ATmega88 Definitions
#define SPM_PAGESIZE   64
#define RAMEND   0x4FF
#define XRAMEND   RAMEND
#define E2END   0x1FF
#define E2PAGESIZE   4
#define FLASHEND   0x1FFF
#define FUSE_MEMORY_SIZE   3
#define FUSE_CKSEL0   (unsigned char)~_BV(0) /* Select Clock Source */
#define FUSE_CKSEL1   (unsigned char)~_BV(1) /* Select Clock Source */
#define FUSE_CKSEL2   (unsigned char)~_BV(2) /* Select Clock Source */
#define FUSE_CKSEL3   (unsigned char)~_BV(3) /* Select Clock Source */
#define FUSE_SUT0   (unsigned char)~_BV(4) /* Select start-up time */
#define FUSE_SUT1   (unsigned char)~_BV(5) /* Select start-up time */
#define FUSE_CKOUT   (unsigned char)~_BV(6) /* Clock output */
#define FUSE_CKDIV8   (unsigned char)~_BV(7) /* Divide clock by 8 */
#define LFUSE_DEFAULT   (FUSE_CKSEL0 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0 & FUSE_CKDIV8)
#define FUSE_BODLEVEL0   (unsigned char)~_BV(0) /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL1   (unsigned char)~_BV(1) /* Brown-out Detector trigger level */
#define FUSE_BODLEVEL2   (unsigned char)~_BV(2) /* Brown-out Detector trigger level */
#define FUSE_EESAVE   (unsigned char)~_BV(3) /* EEPROM memory is preserved through chip erase */
#define FUSE_WDTON   (unsigned char)~_BV(4) /* Watchdog Timer Always On */
#define FUSE_SPIEN   (unsigned char)~_BV(5) /* Enable Serial programming and Data Downloading */
#define FUSE_DWEN   (unsigned char)~_BV(6) /* debugWIRE Enable */
#define FUSE_RSTDISBL   (unsigned char)~_BV(7) /* External reset disable */
#define HFUSE_DEFAULT   (FUSE_SPIEN)
#define FUSE_BOOTRST   (unsigned char)~_BV(0)
#define FUSE_BOOTSZ0   (unsigned char)~_BV(1)
#define FUSE_BOOTSZ1   (unsigned char)~_BV(2)
#define EFUSE_DEFAULT   (FUSE_BOOTSZ0 & FUSE_BOOTSZ1)
#define __LOCK_BITS_EXIST
#define __BOOT_LOCK_BITS_0_EXIST
#define __BOOT_LOCK_BITS_1_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x93
#define SIGNATURE_2   0x0A
