clnt.h
1 /* $NetBSD: clnt.h,v 1.14 2000/06/02 22:57:55 fvdl Exp $ */
2
3 /*
4  * The contents of this file are subject to the Sun Standards
5  * License Version 1.0 the (the "License";) You may not use
6  * this file except in compliance with the License. You may
7  * obtain a copy of the License at lib/libc/rpc/LICENSE
8  *
9  * Software distributed under the License is distributed on
10  * an "AS IS" basis, WITHOUT WARRANTY OF ANY KIND, either
11  * express or implied. See the License for the specific
12  * language governing rights and limitations under the License.
13  *
14  * The Original Code is Copyright 1998 by Sun Microsystems, Inc
15  *
16  * The Initial Developer of the Original Code is: Sun
17  * Microsystems, Inc.
18  *
19  * All Rights Reserved.
20  *
21  * Sun RPC is a product of Sun Microsystems, Inc. and is provided for
22  * unrestricted use provided that this legend is included on all tape
23  * media and as a part of the software program in whole or part. Users
24  * may copy or modify Sun RPC without charge, but are not authorized
25  * to license or distribute it to anyone else except as part of a product or
26  * program developed by the user.
27  *
28  * SUN RPC IS PROVIDED AS IS WITH NO WARRANTIES OF ANY KIND INCLUDING THE
29  * WARRANTIES OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR
30  * PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE OR TRADE PRACTICE.
31  *
32  * Sun RPC is provided with no support and without any obligation on the
33  * part of Sun Microsystems, Inc. to assist in its use, correction,
34  * modification or enhancement.
35  *
36  * SUN MICROSYSTEMS, INC. SHALL HAVE NO LIABILITY WITH RESPECT TO THE
37  * INFRINGEMENT OF COPYRIGHTS, TRADE SECRETS OR ANY PATENTS BY SUN RPC
38  * OR ANY PART THEREOF.
39  *
40  * In no event will Sun Microsystems, Inc. be liable for any lost revenue
41  * or profits or other special, indirect and consequential damages, even if
42  * Sun has been advised of the possibility of such damages.
43  *
44  * Sun Microsystems, Inc.
45  * 2550 Garcia Avenue
46  * Mountain View, California 94043
47  *
48  * from: @(#)clnt.h 1.31 94/04/29 SMI
49  * from: @(#)clnt.h 2.1 88/07/29 4.0 RPCSRC
50  * $FreeBSD: src/include/rpc/clnt.h,v 1.21 2003/01/24 01:47:55 fjoe Exp $
51  */
52
53 /*
54  * clnt.h - Client side remote procedure call interface.
55  *
56  * Copyright (c) 1986-1991,1994-1999 by Sun Microsystems, Inc.
57  * All rights reserved.
58  */
59
60
61 #ifndef _RPC_CLNT_H_
62 #define _RPC_CLNT_H_
63 #include <rpc/clnt_stat.h>
64 #include <sys/cdefs.h>
65 #include <sys/un.h>
66 #include <rpc/auth.h> /* auth_stat */
67
68 /*
69  * Error info.
70  */
71 struct rpc_err {
72  enum clnt_stat re_status;
73  union {
74  int RE_errno; /* related system error */
75  enum auth_stat RE_why; /* why the auth error occurred */
76  struct {
77  rpcvers_t low; /* lowest version supported */
78  rpcvers_t high; /* highest version supported */
79  } RE_vers;
80  struct { /* maybe meaningful if RPC_FAILED */
81  int32_t s1;
82  int32_t s2;
83  } RE_lb; /* life boot & debugging only */
84  } ru;
85 #define re_errno ru.RE_errno
86 #define re_why ru.RE_why
87 #define re_vers ru.RE_vers
88 #define re_lb ru.RE_lb
89 };
90
91
92 /*
93  * Client rpc handle.
94  * Created by individual implementations
95  * Client is responsible for initializing auth, see e.g. auth_none.c.
96  */
97 typedef struct __rpc_client {
98  AUTH *cl_auth; /* authenticator */
99  struct clnt_ops {
100  /* call remote procedure */
101  enum clnt_stat (*cl_call)(struct __rpc_client *,
102  rpcproc_t, xdrproc_t, void *, xdrproc_t,
103  void *, struct timeval);
104  /* abort a call */
105  void (*cl_abort)(void);
106  /* get specific error code */
107  void (*cl_geterr)(struct __rpc_client *,
108  struct rpc_err *);
109  /* frees results */
110  bool_t (*cl_freeres)(struct __rpc_client *,
111  xdrproc_t, void *);
112  /* destroy this structure */
113  void (*cl_destroy)(struct __rpc_client *);
114  /* the ioctl() of rpc */
115  bool_t (*cl_control)(struct __rpc_client *, int,
116  char *);
117  } *cl_ops;
118  void *cl_private; /* private stuff */
119 } CLIENT;
120
121 #define RPCSMALLMSGSIZE 400 /* a more reasonable packet size */
122
123 /*
124  * client side rpc interface ops
125  *
126  * Parameter types are:
127  *
128  */
129
130 /*
131  * enum clnt_stat
132  * CLNT_CALL(rh, proc, xargs, argsp, xres, resp, timeout)
133  * CLIENT *rh;
134  * rpcproc_t proc;
135  * xdrproc_t xargs;
136  * void *argsp;
137  * xdrproc_t xres;
138  * void *resp;
139  * struct timeval timeout;
140  */
141 #define CLNT_CALL(rh, proc, xargs, argsp, xres, resp, secs) \
142  ((*(rh)->cl_ops->cl_call)(rh, proc, xargs, \
143  argsp, xres, resp, secs))
144 #define clnt_call(rh, proc, xargs, argsp, xres, resp, secs) \
145  ((*(rh)->cl_ops->cl_call)(rh, proc, xargs, \
146  argsp, xres, resp, secs))
147
148 /*
149  * void
150  * CLNT_ABORT(rh);
151  * CLIENT *rh;
152  */
153 #define CLNT_ABORT(rh) ((*(rh)->cl_ops->cl_abort)(rh))
154 #define clnt_abort(rh) ((*(rh)->cl_ops->cl_abort)(rh))
155
156 /*
157  * struct rpc_err
158  * CLNT_GETERR(rh);
159  * CLIENT *rh;
160  */
161 #define CLNT_GETERR(rh,errp) ((*(rh)->cl_ops->cl_geterr)(rh, errp))
162 #define clnt_geterr(rh,errp) ((*(rh)->cl_ops->cl_geterr)(rh, errp))
163
164
165 /*
166  * bool_t
167  * CLNT_FREERES(rh, xres, resp);
168  * CLIENT *rh;
169  * xdrproc_t xres;
170  * void *resp;
171  */
172 #define CLNT_FREERES(rh,xres,resp) ((*(rh)->cl_ops->cl_freeres)(rh,xres,resp))
173 #define clnt_freeres(rh,xres,resp) ((*(rh)->cl_ops->cl_freeres)(rh,xres,resp))
174
175 /*
176  * bool_t
177  * CLNT_CONTROL(cl, request, info)
178  * CLIENT *cl;
179  * u_int request;
180  * char *info;
181  */
182 #define CLNT_CONTROL(cl,rq,in) ((*(cl)->cl_ops->cl_control)(cl,rq,in))
183 #define clnt_control(cl,rq,in) ((*(cl)->cl_ops->cl_control)(cl,rq,in))
184
185 /*
186  * control operations that apply to udp, tcp and unix transports
187  *
188  * Note: options marked XXX are no-ops in this implementation of RPC.
189  * The are present in TI-RPC but can't be implemented here since they
190  * depend on the presence of STREAMS/TLI, which we don't have.
191  *
192  */
193 #define CLSET_TIMEOUT 1 /* set timeout (timeval) */
194 #define CLGET_TIMEOUT 2 /* get timeout (timeval) */
195 #define CLGET_SERVER_ADDR 3 /* get server's address (sockaddr) */
196 #define CLGET_FD 6 /* get connections file descriptor */
197 #define CLGET_SVC_ADDR 7 /* get server's address (netbuf) */
198 #define CLSET_FD_CLOSE 8 /* close fd while clnt_destroy */
199 #define CLSET_FD_NCLOSE 9 /* Do not close fd while clnt_destroy */
200 #define CLGET_XID 10 /* Get xid */
201 #define CLSET_XID 11 /* Set xid */
202 #define CLGET_VERS 12 /* Get version number */
203 #define CLSET_VERS 13 /* Set version number */
204 #define CLGET_PROG 14 /* Get program number */
205 #define CLSET_PROG 15 /* Set program number */
206 #define CLSET_SVC_ADDR 16 /* get server's address (netbuf) XXX */
207 #define CLSET_PUSH_TIMOD 17 /* push timod if not already present XXX */
208 #define CLSET_POP_TIMOD 18 /* pop timod XXX */
209
210 /*
211  * Connectionless only control operations
212  */
213 #define CLSET_RETRY_TIMEOUT 4 /* set retry timeout (timeval) */
214 #define CLGET_RETRY_TIMEOUT 5 /* get retry timeout (timeval) */
215
216 /*
217  * Operations which GSSAPI needs. (Bletch.)
218  */
219 #define CLGET_LOCAL_ADDR 19 /* get local addr (sockaddr) */
220
221
222 /*
223  * void
224  * CLNT_DESTROY(rh);
225  * CLIENT *rh;
226  */
227 #define CLNT_DESTROY(rh) ((*(rh)->cl_ops->cl_destroy)(rh))
228 #define clnt_destroy(rh) ((*(rh)->cl_ops->cl_destroy)(rh))
229
230
231 /*
232  * RPCTEST is a test program which is accessible on every rpc
233  * transport/port. It is used for testing, performance evaluation,
234  * and network administration.
235  */
236
237 #define RPCTEST_PROGRAM ((rpcprog_t)1)
238 #define RPCTEST_VERSION ((rpcvers_t)1)
239 #define RPCTEST_NULL_PROC ((rpcproc_t)2)
240 #define RPCTEST_NULL_BATCH_PROC ((rpcproc_t)3)
241
242 /*
243  * By convention, procedure 0 takes null arguments and returns them
244  */
245
246 #define NULLPROC ((rpcproc_t)0)
247
248 /*
249  * Below are the client handle creation routines for the various
250  * implementations of client side rpc. They can return NULL if a
251  * creation failure occurs.
252  */
253
254 /*
255  * Generic client creation routine. Supported protocols are "udp", "tcp"
256  * and "unix".
257  */
258 __BEGIN_DECLS
259 extern CLIENT *clnt_create(const char *, const rpcprog_t, const rpcvers_t,
260  const char *);
261 __END_DECLS
262
263 /*
264  * Added for compatibility to old rpc 4.0. Obsoleted by clnt_vc_create().
265  */
266 __BEGIN_DECLS
267 extern CLIENT *clntunix_create(struct sockaddr_un *,
268  u_long, u_long, int *, u_int, u_int);
269 __END_DECLS
270
271
272 /*
273  * Print why creation failed
274  */
275 __BEGIN_DECLS
276 extern void clnt_pcreateerror(const char *); /* stderr */
277 extern char *clnt_spcreateerror(const char *); /* string */
278 __END_DECLS
279
280 /*
281  * Like clnt_perror(), but is more verbose in its output
282  */
283 __BEGIN_DECLS
284 extern void clnt_perrno(enum clnt_stat); /* stderr */
285 extern char *clnt_sperrno(enum clnt_stat); /* string */
286 __END_DECLS
287
288 /*
289  * Print an English error message, given the client error code
290  */
291 __BEGIN_DECLS
292 extern void clnt_perror(CLIENT *, const char *); /* stderr */
293 extern char *clnt_sperror(CLIENT *, const char *); /* string */
294 __END_DECLS
295
296
297 /*
298  * If a creation fails, the following allows the user to figure out why.
299  */
300 struct rpc_createerr {
301  enum clnt_stat cf_stat;
302  struct rpc_err cf_error; /* useful when cf_stat == RPC_PMAPFAILURE */
303 };
304
305 extern struct rpc_createerr rpc_createerr;
306
307 /* For backward compatibility */
308 #include <rpc/clnt_soc.h>
309
310 #endif /* !_RPC_CLNT_H_ */
Definition: clnt.h:100
Definition: un.h:49
Definition: clnt.h:98
Definition: clnt.h:72
