#define | _AVR_IOXXX_H_ "io4434.h" |
#define | ADC _SFR_IO16(0x04) |
#define | ADCW _SFR_IO16(0x04) |
#define | ADCL _SFR_IO8(0x04) |
#define | ADCH _SFR_IO8(0x05) |
#define | ADCSR _SFR_IO8(0x06) |
#define | ADMUX _SFR_IO8(0x07) |
#define | ACSR _SFR_IO8(0x08) |
#define | UBRR _SFR_IO8(0x09) |
#define | UCR _SFR_IO8(0x0A) |
#define | USR _SFR_IO8(0x0B) |
#define | UDR _SFR_IO8(0x0C) |
#define | SPCR _SFR_IO8(0x0D) |
#define | SPSR _SFR_IO8(0x0E) |
#define | SPDR _SFR_IO8(0x0F) |
#define | PIND _SFR_IO8(0x10) |
#define | DDRD _SFR_IO8(0x11) |
#define | PORTD _SFR_IO8(0x12) |
#define | PINC _SFR_IO8(0x13) |
#define | DDRC _SFR_IO8(0x14) |
#define | PORTC _SFR_IO8(0x15) |
#define | PINB _SFR_IO8(0x16) |
#define | DDRB _SFR_IO8(0x17) |
#define | PORTB _SFR_IO8(0x18) |
#define | PINA _SFR_IO8(0x19) |
#define | DDRA _SFR_IO8(0x1A) |
#define | PORTA _SFR_IO8(0x1B) |
#define | EECR _SFR_IO8(0x1C) |
#define | EEDR _SFR_IO8(0x1D) |
#define | EEAR _SFR_IO8(0x1E) |
#define | EEARL _SFR_IO8(0x1E) |
#define | WDTCR _SFR_IO8(0x21) |
#define | ASSR _SFR_IO8(0x22) |
#define | OCR2 _SFR_IO8(0x23) |
#define | TCNT2 _SFR_IO8(0x24) |
#define | TCCR2 _SFR_IO8(0x25) |
#define | ICR1 _SFR_IO16(0x26) |
#define | ICR1L _SFR_IO8(0x26) |
#define | ICR1H _SFR_IO8(0x27) |
#define | OCR1B _SFR_IO16(0x28) |
#define | OCR1BL _SFR_IO8(0x28) |
#define | OCR1BH _SFR_IO8(0x29) |
#define | OCR1A _SFR_IO16(0x2A) |
#define | OCR1AL _SFR_IO8(0x2A) |
#define | OCR1AH _SFR_IO8(0x2B) |
#define | TCNT1 _SFR_IO16(0x2C) |
#define | TCNT1L _SFR_IO8(0x2C) |
#define | TCNT1H _SFR_IO8(0x2D) |
#define | TCCR1B _SFR_IO8(0x2E) |
#define | TCCR1A _SFR_IO8(0x2F) |
#define | TCNT0 _SFR_IO8(0x32) |
#define | TCCR0 _SFR_IO8(0x33) |
#define | MCUSR _SFR_IO8(0x34) |
#define | MCUCR _SFR_IO8(0x35) |
#define | TIFR _SFR_IO8(0x38) |
#define | TIMSK _SFR_IO8(0x39) |
#define | GIFR _SFR_IO8(0x3A) |
#define | GIMSK _SFR_IO8(0x3B) |
#define | INT0_vect _VECTOR(1) |
#define | SIG_INTERRUPT0 _VECTOR(1) |
#define | INT1_vect _VECTOR(2) |
#define | SIG_INTERRUPT1 _VECTOR(2) |
#define | TIMER2_COMP_vect _VECTOR(3) |
#define | SIG_OUTPUT_COMPARE2 _VECTOR(3) |
#define | TIMER2_OVF_vect _VECTOR(4) |
#define | SIG_OVERFLOW2 _VECTOR(4) |
#define | TIMER1_CAPT_vect _VECTOR(5) |
#define | SIG_INPUT_CAPTURE1 _VECTOR(5) |
#define | TIMER1_COMPA_vect _VECTOR(6) |
#define | SIG_OUTPUT_COMPARE1A _VECTOR(6) |
#define | TIMER1_COMPB_vect _VECTOR(7) |
#define | SIG_OUTPUT_COMPARE1B _VECTOR(7) |
#define | TIMER1_OVF_vect _VECTOR(8) |
#define | SIG_OVERFLOW1 _VECTOR(8) |
#define | TIMER0_OVF_vect _VECTOR(9) |
#define | SIG_OVERFLOW0 _VECTOR(9) |
#define | SPI_STC_vect _VECTOR(10) |
#define | SIG_SPI _VECTOR(10) |
#define | UART_RX_vect _VECTOR(11) |
#define | SIG_UART_RECV _VECTOR(11) |
#define | UART_UDRE_vect _VECTOR(12) |
#define | SIG_UART_DATA _VECTOR(12) |
#define | UART_TX_vect _VECTOR(13) |
#define | SIG_UART_TRANS _VECTOR(13) |
#define | ADC_vect _VECTOR(14) |
#define | SIG_ADC _VECTOR(14) |
#define | EE_RDY_vect _VECTOR(15) |
#define | SIG_EEPROM_READY _VECTOR(15) |
#define | ANA_COMP_vect _VECTOR(16) |
#define | SIG_COMPARATOR _VECTOR(16) |
#define | _VECTORS_SIZE 34 |
#define | EXTRF 1 |
#define | PORF 0 |
#define | INT1 7 |
#define | INT0 6 |
#define | INTF1 7 |
#define | INTF0 6 |
#define | OCIE2 7 |
#define | TOIE2 6 |
#define | TICIE1 5 |
#define | OCIE1A 4 |
#define | OCIE1B 3 |
#define | TOIE1 2 |
#define | TOIE0 0 |
#define | OCF2 7 |
#define | TOV2 6 |
#define | ICF1 5 |
#define | OCF1A 4 |
#define | OCF1B 3 |
#define | TOV1 2 |
#define | TOV0 0 |
#define | SE 6 |
#define | SM1 5 |
#define | SM0 4 |
#define | ISC11 3 |
#define | ISC10 2 |
#define | ISC01 1 |
#define | ISC00 0 |
#define | CS02 2 |
#define | CS01 1 |
#define | CS00 0 |
#define | COM1A1 7 |
#define | COM1A0 6 |
#define | COM1B1 5 |
#define | COM1B0 4 |
#define | PWM11 1 |
#define | PWM10 0 |
#define | ICNC1 7 |
#define | ICES1 6 |
#define | CTC1 3 |
#define | CS12 2 |
#define | CS11 1 |
#define | CS10 0 |
#define | PWM2 6 |
#define | COM21 5 |
#define | COM20 4 |
#define | CTC2 3 |
#define | CS22 2 |
#define | CS21 1 |
#define | CS20 0 |
#define | AS2 3 |
#define | TCN2UB 2 |
#define | OCR2UB 1 |
#define | TCR2UB 0 |
#define | WDTOE 4 |
#define | WDE 3 |
#define | WDP2 2 |
#define | WDP1 1 |
#define | WDP0 0 |
#define | PA7 7 |
#define | PA6 6 |
#define | PA5 5 |
#define | PA4 4 |
#define | PA3 3 |
#define | PA2 2 |
#define | PA1 1 |
#define | PA0 0 |
#define | DDA7 7 |
#define | DDA6 6 |
#define | DDA5 5 |
#define | DDA4 4 |
#define | DDA3 3 |
#define | DDA2 2 |
#define | DDA1 1 |
#define | DDA0 0 |
#define | PINA7 7 |
#define | PINA6 6 |
#define | PINA5 5 |
#define | PINA4 4 |
#define | PINA3 3 |
#define | PINA2 2 |
#define | PINA1 1 |
#define | PINA0 0 |
#define | PB7 7 |
#define | PB6 6 |
#define | PB5 5 |
#define | PB4 4 |
#define | PB3 3 |
#define | PB2 2 |
#define | PB1 1 |
#define | PB0 0 |
#define | DDB7 7 |
#define | DDB6 6 |
#define | DDB5 5 |
#define | DDB4 4 |
#define | DDB3 3 |
#define | DDB2 2 |
#define | DDB1 1 |
#define | DDB0 0 |
#define | PINB7 7 |
#define | PINB6 6 |
#define | PINB5 5 |
#define | PINB4 4 |
#define | PINB3 3 |
#define | PINB2 2 |
#define | PINB1 1 |
#define | PINB0 0 |
#define | PC7 7 |
#define | PC6 6 |
#define | PC5 5 |
#define | PC4 4 |
#define | PC3 3 |
#define | PC2 2 |
#define | PC1 1 |
#define | PC0 0 |
#define | DDC7 7 |
#define | DDC6 6 |
#define | DDC5 5 |
#define | DDC4 4 |
#define | DDC3 3 |
#define | DDC2 2 |
#define | DDC1 1 |
#define | DDC0 0 |
#define | PINC7 7 |
#define | PINC6 6 |
#define | PINC5 5 |
#define | PINC4 4 |
#define | PINC3 3 |
#define | PINC2 2 |
#define | PINC1 1 |
#define | PINC0 0 |
#define | PD7 7 |
#define | PD6 6 |
#define | PD5 5 |
#define | PD4 4 |
#define | PD3 3 |
#define | PD2 2 |
#define | PD1 1 |
#define | PD0 0 |
#define | DDD7 7 |
#define | DDD6 6 |
#define | DDD5 5 |
#define | DDD4 4 |
#define | DDD3 3 |
#define | DDD2 2 |
#define | DDD1 1 |
#define | DDD0 0 |
#define | PIND7 7 |
#define | PIND6 6 |
#define | PIND5 5 |
#define | PIND4 4 |
#define | PIND3 3 |
#define | PIND2 2 |
#define | PIND1 1 |
#define | PIND0 0 |
#define | SPIE 7 |
#define | SPE 6 |
#define | DORD 5 |
#define | MSTR 4 |
#define | CPOL 3 |
#define | CPHA 2 |
#define | SPR1 1 |
#define | SPR0 0 |
#define | SPIF 7 |
#define | WCOL 6 |
#define | RXC 7 |
#define | TXC 6 |
#define | UDRE 5 |
#define | FE 4 |
#define | DOR 3 |
#define | RXCIE 7 |
#define | TXCIE 6 |
#define | UDRIE 5 |
#define | RXEN 4 |
#define | TXEN 3 |
#define | CHR9 2 |
#define | RXB8 1 |
#define | TXB8 0 |
#define | ACD 7 |
#define | ACO 5 |
#define | ACI 4 |
#define | ACIE 3 |
#define | ACIC 2 |
#define | ACIS1 1 |
#define | ACIS0 0 |
#define | MUX2 2 |
#define | MUX1 1 |
#define | MUX0 0 |
#define | ADEN 7 |
#define | ADSC 6 |
#define | ADFR 5 |
#define | ADIF 4 |
#define | ADIE 3 |
#define | ADPS2 2 |
#define | ADPS1 1 |
#define | ADPS0 0 |
#define | EERIE 3 |
#define | EEMWE 2 |
#define | EEWE 1 |
#define | EERE 0 |
#define | RAMEND 0x15F /*Last On-Chip SRAM location*/ |
#define | XRAMEND RAMEND |
#define | E2END 0xFF |
#define | E2PAGESIZE 0 |
#define | FLASHEND 0xFFF |
#define | FUSE_MEMORY_SIZE 1 |
#define | FUSE_SPIEN ~_BV(1) /* Serial Program Downloading Enabled */ |
#define | FUSE_FSTRT ~_BV(2) /* Short Start-up time selected */ |
#define | LFUSE_DEFAULT (0xFF) |
#define | __LOCK_BITS_EXIST |
#define | SIGNATURE_0 0x1E |
#define | SIGNATURE_1 0x93 |
#define | SIGNATURE_2 0x03 |
#define | DIDR _SFR_IO8(0x001) |
#define | AIN0D 0 |
#define | AIN1D 1 |
#define | UBRRH _SFR_IO8(0x002) |
#define | UBRR8 0 |
#define | UBRR9 1 |
#define | UBRR10 2 |
#define | UBRR11 3 |
#define | UCSRC _SFR_IO8(0x003) |
#define | UCPOL 0 |
#define | UCSZ0 1 |
#define | UCSZ1 2 |
#define | USBS 3 |
#define | UPM0 4 |
#define | UPM1 5 |
#define | UMSEL 6 |
#define | PCMSK1 _SFR_IO8(0x004) |
#define | PCINT8 0 |
#define | PCINT9 1 |
#define | PCINT10 2 |
#define | PCMSK2 _SFR_IO8(0x005) |
#define | PCINT11 0 |
#define | PCINT12 1 |
#define | PCINT13 2 |
#define | PCINT14 3 |
#define | PCINT15 4 |
#define | PCINT16 5 |
#define | PCINT17 6 |
#define | PRR _SFR_IO8(0x006) |
#define | PRUSART 0 |
#define | PRUSI 1 |
#define | PRTIM0 2 |
#define | PRTIM1 3 |
#define | BODCR _SFR_IO8(0x007) |
#define | BPDSE 0 |
#define | BPDS 1 |
#define | ACSR _SFR_IO8(0x008) |
#define | ACIS0 0 |
#define | ACIS1 1 |
#define | ACIC 2 |
#define | ACIE 3 |
#define | ACI 4 |
#define | ACO 5 |
#define | ACBG 6 |
#define | ACD 7 |
#define | UBRRL _SFR_IO8(0x009) |
#define | UBRR0 0 |
#define | UBRR1 1 |
#define | UBRR2 2 |
#define | UBRR3 3 |
#define | UBRR4 4 |
#define | UBRR5 5 |
#define | UBRR6 6 |
#define | UBRR7 7 |
#define | UCSRB _SFR_IO8(0x00A) |
#define | TXB8 0 |
#define | RXB8 1 |
#define | UCSZ2 2 |
#define | TXEN 3 |
#define | RXEN 4 |
#define | UDRIE 5 |
#define | TXCIE 6 |
#define | RXCIE 7 |
#define | UCSRA _SFR_IO8(0x00B) |
#define | MPCM 0 |
#define | U2X 1 |
#define | UPE 2 |
#define | DOR 3 |
#define | FE 4 |
#define | UDRE 5 |
#define | TXC 6 |
#define | RXC 7 |
#define | UDR _SFR_IO8(0x00C) |
#define | UDR0 0 |
#define | UDR1 1 |
#define | UDR2 2 |
#define | UDR3 3 |
#define | UDR4 4 |
#define | UDR5 5 |
#define | UDR6 6 |
#define | UDR7 7 |
#define | USICR _SFR_IO8(0x00D) |
#define | USITC 0 |
#define | USICLK 1 |
#define | USICS0 2 |
#define | USICS1 3 |
#define | USIWM0 4 |
#define | USIWM1 5 |
#define | USIOIE 6 |
#define | USISIE 7 |
#define | USISR _SFR_IO8(0x00E) |
#define | USICNT0 0 |
#define | USICNT1 1 |
#define | USICNT2 2 |
#define | USICNT3 3 |
#define | USIDC 4 |
#define | USIPF 5 |
#define | USIOIF 6 |
#define | USISIF 7 |
#define | USIDR _SFR_IO8(0x00F) |
#define | USIDR0 0 |
#define | USIDR1 1 |
#define | USIDR2 2 |
#define | USIDR3 3 |
#define | USIDR4 4 |
#define | USIDR5 5 |
#define | USIDR6 6 |
#define | USIDR7 7 |
#define | PIND _SFR_IO8(0x010) |
#define | PIND0 0 |
#define | PIND1 1 |
#define | PIND2 2 |
#define | PIND3 3 |
#define | PIND4 4 |
#define | PIND5 5 |
#define | PIND6 6 |
#define | DDRD _SFR_IO8(0x011) |
#define | DDD0 0 |
#define | DDD1 1 |
#define | DDD2 2 |
#define | DDD3 3 |
#define | DDD4 4 |
#define | DDD5 5 |
#define | DDD6 6 |
#define | PORTD _SFR_IO8(0x012) |
#define | PORTD0 0 |
#define | PORTD1 1 |
#define | PORTD2 2 |
#define | PORTD3 3 |
#define | PORTD4 4 |
#define | PORTD5 5 |
#define | PORTD6 6 |
#define | GPIOR0 _SFR_IO8(0x013) |
#define | GPIOR00 0 |
#define | GPIOR01 1 |
#define | GPIOR02 2 |
#define | GPIOR03 3 |
#define | GPIOR04 4 |
#define | GPIOR05 5 |
#define | GPIOR06 6 |
#define | GPIOR07 7 |
#define | GPIOR1 _SFR_IO8(0x014) |
#define | GPIOR10 0 |
#define | GPIOR11 1 |
#define | GPIOR12 2 |
#define | GPIOR13 3 |
#define | GPIOR14 4 |
#define | GPIOR15 5 |
#define | GPIOR16 6 |
#define | GPIOR17 7 |
#define | GPIOR2 _SFR_IO8(0x015) |
#define | GPIOR20 0 |
#define | GPIOR21 1 |
#define | GPIOR22 2 |
#define | GPIOR23 3 |
#define | GPIOR24 4 |
#define | GPIOR25 5 |
#define | GPIOR26 6 |
#define | GPIOR27 7 |
#define | PINB _SFR_IO8(0x016) |
#define | PINB0 0 |
#define | PINB1 1 |
#define | PINB2 2 |
#define | PINB3 3 |
#define | PINB4 4 |
#define | PINB5 5 |
#define | PINB6 6 |
#define | PINB7 7 |
#define | DDRB _SFR_IO8(0x017) |
#define | DDB0 0 |
#define | DDB1 1 |
#define | DDB2 2 |
#define | DDB3 3 |
#define | DDB4 4 |
#define | DDB5 5 |
#define | DDB6 6 |
#define | DDB7 7 |
#define | PORTB _SFR_IO8(0x018) |
#define | PORTB0 0 |
#define | PORTB1 1 |
#define | PORTB2 2 |
#define | PORTB3 3 |
#define | PORTB4 4 |
#define | PORTB5 5 |
#define | PORTB6 6 |
#define | PORTB7 7 |
#define | PINA _SFR_IO8(0x019) |
#define | PINA0 0 |
#define | PINA1 1 |
#define | PINA2 2 |
#define | DDRA _SFR_IO8(0x01A) |
#define | DDA0 0 |
#define | DDA1 1 |
#define | DDA2 2 |
#define | PORTA _SFR_IO8(0x01B) |
#define | PORTA0 0 |
#define | PORTA1 1 |
#define | PORTA2 2 |
#define | EECR _SFR_IO8(0x01C) |
#define | EERE 0 |
#define | EEPE 1 |
#define | EEMPE 2 |
#define | EERIE 3 |
#define | EEPM0 4 |
#define | EEPM1 5 |
#define | EEDR _SFR_IO8(0x01D) |
#define | EEDR0 0 |
#define | EEDR1 1 |
#define | EEDR2 2 |
#define | EEDR3 3 |
#define | EEDR4 4 |
#define | EEDR5 5 |
#define | EEDR6 6 |
#define | EEDR7 7 |
#define | EEAR _SFR_IO8(0x01E) |
#define | EEAR0 0 |
#define | EEAR1 1 |
#define | EEAR2 2 |
#define | EEAR3 3 |
#define | EEAR4 4 |
#define | EEAR5 5 |
#define | EEAR6 6 |
#define | PCMSK _SFR_IO8(0x020) |
#define | PCINT0 0 |
#define | PCINT1 1 |
#define | PCINT2 2 |
#define | PCINT3 3 |
#define | PCINT4 4 |
#define | PCINT5 5 |
#define | PCINT6 6 |
#define | PCINT7 7 |
#define | WDTCR _SFR_IO8(0x021) |
#define | WDP0 0 |
#define | WDP1 1 |
#define | WDP2 2 |
#define | WDE 3 |
#define | WDCE 4 |
#define | WDP3 5 |
#define | WDIE 6 |
#define | WDIF 7 |
#define | TCCR1C _SFR_IO8(0x022) |
#define | FOC1B 6 |
#define | FOC1A 7 |
#define | GTCCR _SFR_IO8(0x023) |
#define | PSR10 0 |
#define | ICR1 _SFR_IO16(0x024) |
#define | ICR1L _SFR_IO8(0x024) |
#define | ICR1L0 0 |
#define | ICR1L1 1 |
#define | ICR1L2 2 |
#define | ICR1L3 3 |
#define | ICR1L4 4 |
#define | ICR1L5 5 |
#define | ICR1L6 6 |
#define | ICR1L7 7 |
#define | ICR1H _SFR_IO8(0x025) |
#define | ICR1H0 0 |
#define | ICR1H1 1 |
#define | ICR1H2 2 |
#define | ICR1H3 3 |
#define | ICR1H4 4 |
#define | ICR1H5 5 |
#define | ICR1H6 6 |
#define | ICR1H7 7 |
#define | CLKPR _SFR_IO8(0x026) |
#define | CLKPS0 0 |
#define | CLKPS1 1 |
#define | CLKPS2 2 |
#define | CLKPS3 3 |
#define | CLKPCE 7 |
#define | OCR1B _SFR_IO16(0x028) |
#define | OCR1BL _SFR_IO8(0x028) |
#define | OCR1BL0 0 |
#define | OCR1BL1 1 |
#define | OCR1BL2 2 |
#define | OCR1BL3 3 |
#define | OCR1BL4 4 |
#define | OCR1BL5 5 |
#define | OCR1BL6 6 |
#define | OCR1BL7 7 |
#define | OCR1BH _SFR_IO8(0x029) |
#define | OCR1BH0 0 |
#define | OCR1BH1 1 |
#define | OCR1BH2 2 |
#define | OCR1BH3 3 |
#define | OCR1BH4 4 |
#define | OCR1BH5 5 |
#define | OCR1BH6 6 |
#define | OCR1BH7 7 |
#define | OCR1A _SFR_IO16(0x02A) |
#define | OCR1AL _SFR_IO8(0x02A) |
#define | OCR1AL0 0 |
#define | OCR1AL1 1 |
#define | OCR1AL2 2 |
#define | OCR1AL3 3 |
#define | OCR1AL4 4 |
#define | OCR1AL5 5 |
#define | OCR1AL6 6 |
#define | OCR1AL7 7 |
#define | OCR1AH _SFR_IO8(0x02B) |
#define | OCR1AH0 0 |
#define | OCR1AH1 1 |
#define | OCR1AH2 2 |
#define | OCR1AH3 3 |
#define | OCR1AH4 4 |
#define | OCR1AH5 5 |
#define | OCR1AH6 6 |
#define | OCR1AH7 7 |
#define | TCNT1 _SFR_IO16(0x02C) |
#define | TCNT1L _SFR_IO8(0x02C) |
#define | TCNT1L0 0 |
#define | TCNT1L1 1 |
#define | TCNT1L2 2 |
#define | TCNT1L3 3 |
#define | TCNT1L4 4 |
#define | TCNT1L5 5 |
#define | TCNT1L6 6 |
#define | TCNT1L7 7 |
#define | TCNT1H _SFR_IO8(0x02D) |
#define | TCNT1H0 0 |
#define | TCNT1H1 1 |
#define | TCNT1H2 2 |
#define | TCNT1H3 3 |
#define | TCNT1H4 4 |
#define | TCNT1H5 5 |
#define | TCNT1H6 6 |
#define | TCNT1H7 7 |
#define | TCCR1B _SFR_IO8(0x02E) |
#define | CS10 0 |
#define | CS11 1 |
#define | CS12 2 |
#define | WGM12 3 |
#define | WGM13 4 |
#define | ICES1 6 |
#define | ICNC1 7 |
#define | TCCR1A _SFR_IO8(0x02F) |
#define | WGM10 0 |
#define | WGM11 1 |
#define | TCCR0A _SFR_IO8(0x030) |
#define | WGM00 0 |
#define | WGM01 1 |
#define | COM0B0 4 |
#define | COM0B1 5 |
#define | COM0A0 6 |
#define | COM0A1 7 |
#define | OSCCAL _SFR_IO8(0x031) |
#define | CAL0 0 |
#define | CAL1 1 |
#define | CAL2 2 |
#define | CAL3 3 |
#define | CAL4 4 |
#define | CAL5 5 |
#define | CAL6 6 |
#define | TCNT0 _SFR_IO8(0x032) |
#define | TCNT0_0 0 |
#define | TCNT0_1 1 |
#define | TCNT0_2 2 |
#define | TCNT0_3 3 |
#define | TCNT0_4 4 |
#define | TCNT0_5 5 |
#define | TCNT0_6 6 |
#define | TCNT0_7 7 |
#define | TCCR0B _SFR_IO8(0x033) |
#define | CS00 0 |
#define | CS01 1 |
#define | CS02 2 |
#define | WGM02 3 |
#define | FOC0B 6 |
#define | FOC0A 7 |
#define | MCUSR _SFR_IO8(0x034) |
#define | PORF 0 |
#define | EXTRF 1 |
#define | BORF 2 |
#define | WDRF 3 |
#define | MCUCR _SFR_IO8(0x035) |
#define | ISC00 0 |
#define | ISC01 1 |
#define | ISC10 2 |
#define | ISC11 3 |
#define | SM0 4 |
#define | SE 5 |
#define | SM1 6 |
#define | PUD 7 |
#define | OCR0A _SFR_IO8(0x036) |
#define | OCR0A_0 0 |
#define | OCR0A_1 1 |
#define | OCR0A_2 2 |
#define | OCR0A_3 3 |
#define | OCR0A_4 4 |
#define | OCR0A_5 5 |
#define | OCR0A_6 6 |
#define | OCR0A_7 7 |
#define | SPMCSR _SFR_IO8(0x037) |
#define | SPMEN 0 |
#define | PGERS 1 |
#define | PGWRT 2 |
#define | RFLB 3 |
#define | CTPB 4 |
#define | TIFR _SFR_IO8(0x038) |
#define | OCF0A 0 |
#define | TOV0 1 |
#define | OCF0B 2 |
#define | ICF1 3 |
#define | OCF1B 5 |
#define | OCF1A 6 |
#define | TOV1 7 |
#define | TIMSK _SFR_IO8(0x039) |
#define | OCIE0A 0 |
#define | TOIE0 1 |
#define | OCIE0B 2 |
#define | ICIE1 3 |
#define | OCIE1B 5 |
#define | OCIE1A 6 |
#define | TOIE1 7 |
#define | EIFR _SFR_IO8(0x03A) |
#define | PCIF 5 |
#define | INTF0 6 |
#define | INTF1 7 |
#define | GIMSK _SFR_IO8(0x03B) |
#define | PCIE 5 |
#define | INT0 6 |
#define | INT1 7 |
#define | OCR0B _SFR_IO8(0x03C) |
#define | OCR0_0 0 |
#define | OCR0_1 1 |
#define | OCR0_2 2 |
#define | OCR0_3 3 |
#define | OCR0_4 4 |
#define | OCR0_5 5 |
#define | OCR0_6 6 |
#define | OCR0_7 7 |
#define | INT0_vect_num 1 |
#define | INT0_vect _VECTOR(1) /* External Interrupt Request 0 */ |
#define | INT1_vect_num 2 |
#define | INT1_vect _VECTOR(2) /* External Interrupt Request 1 */ |
#define | TIMER1_CAPT_vect_num 3 |
#define | TIMER1_CAPT_vect _VECTOR(3) /* Timer/Counter1 Capture Event */ |
#define | TIMER1_COMPA_vect_num 4 |
#define | TIMER1_COMPA_vect _VECTOR(4) /* Timer/Counter1 Compare Match A */ |
#define | TIMER1_OVF_vect_num 5 |
#define | TIMER1_OVF_vect _VECTOR(5) /* Timer/Counter1 Overflow */ |
#define | TIMER0_OVF_vect_num 6 |
#define | TIMER0_OVF_vect _VECTOR(6) /* Timer/Counter0 Overflow */ |
#define | USART_RX_vect_num 7 |
#define | USART_RX_vect _VECTOR(7) /* USART, Rx Complete */ |
#define | USART_UDRE_vect_num 8 |
#define | USART_UDRE_vect _VECTOR(8) /* USART Data Register Empty */ |
#define | USART_TX_vect_num 9 |
#define | USART_TX_vect _VECTOR(9) /* USART, Tx Complete */ |
#define | ANA_COMP_vect_num 10 |
#define | ANA_COMP_vect _VECTOR(10) /* Analog Comparator */ |
#define | PCINT_B_vect_num 11 |
#define | PCINT_B_vect _VECTOR(11) /* Pin Change Interrupt Request B */ |
#define | TIMER1_COMPB_vect_num 12 |
#define | TIMER1_COMPB_vect _VECTOR(12) /* */ |
#define | TIMER0_COMPA_vect_num 13 |
#define | TIMER0_COMPA_vect _VECTOR(13) /* */ |
#define | TIMER0_COMPB_vect_num 14 |
#define | TIMER0_COMPB_vect _VECTOR(14) /* */ |
#define | USI_START_vect_num 15 |
#define | USI_START_vect _VECTOR(15) /* USI Start Condition */ |
#define | USI_OVERFLOW_vect_num 16 |
#define | USI_OVERFLOW_vect _VECTOR(16) /* USI Overflow */ |
#define | WDT_OVERFLOW_vect_num 18 |
#define | WDT_OVERFLOW_vect _VECTOR(18) /* Watchdog Timer Overflow */ |
#define | PCINT_D_vect_num 20 |
#define | PCINT_D_vect _VECTOR(20) /* Pin Change Interrupt Request D */ |
#define | EEPROM_Ready_vect_num 17 |
#define | EEPROM_Ready_vect _VECTOR(17) /* */ |
#define | PCINT_A_vect_num 19 |
#define | PCINT_A_vect _VECTOR(19) /* Pin Change Interrupt Request A */ |
#define | _VECTOR_SIZE 2 /* Size of individual vector. */ |
#define | _VECTORS_SIZE (21 * _VECTOR_SIZE) |
#define | SPM_PAGESIZE (32) |
#define | RAMSTART (0x60) |
#define | RAMSIZE (128) |
#define | RAMEND (RAMSTART + RAMSIZE - 1) |
#define | XRAMSTART (NA) |
#define | XRAMSIZE (0) |
#define | XRAMEND (RAMEND) |
#define | E2END (0x7F) |
#define | E2PAGESIZE (4) |
#define | FLASHEND (0x7FF) |
#define | FUSE_MEMORY_SIZE 3 |
#define | FUSE_CKSEL0 (unsigned char)~_BV(0) /* Select Clock Source */ |
#define | FUSE_CKSEL1 (unsigned char)~_BV(1) /* Select Clock Source */ |
#define | FUSE_CKSEL2 (unsigned char)~_BV(2) /* Select Clock Source */ |
#define | FUSE_CKSEL3 (unsigned char)~_BV(3) /* Select Clock Source */ |
#define | FUSE_SUT0 (unsigned char)~_BV(4) /* Select start-up time */ |
#define | FUSE_SUT1 (unsigned char)~_BV(5) /* Select start-up time */ |
#define | FUSE_CKOUT (unsigned char)~_BV(6) /* Clock output */ |
#define | FUSE_CKDIV8 (unsigned char)~_BV(7) /* Divide clock by 8 */ |
#define | LFUSE_DEFAULT (FUSE_CKDIV8 & FUSE_SUT0 & FUSE_CKSEL3 & FUSE_CKSEL2 & FUSE_CKSEL0) |
#define | FUSE_BODLEVEL0 (unsigned char)~_BV(0) /* Brown-out Detector trigger level */ |
#define | FUSE_BODLEVEL1 (unsigned char)~_BV(1) /* Brown-out Detector trigger level */ |
#define | FUSE_BODLEVEL2 (unsigned char)~_BV(2) /* Brown-out Detector trigger level */ |
#define | FUSE_EESAVE (unsigned char)~_BV(3) /* EEPROM memory is preserved through chip erase */ |
#define | FUSE_WDTON (unsigned char)~_BV(4) /* Watchdog Timer Always On */ |
#define | FUSE_SPIEN (unsigned char)~_BV(5) /* Enable Serial programming and Data Downloading */ |
#define | FUSE_DWEN (unsigned char)~_BV(6) /* debugWIRE Enable */ |
#define | FUSE_RSTDISBL (unsigned char)~_BV(7) /* External reset disable */ |
#define | HFUSE_DEFAULT (FUSE_SPIEN) |
#define | FUSE_SELFPRGEN (unsigned char)~_BV(0) /* Self Programming Enable */ |
#define | EFUSE_DEFAULT (0xFF) |
#define | SIGNATURE_1 0x91 |
#define | SIGNATURE_2 0x0A |
#define | RXD_DDR DDRD |
#define | RXD_PORT PORTD |
#define | RXD_PIN PIND |
#define | RXD_BIT 0 |
#define | TXD_DDR DDRD |
#define | TXD_PORT PORTD |
#define | TXD_PIN PIND |
#define | TXD_BIT 1 |
#define | PA1_DDR DDRXTAL |
#define | PA1_PORT PORTXTAL |
#define | PA1_PIN PINXTAL |
#define | PA1_BIT XTAL2 |
#define | PA0_DDR DDRXTAL |
#define | PA0_PORT PORTXTAL |
#define | PA0_PIN PINXTAL |
#define | PA0_BIT XTAL1 |
#define | INT0_DDR DDRD |
#define | INT0_PORT PORTD |
#define | INT0_PIN PIND |
#define | INT0_BIT 2 |
#define | XCK_DDR DDRD |
#define | XCK_PORT PORTD |
#define | XCK_PIN PIND |
#define | XCK_BIT 2 |
#define | CKOUT_DDR DDRD |
#define | CKOUT_PORT PORTD |
#define | CKOUT_PIN PIND |
#define | CKOUT_BIT 2 |
#define | INT1_DDR DDRD |
#define | INT1_PORT PORTD |
#define | INT1_PIN PIND |
#define | INT1_BIT 3 |
#define | T0_DDR DDRD |
#define | T0_PORT PORTD |
#define | T0_PIN PIND |
#define | T0_BIT 4 |
#define | T1_DDR DDRD |
#define | T1_PORT PORTD |
#define | T1_PIN PIND |
#define | T1_BIT 5 |
#define | OC0B_DDR DDRD |
#define | OC0B_PORT PORTD |
#define | OC0B_PIN PIND |
#define | OC0B_BIT 5 |
#define | ICP_DDR DDRD |
#define | ICP_PORT PORTD |
#define | ICP_PIN PIND |
#define | ICP_BIT 6 |
#define | AIN0_DDR DDRB |
#define | AIN0_PORT PORTB |
#define | AIN0_PIN PINB |
#define | AIN0_BIT 0 |
#define | AIN1_DDR DDRB |
#define | AIN1_PORT PORTB |
#define | AIN1_PIN PINB |
#define | AIN1_BIT 1 |
#define | OC0A_DDR DDRB |
#define | OC0A_PORT PORTB |
#define | OC0A_PIN PINB |
#define | OC0A_BIT 2 |
#define | OC1A_DDR DDRB |
#define | OC1A_PORT PORTB |
#define | OC1A_PIN PINB |
#define | OC1A_BIT 3 |
#define | OC1B_DDR DDRB |
#define | OC1B_PORT PORTB |
#define | OC1B_PIN PINB |
#define | OC1B_BIT 4 |
#define | MOSI_DDR DDRB |
#define | MOSI_PORT PORTB |
#define | MOSI_PIN PINB |
#define | MOSI_BIT 5 |
#define | DI_DDR DDRB |
#define | DI_PORT PORTB |
#define | DI_PIN PINB |
#define | DI_BIT 5 |
#define | MISO_DDR DDRB |
#define | MISO_PORT PORTB |
#define | MISO_PIN PINB |
#define | MISO_BIT 6 |
#define | DO_DDR DDRB |
#define | DO_PORT PORTB |
#define | DO_PIN PINB |
#define | DO_BIT 6 |
#define | SCK_DDR DDRB |
#define | SCK_PORT PORTB |
#define | SCK_PIN PINB |
#define | SCK_BIT 7 |
#define | SCL_DDR DDRB |
#define | SCL_PORT PORTB |
#define | SCL_PIN PINB |
#define | SCL_BIT 7 |
