#define | ADCW _SFR_IO16(0x04) |
#define | ADC _SFR_IO16(0x04) |
#define | ADCL _SFR_IO8(0x04) |
#define | ADCH _SFR_IO8(0x05) |
#define | ADCSR _SFR_IO8(0x06) |
#define | ADPS0 0 |
#define | ADPS1 1 |
#define | ADPS2 2 |
#define | ADIE 3 |
#define | ADIF 4 |
#define | ADFR 5 |
#define | ADSC 6 |
#define | ADEN 7 |
#define | ADMUX _SFR_IO8(0x07) |
#define | MUX0 0 |
#define | MUX1 1 |
#define | MUX2 2 |
#define | MUX3 3 |
#define | MUX4 4 |
#define | ADLAR 5 |
#define | REFS0 6 |
#define | REFS1 7 |
#define | ACSR _SFR_IO8(0x08) |
#define | ACIS0 0 |
#define | ACIS1 1 |
#define | ACME 2 |
#define | ACIE 3 |
#define | ACI 4 |
#define | ACO 5 |
#define | ACBG 6 |
#define | ACD 7 |
#define | USICR _SFR_IO8(0x0D) |
#define | USITC 0 |
#define | USICLK 1 |
#define | USICS0 2 |
#define | USICS1 3 |
#define | USIWM0 4 |
#define | USIWM1 5 |
#define | USIOIE 6 |
#define | USISIE 7 |
#define | USISR _SFR_IO8(0x0E) |
#define | USICNT0 0 |
#define | USICNT1 1 |
#define | USICNT2 2 |
#define | USICNT3 3 |
#define | USIDC 4 |
#define | USIPF 5 |
#define | USIOIF 6 |
#define | USISIF 7 |
#define | USIDR _SFR_IO8(0x0F) |
#define | PINB _SFR_IO8(0x16) |
#define | PINB0 0 |
#define | PINB1 1 |
#define | PINB2 2 |
#define | PINB3 3 |
#define | PINB4 4 |
#define | PINB5 5 |
#define | PINB6 6 |
#define | PINB7 7 |
#define | DDRB _SFR_IO8(0x17) |
#define | DDB0 0 |
#define | DDB1 1 |
#define | DDB2 2 |
#define | DDB3 3 |
#define | DDB4 4 |
#define | DDB5 5 |
#define | DDB6 6 |
#define | DDB7 7 |
#define | PORTB _SFR_IO8(0x18) |
#define | PB0 0 |
#define | PB1 1 |
#define | PB2 2 |
#define | PB3 3 |
#define | PB4 4 |
#define | PB5 5 |
#define | PB6 6 |
#define | PB7 7 |
#define | PINA _SFR_IO8(0x19) |
#define | PINA0 0 |
#define | PINA1 1 |
#define | PINA2 2 |
#define | PINA3 3 |
#define | PINA4 4 |
#define | PINA5 5 |
#define | PINA6 6 |
#define | PINA7 7 |
#define | DDRA _SFR_IO8(0x1A) |
#define | DDA0 0 |
#define | DDA1 1 |
#define | DDA2 2 |
#define | DDA3 3 |
#define | DDA4 4 |
#define | DDA5 5 |
#define | DDA6 6 |
#define | DDA7 7 |
#define | PORTA _SFR_IO8(0x1B) |
#define | PA0 0 |
#define | PA1 1 |
#define | PA2 2 |
#define | PA3 3 |
#define | PA4 4 |
#define | PA5 5 |
#define | PA6 6 |
#define | PA7 7 |
#define | EECR _SFR_IO8(0x1C) |
#define | EERE 0 |
#define | EEWE 1 |
#define | EEMWE 2 |
#define | EERIE 3 |
#define | EEDR _SFR_IO8(0x1D) |
#define | EEAR _SFR_IO8(0x1E) |
#define | EEARL _SFR_IO8(0x1E) |
#define | WDTCR _SFR_IO8(0x21) |
#define | WDP0 0 |
#define | WDP1 1 |
#define | WDP2 2 |
#define | WDE 3 |
#define | WDCE 4 |
#define | PLLCSR _SFR_IO8(0x29) |
#define | PLOCK 0 |
#define | PLLE 1 |
#define | PCKE 2 |
#define | OCR1C _SFR_IO8(0x2B) |
#define | OCR1B _SFR_IO8(0x2C) |
#define | OCR1A _SFR_IO8(0x2D) |
#define | TCNT1 _SFR_IO8(0x2E) |
#define | TCCR1B _SFR_IO8(0x2F) |
#define | CS10 0 |
#define | CS11 1 |
#define | CS12 2 |
#define | CS13 3 |
#define | PSR1 6 |
#define | CTC1 7 |
#define | TCCR1A _SFR_IO8(0x30) |
#define | PWM1B 0 |
#define | PWM1A 1 |
#define | FOC1B 2 |
#define | FOC1A 3 |
#define | COM1B0 4 |
#define | COM1B1 5 |
#define | COM1A0 6 |
#define | COM1A1 7 |
#define | OSCCAL _SFR_IO8(0x31) |
#define | TCNT0 _SFR_IO8(0x32) |
#define | TCCR0 _SFR_IO8(0x33) |
#define | CS00 0 |
#define | CS01 1 |
#define | CS02 2 |
#define | PSR0 3 |
#define | MCUSR _SFR_IO8(0x34) |
#define | PORF 0 |
#define | EXTRF 1 |
#define | BORF 2 |
#define | WDRF 3 |
#define | MCUCR _SFR_IO8(0x35) |
#define | ISC00 0 |
#define | ISC01 1 |
#define | SM0 3 |
#define | SM1 4 |
#define | SE 5 |
#define | PUD 6 |
#define | TIFR _SFR_IO8(0x38) |
#define | TOV0 1 |
#define | TOV1 2 |
#define | OCF1B 5 |
#define | OCF1A 6 |
#define | TIMSK _SFR_IO8(0x39) |
#define | TOIE0 1 |
#define | TOIE1 2 |
#define | OCIE1B 5 |
#define | OCIE1A 6 |
#define | GIFR _SFR_IO8(0x3A) |
#define | PCIF 5 |
#define | INTF0 6 |
#define | GIMSK _SFR_IO8(0x3B) |
#define | PCIE0 4 |
#define | PCIE1 5 |
#define | INT0 6 |
#define | INT0_vect _VECTOR(1) |
#define | SIG_INTERRUPT0 _VECTOR(1) |
#define | IO_PINS_vect _VECTOR(2) |
#define | SIG_PIN_CHANGE _VECTOR(2) |
#define | TIMER1_CMPA_vect _VECTOR(3) |
#define | SIG_OUTPUT_COMPARE1A _VECTOR(3) |
#define | TIMER1_CMPB_vect _VECTOR(4) |
#define | SIG_OUTPUT_COMPARE1B _VECTOR(4) |
#define | TIMER1_OVF1_vect _VECTOR(5) |
#define | SIG_OVERFLOW1 _VECTOR(5) |
#define | TIMER0_OVF0_vect _VECTOR(6) |
#define | SIG_OVERFLOW0 _VECTOR(6) |
#define | USI_STRT_vect _VECTOR(7) |
#define | SIG_USI_START _VECTOR(7) |
#define | USI_OVF_vect _VECTOR(8) |
#define | SIG_USI_OVERFLOW _VECTOR(8) |
#define | EE_RDY_vect _VECTOR(9) |
#define | SIG_EEPROM_READY _VECTOR(9) |
#define | ANA_COMP_vect _VECTOR(10) |
#define | SIG_ANA_COMP _VECTOR(10) |
#define | SIG_COMPARATOR _VECTOR(10) |
#define | ADC_vect _VECTOR(11) |
#define | SIG_ADC _VECTOR(11) |
#define | _VECTORS_SIZE 24 |
#define | RAMEND 0xDF |
#define | XRAMEND RAMEND |
#define | E2END 0x7F |
#define | E2PAGESIZE 4 |
#define | FLASHEND 0x07FF |
#define | FUSE_MEMORY_SIZE 2 |
#define | FUSE_CKSEL0 (unsigned char)~_BV(0) |
#define | FUSE_CKSEL1 (unsigned char)~_BV(1) |
#define | FUSE_CKSEL2 (unsigned char)~_BV(2) |
#define | FUSE_CKSEL3 (unsigned char)~_BV(3) |
#define | FUSE_SUT0 (unsigned char)~_BV(4) |
#define | FUSE_SUT1 (unsigned char)~_BV(5) |
#define | FUSE_CKOPT (unsigned char)~_BV(6) |
#define | FUSE_PLLCK (unsigned char)~_BV(7) |
#define | LFUSE_DEFAULT (FUSE_CKSEL1 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0) |
#define | FUSE_BODEN (unsigned char)~_BV(0) |
#define | FUSE_BODLEVEL (unsigned char)~_BV(1) |
#define | FUSE_EESAVE (unsigned char)~_BV(2) |
#define | FUSE_SPIEN (unsigned char)~_BV(3) |
#define | FUSE_RSTDISBL (unsigned char)~_BV(4) |
#define | HFUSE_DEFAULT (FUSE_SPIEN) |
#define | __LOCK_BITS_EXIST |
#define | SIGNATURE_0 0x1E |
#define | SIGNATURE_1 0x91 |
#define | SIGNATURE_2 0x09 |
