rtems_id | __gnat_binary_semaphore_create (void) |
int | __gnat_binary_semaphore_delete (rtems_id semaphore) |
int | __gnat_binary_semaphore_obtain (rtems_id semaphore) |
int | __gnat_binary_semaphore_release (rtems_id semaphore) |
int | __gnat_binary_semaphore_flush (rtems_id semaphore) |
void * | set_vector (void *, rtems_vector_number, int) |
int | __gnat_interrupt_connect (int vector, ISRHandler handler, void *parameter) |
int | __gnat_interrupt_set (int vector, ISRHandler handler) |
ISRHandler | __gnat_interrupt_get (int vector) |
int | __gnat_interrupt_number_to_vector (int intNum) |
