#define | ZLIB_INTERNAL |
#define | local static |
#define | ERR_MSG(err) z_errmsg[Z_NEED_DICT-(err)] |
#define | ERR_RETURN(strm, err) return (strm->msg = (char*)ERR_MSG(err), (err)) |
#define | DEF_WBITS MAX_WBITS |
#define | DEF_MEM_LEVEL MAX_MEM_LEVEL |
#define | STORED_BLOCK 0 |
#define | STATIC_TREES 1 |
#define | DYN_TREES 2 |
#define | MIN_MATCH 3 |
#define | MAX_MATCH 258 |
#define | PRESET_DICT 0x20 /* preset dictionary flag in zlib header */ |
#define | OS_CODE 0x03 /* assume Unix */ |
#define | F_OPEN(name, mode) fopen((name), (mode)) |
#define | Assert(cond, msg) |
#define | Trace(x) |
#define | Tracev(x) |
#define | Tracevv(x) |
#define | Tracec(c, x) |
#define | Tracecv(c, x) |
#define | ZALLOC(strm, items, size) (*((strm)->zalloc))((strm)->opaque, (items), (size)) |
#define | ZFREE(strm, addr) (*((strm)->zfree))((strm)->opaque, (voidpf)(addr)) |
#define | TRY_FREE(s, p) {if (p) ZFREE(s, p);} |
typedef unsigned char | uch |
typedef uch FAR | uchf |
typedef unsigned short | ush |
typedef ush FAR | ushf |
typedef unsigned long | ulg |
ZEXTERN uLong ZEXPORT adler32_combine64 | OF ((uLong, uLong, z_off_t)) |
void ZLIB_INTERNAL zmemcpy | OF ((Bytef *dest, const Bytef *source, uInt len)) |
int ZLIB_INTERNAL zmemcmp | OF ((const Bytef *s1, const Bytef *s2, uInt len)) |
void ZLIB_INTERNAL zmemzero | OF ((Bytef *dest, uInt len)) |
voidpf ZLIB_INTERNAL zcalloc | OF ((voidpf opaque, unsigned items, unsigned size)) |
void ZLIB_INTERNAL zcfree | OF ((voidpf opaque, voidpf ptr)) |
const char *const | z_errmsg [10] |
