ypclnt.h
1 /*
2  * Copyright (c) 1992/3 Theo de Raadt <deraadt@fsa.ca>
3  * All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 3. The name of the author may not be used to endorse or promote
14  * products derived from this software without specific prior written
15  * permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS
18  * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
19  * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY
21  * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * $FreeBSD: src/include/rpcsvc/ypclnt.h,v 1.11 1999/08/27 23:45:12 peter Exp $
30  */
31
32 #ifndef _RPCSVC_YPCLNT_H_
33 #define _RPCSVC_YPCLNT_H_
34
35 #include <sys/cdefs.h>
36
37 #define YPERR_BADARGS 1 /* args to function are bad */
38 #define YPERR_RPC 2 /* RPC failure */
39 #define YPERR_DOMAIN 3 /* can't bind to a server for domain */
40 #define YPERR_MAP 4 /* no such map in server's domain */
41 #define YPERR_KEY 5 /* no such key in map */
42 #define YPERR_YPERR 6 /* some internal YP server or client error */
43 #define YPERR_RESRC 7 /* local resource allocation failure */
44 #define YPERR_NOMORE 8 /* no more records in map database */
45 #define YPERR_PMAP 9 /* can't communicate with portmapper */
46 #define YPERR_YPBIND 10 /* can't communicate with ypbind */
47 #define YPERR_YPSERV 11 /* can't communicate with ypserv */
48 #define YPERR_NODOM 12 /* local domain name not set */
49 #define YPERR_BADDB 13 /* YP data base is bad */
50 #define YPERR_VERS 14 /* YP version mismatch */
51 #define YPERR_ACCESS 15 /* access violation */
52 #define YPERR_BUSY 16 /* database is busy */
53
54 /*
55  * Types of update operations
56  */
57 #define YPOP_CHANGE 1 /* change, do not add */
58 #define YPOP_INSERT 2 /* add, do not change */
59 #define YPOP_DELETE 3 /* delete this entry */
60 #define YPOP_STORE 4 /* add, or change */
61
62 struct ypall_callback {
63  /* return non-0 to stop getting called */
64  int (*foreach) (unsigned long, char *, int, char *, int, void *);
65  char *data; /* opaque pointer for use of callback fn */
66 };
67
68 struct dom_binding;
69
70 __BEGIN_DECLS
71 int yp_bind (char *dom);
72 int _yp_dobind (char *dom, struct dom_binding **ypdb);
73 void yp_unbind (char *dom);
74 int yp_get_default_domain (char **domp);
75 int yp_match (char *indomain, char *inmap,
76  const char *inkey, int inkeylen, char **outval,
77  int *outvallen);
78 int yp_first (char *indomain, char *inmap,
79  char **outkey, int *outkeylen, char **outval,
80  int *outvallen);
81 int yp_next (char *indomain, char *inmap,
82  char *inkey, int inkeylen, char **outkey,
83  int *outkeylen, char **outval, int *outvallen);
84 int yp_master (char *indomain, char *inmap, char **outname);
85 int yp_order (char *indomain, char *inmap, int *outorder);
86 int yp_all (char *indomain, char *inmap,
87  struct ypall_callback *incallback);
88 char * yperr_string (int incode);
89 char * ypbinderr_string (int incode);
90 int ypprot_err (unsigned int incode);
91 __END_DECLS
92
93 #endif /* _RPCSVC_YPCLNT_H_ */
Definition: yp_prot.h:200
Definition: ypclnt.h:63
