xdr.h
1 /* $NetBSD: xdr.h,v 1.19 2000/07/17 05:00:45 matt Exp $ */
2
3 /*
4  * Sun RPC is a product of Sun Microsystems, Inc. and is provided for
5  * unrestricted use provided that this legend is included on all tape
6  * media and as a part of the software program in whole or part. Users
7  * may copy or modify Sun RPC without charge, but are not authorized
8  * to license or distribute it to anyone else except as part of a product or
9  * program developed by the user.
10  *
11  * SUN RPC IS PROVIDED AS IS WITH NO WARRANTIES OF ANY KIND INCLUDING THE
12  * WARRANTIES OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR
13  * PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE OR TRADE PRACTICE.
14  *
15  * Sun RPC is provided with no support and without any obligation on the
16  * part of Sun Microsystems, Inc. to assist in its use, correction,
17  * modification or enhancement.
18  *
19  * SUN MICROSYSTEMS, INC. SHALL HAVE NO LIABILITY WITH RESPECT TO THE
20  * INFRINGEMENT OF COPYRIGHTS, TRADE SECRETS OR ANY PATENTS BY SUN RPC
21  * OR ANY PART THEREOF.
22  *
23  * In no event will Sun Microsystems, Inc. be liable for any lost revenue
24  * or profits or other special, indirect and consequential damages, even if
25  * Sun has been advised of the possibility of such damages.
26  *
27  * Sun Microsystems, Inc.
28  * 2550 Garcia Avenue
29  * Mountain View, California 94043
30  *
31  * from: @(#)xdr.h 1.19 87/04/22 SMI
32  * from: @(#)xdr.h 2.2 88/07/29 4.0 RPCSRC
33  * $FreeBSD: src/include/rpc/xdr.h,v 1.23 2003/03/07 13:19:40 nectar Exp $
34  */
35
36 /*
37  * xdr.h, External Data Representation Serialization Routines.
38  *
39  * Copyright (C) 1984, Sun Microsystems, Inc.
40  */
41
42 #ifndef _RPC_XDR_H
43 #define _RPC_XDR_H
44
45 #include <sys/cdefs.h>
46
47 #include <rpc/types.h>
48
49 /*
50  * XDR provides a conventional way for converting between C data
51  * types and an external bit-string representation. Library supplied
52  * routines provide for the conversion on built-in C data types. These
53  * routines and utility routines defined here are used to help implement
54  * a type encode/decode routine for each user-defined type.
55  *
56  * Each data type provides a single procedure which takes two arguments:
57  *
58  * bool_t
59  * xdrproc(xdrs, argresp)
60  * XDR *xdrs;
61  * <type> *argresp;
62  *
63  * xdrs is an instance of a XDR handle, to which or from which the data
64  * type is to be converted. argresp is a pointer to the structure to be
65  * converted. The XDR handle contains an operation field which indicates
66  * which of the operations (ENCODE, DECODE * or FREE) is to be performed.
67  *
68  * XDR_DECODE may allocate space if the pointer argresp is null. This
69  * data can be freed with the XDR_FREE operation.
70  *
71  * We write only one procedure per data type to make it easy
72  * to keep the encode and decode procedures for a data type consistent.
73  * In many cases the same code performs all operations on a user defined type,
74  * because all the hard work is done in the component type routines.
75  * decode as a series of calls on the nested data types.
76  */
77
78 /*
79  * Xdr operations. XDR_ENCODE causes the type to be encoded into the
80  * stream. XDR_DECODE causes the type to be extracted from the stream.
81  * XDR_FREE can be used to release the space allocated by an XDR_DECODE
82  * request.
83  */
84 enum xdr_op {
85  XDR_ENCODE=0,
86  XDR_DECODE=1,
87  XDR_FREE=2
88 };
89
90 /*
91  * This is the number of bytes per unit of external data.
92  */
93 #define BYTES_PER_XDR_UNIT (4)
94 #define RNDUP(x) ((((x) + BYTES_PER_XDR_UNIT - 1) / BYTES_PER_XDR_UNIT) \
95  * BYTES_PER_XDR_UNIT)
96
97 /*
98  * The XDR handle.
99  * Contains operation which is being applied to the stream,
100  * an operations vector for the particular implementation (e.g. see xdr_mem.c),
101  * and two private fields for the use of the particular implementation.
102  */
103 typedef struct __rpc_xdr {
104  enum xdr_op x_op; /* operation; fast additional param */
105  const struct xdr_ops {
106  /* get a long from underlying stream */
107  bool_t (*x_getlong)(struct __rpc_xdr *, long *);
108  /* put a long to " */
109  bool_t (*x_putlong)(struct __rpc_xdr *, const long *);
110  /* get some bytes from " */
111  bool_t (*x_getbytes)(struct __rpc_xdr *, char *, u_int);
112  /* put some bytes to " */
113  bool_t (*x_putbytes)(struct __rpc_xdr *, const char *, u_int);
114  /* returns bytes off from beginning */
115  u_int (*x_getpostn)(struct __rpc_xdr *);
116  /* lets you reposition the stream */
117  bool_t (*x_setpostn)(struct __rpc_xdr *, u_int);
118  /* buf quick ptr to buffered data */
119  int32_t *(*x_inline)(struct __rpc_xdr *, u_int);
120  /* free privates of this xdr_stream */
121  void (*x_destroy)(struct __rpc_xdr *);
122  } *x_ops;
123  char * x_public; /* users' data */
124  void * x_private; /* pointer to private data */
125  char * x_base; /* private used for position info */
126  u_int x_handy; /* extra private word */
127 } XDR;
128
129 /*
130  * A xdrproc_t exists for each data type which is to be encoded or decoded.
131  *
132  * The second argument to the xdrproc_t is a pointer to an opaque pointer.
133  * The opaque pointer generally points to a structure of the data type
134  * to be decoded. If this pointer is 0, then the type routines should
135  * allocate dynamic storage of the appropriate size and return it.
136  */
137 typedef bool_t (*xdrproc_t) (XDR *, void *, ...);
138
139 /*
140  * Operations defined on a XDR handle
141  *
142  * XDR *xdrs;
143  * long *longp;
144  * caddr_t addr;
145  * u_int len;
146  * u_int pos;
147  */
148 #define XDR_GETLONG(xdrs, longp) \
149  (*(xdrs)->x_ops->x_getlong)(xdrs, longp)
150 #define xdr_getlong(xdrs, longp) \
151  (*(xdrs)->x_ops->x_getlong)(xdrs, longp)
152
153 #define XDR_PUTLONG(xdrs, longp) \
154  (*(xdrs)->x_ops->x_putlong)(xdrs, longp)
155 #define xdr_putlong(xdrs, longp) \
156  (*(xdrs)->x_ops->x_putlong)(xdrs, longp)
157
158 #define XDR_GETBYTES(xdrs, addr, len) \
159  (*(xdrs)->x_ops->x_getbytes)(xdrs, addr, len)
160 #define xdr_getbytes(xdrs, addr, len) \
161  (*(xdrs)->x_ops->x_getbytes)(xdrs, addr, len)
162
163 #define XDR_PUTBYTES(xdrs, addr, len) \
164  (*(xdrs)->x_ops->x_putbytes)(xdrs, addr, len)
165 #define xdr_putbytes(xdrs, addr, len) \
166  (*(xdrs)->x_ops->x_putbytes)(xdrs, addr, len)
167
168 #define XDR_GETPOS(xdrs) \
169  (*(xdrs)->x_ops->x_getpostn)(xdrs)
170 #define xdr_getpos(xdrs) \
171  (*(xdrs)->x_ops->x_getpostn)(xdrs)
172
173 #define XDR_SETPOS(xdrs, pos) \
174  (*(xdrs)->x_ops->x_setpostn)(xdrs, pos)
175 #define xdr_setpos(xdrs, pos) \
176  (*(xdrs)->x_ops->x_setpostn)(xdrs, pos)
177
178 #define XDR_INLINE(xdrs, len) \
179  (*(xdrs)->x_ops->x_inline)(xdrs, len)
180 #define xdr_inline(xdrs, len) \
181  (*(xdrs)->x_ops->x_inline)(xdrs, len)
182
183 #define XDR_DESTROY(xdrs) \
184  if ((xdrs)->x_ops->x_destroy) \
185  (*(xdrs)->x_ops->x_destroy)(xdrs)
186 #define xdr_destroy(xdrs) \
187  if ((xdrs)->x_ops->x_destroy) \
188  (*(xdrs)->x_ops->x_destroy)(xdrs)
189
190 /*
191  * Support struct for discriminated unions.
192  * You create an array of xdrdiscrim structures, terminated with
193  * an entry with a null procedure pointer. The xdr_union routine gets
194  * the discriminant value and then searches the array of structures
195  * for a matching value. If a match is found the associated xdr routine
196  * is called to handle that part of the union. If there is
197  * no match, then a default routine may be called.
198  * If there is no match and no default routine it is an error.
199  */
200 #define NULL_xdrproc_t ((xdrproc_t)0)
201 struct xdr_discrim {
202  int value;
203  xdrproc_t proc;
204 };
205
206 /*
207  * In-line routines for fast encode/decode of primitive data types.
208  * Caveat emptor: these use single memory cycles to get the
209  * data from the underlying buffer, and will fail to operate
210  * properly if the data is not aligned. The standard way to use these
211  * is to say:
212  * if ((buf = XDR_INLINE(xdrs, count)) == NULL)
213  * return (FALSE);
214  * <<< macro calls >>>
215  * where ``count'' is the number of bytes of data occupied
216  * by the primitive data types.
217  *
218  * N.B. and frozen for all time: each data type here uses 4 bytes
219  * of external representation.
220  */
221 #define IXDR_GET_LONG(buf) ((long)ntohl((u_long)*(buf)++))
222 #define IXDR_PUT_LONG(buf, v) (*(buf)++ = (long)htonl((u_long)v))
223
224 #define IXDR_GET_BOOL(buf) ((bool_t)IXDR_GET_LONG(buf))
225 #define IXDR_GET_ENUM(buf, t) ((t)IXDR_GET_LONG(buf))
226 #define IXDR_GET_U_LONG(buf) ((u_long)IXDR_GET_LONG(buf))
227 #define IXDR_GET_SHORT(buf) ((short)IXDR_GET_LONG(buf))
228 #define IXDR_GET_U_SHORT(buf) ((u_short)IXDR_GET_LONG(buf))
229
230 #define IXDR_PUT_BOOL(buf, v) IXDR_PUT_LONG((buf), ((long)(v)))
231 #define IXDR_PUT_ENUM(buf, v) IXDR_PUT_LONG((buf), ((long)(v)))
232 #define IXDR_PUT_U_LONG(buf, v) IXDR_PUT_LONG((buf), ((long)(v)))
233 #define IXDR_PUT_SHORT(buf, v) IXDR_PUT_LONG((buf), ((long)(v)))
234 #define IXDR_PUT_U_SHORT(buf, v) IXDR_PUT_LONG((buf), ((long)(v)))
235
236 /*
237  * These are the "generic" xdr routines.
238  */
239 __BEGIN_DECLS
240 extern bool_t xdr_void(void);
241 extern bool_t xdr_int(XDR *, int *);
242 extern bool_t xdr_u_int(XDR *, u_int *);
243 extern bool_t xdr_long(XDR *, long *);
244 extern bool_t xdr_u_long(XDR *, u_long *);
245 extern bool_t xdr_short(XDR *, short *);
246 extern bool_t xdr_u_short(XDR *, u_short *);
247 extern bool_t xdr_int16_t(XDR *, int16_t *);
248 extern bool_t xdr_u_int16_t(XDR *, u_int16_t *);
249 extern bool_t xdr_int32_t(XDR *, int32_t *);
250 extern bool_t xdr_u_int32_t(XDR *, u_int32_t *);
251 extern bool_t xdr_int64_t(XDR *, int64_t *);
252 extern bool_t xdr_u_int64_t(XDR *, u_int64_t *);
253 extern bool_t xdr_bool(XDR *, bool_t *);
254 extern bool_t xdr_enum(XDR *, enum_t *);
255 extern bool_t xdr_array(XDR *, char **, u_int *, u_int, u_int, xdrproc_t);
256 extern bool_t xdr_bytes(XDR *, char **, u_int *, u_int);
257 extern bool_t xdr_opaque(XDR *, caddr_t, u_int);
258 extern bool_t xdr_string(XDR *, char **, u_int);
259 extern bool_t xdr_union(XDR *, enum_t *, char *, const struct xdr_discrim *, xdrproc_t);
260 extern unsigned long xdr_sizeof (xdrproc_t, void *);
261 extern bool_t xdr_char(XDR *, char *);
262 extern bool_t xdr_u_char(XDR *, u_char *);
263 extern bool_t xdr_vector(XDR *, char *, u_int, u_int, xdrproc_t);
264 extern bool_t xdr_float(XDR *, float *);
265 extern bool_t xdr_double(XDR *, double *);
266 extern bool_t xdr_reference(XDR *, caddr_t *, u_int, xdrproc_t);
267 extern bool_t xdr_pointer(XDR *, caddr_t *, u_int, xdrproc_t);
268 extern bool_t xdr_wrapstring(XDR *, char **);
269 extern void xdr_free(xdrproc_t, char *);
270 __END_DECLS
271
272 /*
273  * Common opaque bytes objects used by many rpc protocols;
274  * declared here due to commonality.
275  */
276 #define MAX_NETOBJ_SZ 1024
277 struct netobj {
278  u_int n_len;
279  char *n_bytes;
280 };
281 typedef struct netobj netobj;
282 extern bool_t xdr_netobj(XDR *, struct netobj *);
283
284 /*
285  * These are the public routines for the various implementations of
286  * xdr streams.
287  */
288 __BEGIN_DECLS
289 /* XDR using memory buffers */
290 extern void xdrmem_create(XDR *, char *, u_int, enum xdr_op);
291
292 /* XDR using stdio library */
293 #ifdef _STDIO_H_
294 extern void xdrstdio_create(XDR *, FILE *, enum xdr_op);
295 #endif
296
297 /* XDR pseudo records for tcp */
298 extern void xdrrec_create(XDR *, u_int, u_int, char *,
299  int (*) (caddr_t, caddr_t, int),
300  int (*) (caddr_t, caddr_t, int));
301
302 /* make end of xdr record */
303 extern bool_t xdrrec_endofrecord(XDR *, bool_t);
304
305 /* move to beginning of next record */
306 extern bool_t xdrrec_skiprecord(XDR *);
307
308 /* true if no more input */
309 extern bool_t xdrrec_eof(XDR *);
310 __END_DECLS
311
312 #endif /* !_RPC_XDR_H */
Definition: xdr.h:104
Definition: proc.h:5
Definition: xdr.h:106
Definition: xdr.h:202
