#define | ACSR _SFR_IO8(0x08) |
#define | UBRR _SFR_IO8(0x09) |
#define | UCR _SFR_IO8(0x0A) |
#define | USR _SFR_IO8(0x0B) |
#define | UDR _SFR_IO8(0x0C) |
#define | SPCR _SFR_IO8(0x0D) |
#define | SPSR _SFR_IO8(0x0E) |
#define | SPDR _SFR_IO8(0x0F) |
#define | PIND _SFR_IO8(0x10) |
#define | DDRD _SFR_IO8(0x11) |
#define | PORTD _SFR_IO8(0x12) |
#define | PINC _SFR_IO8(0x13) |
#define | DDRC _SFR_IO8(0x14) |
#define | PORTC _SFR_IO8(0x15) |
#define | PINB _SFR_IO8(0x16) |
#define | DDRB _SFR_IO8(0x17) |
#define | PORTB _SFR_IO8(0x18) |
#define | PINA _SFR_IO8(0x19) |
#define | DDRA _SFR_IO8(0x1A) |
#define | PORTA _SFR_IO8(0x1B) |
#define | EECR _SFR_IO8(0x1C) |
#define | EEDR _SFR_IO8(0x1D) |
#define | EEAR _SFR_IO8(0x1E) |
#define | EEARL _SFR_IO8(0x1E) |
#define | WDTCR _SFR_IO8(0x21) |
#define | ICR1 _SFR_IO16(0x24) |
#define | ICR1L _SFR_IO8(0x24) |
#define | ICR1H _SFR_IO8(0x25) |
#define | OCR1B _SFR_IO16(0x28) |
#define | OCR1BL _SFR_IO8(0x28) |
#define | OCR1BH _SFR_IO8(0x29) |
#define | OCR1A _SFR_IO16(0x2A) |
#define | OCR1AL _SFR_IO8(0x2A) |
#define | OCR1AH _SFR_IO8(0x2B) |
#define | TCNT1 _SFR_IO16(0x2C) |
#define | TCNT1L _SFR_IO8(0x2C) |
#define | TCNT1H _SFR_IO8(0x2D) |
#define | TCCR1B _SFR_IO8(0x2E) |
#define | TCCR1A _SFR_IO8(0x2F) |
#define | TCNT0 _SFR_IO8(0x32) |
#define | TCCR0 _SFR_IO8(0x33) |
#define | MCUCR _SFR_IO8(0x35) |
#define | TIFR _SFR_IO8(0x38) |
#define | TIMSK _SFR_IO8(0x39) |
#define | GIFR _SFR_IO8(0x3A) |
#define | GIMSK _SFR_IO8(0x3B) |
#define | INT0_vect _VECTOR(1) |
#define | SIG_INTERRUPT0 _VECTOR(1) |
#define | INT1_vect _VECTOR(2) |
#define | SIG_INTERRUPT1 _VECTOR(2) |
#define | TIMER1_CAPT_vect _VECTOR(3) |
#define | SIG_INPUT_CAPTURE1 _VECTOR(3) |
#define | TIMER1_COMPA_vect _VECTOR(4) |
#define | SIG_OUTPUT_COMPARE1A _VECTOR(4) |
#define | TIMER1_COMPB_vect _VECTOR(5) |
#define | SIG_OUTPUT_COMPARE1B _VECTOR(5) |
#define | TIMER1_OVF_vect _VECTOR(6) |
#define | SIG_OVERFLOW1 _VECTOR(6) |
#define | TIMER0_OVF_vect _VECTOR(7) |
#define | SIG_OVERFLOW0 _VECTOR(7) |
#define | SPI_STC_vect _VECTOR(8) |
#define | SIG_SPI _VECTOR(8) |
#define | UART_RX_vect _VECTOR(9) |
#define | SIG_UART_RECV _VECTOR(9) |
#define | UART_UDRE_vect _VECTOR(10) |
#define | SIG_UART_DATA _VECTOR(10) |
#define | UART_TX_vect _VECTOR(11) |
#define | SIG_UART_TRANS _VECTOR(11) |
#define | ANA_COMP_vect _VECTOR(12) |
#define | SIG_COMPARATOR _VECTOR(12) |
#define | _VECTORS_SIZE 26 |
#define | INT1 7 |
#define | INT0 6 |
#define | INTF1 7 |
#define | INTF0 6 |
#define | TOIE1 7 |
#define | OCIE1A 6 |
#define | OCIE1B 5 |
#define | TICIE1 3 |
#define | TOIE0 1 |
#define | TOV1 7 |
#define | OCF1A 6 |
#define | OCF1B 5 |
#define | ICF1 3 |
#define | TOV0 1 |
#define | SRE 7 |
#define | SRW 6 |
#define | SE 5 |
#define | SM 4 |
#define | ISC11 3 |
#define | ISC10 2 |
#define | ISC01 1 |
#define | ISC00 0 |
#define | CS02 2 |
#define | CS01 1 |
#define | CS00 0 |
#define | COM1A1 7 |
#define | COM1A0 6 |
#define | COM1B1 5 |
#define | COM1B0 4 |
#define | PWM11 1 |
#define | PWM10 0 |
#define | ICNC1 7 |
#define | ICES1 6 |
#define | CTC1 3 |
#define | CS12 2 |
#define | CS11 1 |
#define | CS10 0 |
#define | WDTOE 4 |
#define | WDE 3 |
#define | WDP2 2 |
#define | WDP1 1 |
#define | WDP0 0 |
#define | PA7 7 |
#define | PA6 6 |
#define | PA5 5 |
#define | PA4 4 |
#define | PA3 3 |
#define | PA2 2 |
#define | PA1 1 |
#define | PA0 0 |
#define | DDA7 7 |
#define | DDA6 6 |
#define | DDA5 5 |
#define | DDA4 4 |
#define | DDA3 3 |
#define | DDA2 2 |
#define | DDA1 1 |
#define | DDA0 0 |
#define | PINA7 7 |
#define | PINA6 6 |
#define | PINA5 5 |
#define | PINA4 4 |
#define | PINA3 3 |
#define | PINA2 2 |
#define | PINA1 1 |
#define | PINA0 0 |
#define | PB7 7 |
#define | PB6 6 |
#define | PB5 5 |
#define | PB4 4 |
#define | PB3 3 |
#define | PB2 2 |
#define | PB1 1 |
#define | PB0 0 |
#define | DDB7 7 |
#define | DDB6 6 |
#define | DDB5 5 |
#define | DDB4 4 |
#define | DDB3 3 |
#define | DDB2 2 |
#define | DDB1 1 |
#define | DDB0 0 |
#define | PINB7 7 |
#define | PINB6 6 |
#define | PINB5 5 |
#define | PINB4 4 |
#define | PINB3 3 |
#define | PINB2 2 |
#define | PINB1 1 |
#define | PINB0 0 |
#define | PC7 7 |
#define | PC6 6 |
#define | PC5 5 |
#define | PC4 4 |
#define | PC3 3 |
#define | PC2 2 |
#define | PC1 1 |
#define | PC0 0 |
#define | DDC7 7 |
#define | DDC6 6 |
#define | DDC5 5 |
#define | DDC4 4 |
#define | DDC3 3 |
#define | DDC2 2 |
#define | DDC1 1 |
#define | DDC0 0 |
#define | PINC7 7 |
#define | PINC6 6 |
#define | PINC5 5 |
#define | PINC4 4 |
#define | PINC3 3 |
#define | PINC2 2 |
#define | PINC1 1 |
#define | PINC0 0 |
#define | PD7 7 |
#define | PD6 6 |
#define | PD5 5 |
#define | PD4 4 |
#define | PD3 3 |
#define | PD2 2 |
#define | PD1 1 |
#define | PD0 0 |
#define | DDD7 7 |
#define | DDD6 6 |
#define | DDD5 5 |
#define | DDD4 4 |
#define | DDD3 3 |
#define | DDD2 2 |
#define | DDD1 1 |
#define | DDD0 0 |
#define | PIND7 7 |
#define | PIND6 6 |
#define | PIND5 5 |
#define | PIND4 4 |
#define | PIND3 3 |
#define | PIND2 2 |
#define | PIND1 1 |
#define | PIND0 0 |
#define | SPIF 7 |
#define | WCOL 6 |
#define | SPIE 7 |
#define | SPE 6 |
#define | DORD 5 |
#define | MSTR 4 |
#define | CPOL 3 |
#define | CPHA 2 |
#define | SPR1 1 |
#define | SPR0 0 |
#define | RXC 7 |
#define | TXC 6 |
#define | UDRE 5 |
#define | FE 4 |
#define | DOR 3 |
#define | RXCIE 7 |
#define | TXCIE 6 |
#define | UDRIE 5 |
#define | RXEN 4 |
#define | TXEN 3 |
#define | CHR9 2 |
#define | RXB8 1 |
#define | TXB8 0 |
#define | ACD 7 |
#define | ACO 5 |
#define | ACI 4 |
#define | ACIE 3 |
#define | ACIC 2 |
#define | ACIS1 1 |
#define | ACIS0 0 |
#define | EERIE 3 |
#define | EEMWE 2 |
#define | EEWE 1 |
#define | EERE 0 |
#define | RAMEND 0x15F /* Last On-Chip SRAM Location */ |
#define | XRAMEND 0xFFFF |
#define | E2END 0xFF |
#define | E2PAGESIZE 0 |
#define | FLASHEND 0xFFF |
#define | FUSE_MEMORY_SIZE 1 |
#define | FUSE_SPIEN (unsigned char)~_BV(1) /* Serial Program Downloading Enabled */ |
#define | FUSE_FSTRT (unsigned char)~_BV(2) /* Short Start-up time selected */ |
#define | LFUSE_DEFAULT (0xFF) |
#define | __LOCK_BITS_EXIST |
#define | SIGNATURE_0 0x1E |
#define | SIGNATURE_1 0x92 |
#define | SIGNATURE_2 0x01 |
