ATtiny28 Definitions
#define OSCCAL   _SFR_IO8(0x00)
#define WDTCR   _SFR_IO8(0x01)
#define MODCR   _SFR_IO8(0x02)
#define TCNT0   _SFR_IO8(0x03)
#define TCCR0   _SFR_IO8(0x04)
#define IFR   _SFR_IO8(0x05)
#define ICR   _SFR_IO8(0x06)
#define MCUCS   _SFR_IO8(0x07)
#define ACSR   _SFR_IO8(0x08)
#define PIND   _SFR_IO8(0x10)
#define DDRD   _SFR_IO8(0x11)
#define PORTD   _SFR_IO8(0x12)
#define PINB   _SFR_IO8(0x16)
#define PINA   _SFR_IO8(0x19)
#define PACR   _SFR_IO8(0x1A)
#define PORTA   _SFR_IO8(0x1B)
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define INT1_vect   _VECTOR(2)
#define SIG_INTERRUPT1   _VECTOR(2)
#define LOWLEVEL_IO_PINS_vect   _VECTOR(3)
#define SIG_PIN   _VECTOR(3)
#define TIMER0_OVF_vect   _VECTOR(4)
#define SIG_OVERFLOW0   _VECTOR(4)
#define ANA_COMP_vect   _VECTOR(5)
#define SIG_COMPARATOR   _VECTOR(5)
#define _VECTORS_SIZE   12
#define INT1   7
#define INT0   6
#define LLIE   5
#define TOIE0   4
#define ISC11   3
#define ISC10   2
#define ISC01   1
#define ISC00
#define INTF1   7
#define INTF0   6
#define TOV0   4
#define PLUPB   7
#define SE   5
#define SM   4
#define WDRF   3
#define EXTRF   1
#define PORF   0
#define FOV0   7
#define OOM01   4
#define OOM00   3
#define CS02   2
#define CS01   1
#define CS00   0
#define ONTIM4   7
#define ONTIM3   6
#define ONTIM2   5
#define ONTIM1   4
#define ONTIM0   3
#define MCONF2   2
#define MCONF1   1
#define MCONF0   0
#define WDTOE   4
#define WDE   3
#define WDP2   2
#define WDP1   1
#define WDP0   0
#define PA3   3
#define PA2   2
#define PA1   1
#define PA0   0
#define DDA3   3
#define PA2HC   2
#define DDA1   1
#define DDA0   0
#define PINA3   3
#define PINA1   1
#define PINA0   0
#define PINB7   7
#define PINB6   6
#define PINB5   5
#define PINB4   4
#define PINB3   3
#define PINB2   2
#define PINB1   1
#define PINB0   0
#define PD7   7
#define PD6   6
#define PD5   5
#define PD4   4
#define PD3   3
#define PD2   2
#define PD1   1
#define PD0   0
#define DDD7   7
#define DDD6   6
#define DDD5   5
#define DDD4   4
#define DDD3   3
#define DDD2   2
#define DDD1   1
#define DDD0   0
#define PIND7   7
#define PIND6   6
#define PIND5   5
#define PIND4   4
#define PIND3   3
#define PIND2   2
#define PIND1   1
#define PIND0   0
#define ACD   7
#define ACO   5
#define ACI   4
#define ACIE   3
#define ACIS1   1
#define ACIS0   0
#define RAMEND   0x1F
#define XRAMEND   0x0
#define E2END   0x0
#define E2PAGESIZE   0
#define FLASHEND   0x7FF
#define FUSE_MEMORY_SIZE   1
#define FUSE_CKSEL0   (unsigned char)~_BV(0)
#define FUSE_CKSEL1   (unsigned char)~_BV(1)
#define FUSE_CKSEL2   (unsigned char)~_BV(2)
#define FUSE_CKSEL3   (unsigned char)~_BV(3)
#define FUSE_INTCAP   (unsigned char)~_BV(4)
#define FUSE_DEFAULT   (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3)
#define __LOCK_BITS_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x91
#define SIGNATURE_2   0x07
