
#define FINT0   0
#define FIF7   7
#define FIF6   6
#define FIF5   5
#define FIF4   4
#define FINT7   3
#define FINT6   2
#define FINT5   1
#define FINT4   0
#define FIF11   7
#define FIF10   6
#define FIF9   5
#define FIF8   4
#define FINT11   3
#define FINT10   2
#define FINT9   1
#define FINT8   0
#define FIF15   7
#define FIF14   6
#define FIF13   5
#define FIF12   4
#define FINT15   3
#define FINT14   2
#define FINT13   1
#define FINT12   0
#define JTRF   7
#define JTD   6
#define SE   5
#define SM1   4
#define SM0   3
#define PORF   2
#define WDRF   1
#define EXTRF   0
#define IDRD   7
#define PIND7   7
#define PIND6   6
#define PIND5   5
#define PIND4   4
#define PIND3   3
#define PIND2   2
#define PIND1   1
#define PIND0   0
#define PINE7   7
#define PINE6   6
#define PINE5   5
#define PINE4   4
#define PINE3   3
#define PINE2   2
#define PINE1   1
#define PINE0   0
#define PD7   7
#define PD6   6
#define PD5   5
#define PD4   4
#define PD3   3
#define PD2   2
#define PD1   1
#define PD0   0
#define PE7   7
#define PE6   6
#define PE5   5
#define PE4   4
#define PE3   3
#define PE2   2
#define PE1   1
#define PE0   0
#define PSR2   1
#define PSR10   0
#define FMXOR   3
#define WDTS   2
#define DBG   1
#define SRST   0
#define FOC0   7
#define PWM0   6
#define COM01   5
#define COM00   4
#define CTC0   3
#define CS02   2
#define CS01   1
#define CS00   0
#define COM1A1   7
#define COM1A0   6
#define COM1B1   5
#define COM1B0   4
#define FOC1A   3
#define FOC1B   2
#define PWM11   1
#define PWM10   0
#define ICNC1   7
#define ICES1   6
#define ICPE   5
#define CTC1   3
#define CS12   2
#define CS11   1
#define CS10   0
#define FOC2   7
#define PWM2   6
#define COM21   5
#define COM20   4
#define CTC2   3
#define CS22   2
#define CS21   1
#define CS20   0
#define TOV1   7
#define OCF1A   6
#define OCF1B   5
#define TOV2   4
#define ICF1   3
#define OCF2   2
#define TOV0   1
#define OCF0   0
#define TOIE1   7
#define OCIE1A   6
#define OCIE1B   5
#define TOIE2   4
#define TICIE1   3
#define OCIE2   2
#define TOIE0   1
#define OCIE0   0
#define TWGCE   0
#define TWINT   7
#define TWEA   6
#define TWSTA   5
#define TWSTO   4
#define TWWC   3
#define TWEN   2
#define TWIE   0
#define TWS7   7
#define TWS6   6
#define TWS5   5
#define TWS4   4
#define TWS3   3
#define RXC0   7
#define TXC0   6
#define UDRE0   5
#define FE0   4
#define OR0   3
#define U2X0   1
#define MPCM0   0
#define RXCIE0   7
#define TXCIE0   6
#define UDRIE0   5
#define RXEN0   4
#define TXEN0   3
#define CHR90   2
#define RXB80   1
#define TXB80   0
#define RXC1   7
#define TXC1   6
#define UDRE1   5
#define FE1   4
#define OR1   3
#define U2X1   1
#define MPCM1   0
#define RXCIE1   7
#define TXCIE1   6
#define UDRIE1   5
#define RXEN1   4
#define TXEN1   3
#define CHR91   2
#define RXB81   1
#define TXB81   0
#define WDTOE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define RAMEND   0x0FFF
#define XRAMEND   RAMEND
#define E2END   0
#define FLASHEND   0x7FFF
