#include "deflate.h"
struct | config_s |
struct | static_tree_desc_s |
Typedefs | |
typedef block_state compress_func | OF((deflate_state *s, int flush)) |
typedef struct config_s | config |
Enumerations | |
enum | block_state { need_more, block_done, finish_started, finish_done } |
local void fill_window | OF ((deflate_state *s)) |
local block_state deflate_stored | OF ((deflate_state *s, int flush)) |
local void putShortMSB | OF ((deflate_state *s, uInt b)) |
local void flush_pending | OF ((z_streamp strm)) |
local int read_buf | OF ((z_streamp strm, Bytef *buf, unsigned size)) |
local uInt longest_match | OF ((deflate_state *s, IPos cur_match)) |
int ZEXPORT | deflateInit_ (z_streamp strm, int level, const char *version, int stream_size) |
int ZEXPORT | deflateInit2_ (z_streamp strm, int level, int method, int windowBits, int memLevel, int strategy, const char *version, int stream_size) |
int ZEXPORT | deflateSetDictionary (z_streamp strm, const Bytef *dictionary, uInt dictLength) |
int ZEXPORT | deflateReset (z_streamp strm) |
int ZEXPORT | deflateSetHeader (z_streamp strm, gz_headerp head) |
int ZEXPORT | deflatePrime (z_streamp strm, int bits, int value) |
int ZEXPORT | deflateParams (z_streamp strm, int level, int strategy) |
int ZEXPORT | deflateTune (z_streamp strm, int good_length, int max_lazy, int nice_length, int max_chain) |
uLong ZEXPORT | deflateBound (z_streamp strm, uLong sourceLen) |
local void | putShortMSB (deflate_state *s, uInt b) |
local void | flush_pending (z_streamp strm) |
int ZEXPORT | deflate (z_streamp strm, int flush) |
int ZEXPORT | deflateEnd (z_streamp strm) |
int ZEXPORT | deflateCopy (z_streamp dest, z_streamp source) |
local int | read_buf (z_streamp strm, Bytef *buf, unsigned size) |
local void | lm_init (deflate_state *s) |
local uInt | longest_match (deflate_state *s, IPos cur_match) |
local void | fill_window (deflate_state *s) |
local block_state | deflate_stored (deflate_state *s, int flush) |
local block_state | deflate_fast (deflate_state *s, int flush) |
local block_state | deflate_slow (deflate_state *s, int flush) |
local block_state | deflate_rle (deflate_state *s, int flush) |
local block_state | deflate_huff (deflate_state *s, int flush) |
const char | deflate_copyright [] |
local const config | configuration_table [10] |
#define CLEAR_HASH | ( | s | ) |
#define FLUSH_BLOCK | ( | s, | |
last | |||
#define FLUSH_BLOCK_ONLY | ( | s, | |
last | |||
#define INSERT_STRING | ( | s, | |
str, | |||
match_head | |||
local const config configuration_table[10] |
const char deflate_copyright[] |
