score
cpu
v850
score
v850.h
1
12
13
* COPYRIGHT (c) 1989-2012.
14
* On-Line Applications Research Corporation (OAR).
15
16
* The license and distribution terms for this file may be
17
* found in the file LICENSE in this distribution or at
18
* http://www.rtems.org/license/LICENSE.
19
20
21
#ifndef _RTEMS_SCORE_V850_H
22
#define _RTEMS_SCORE_V850_H
23
24
#ifdef __cplusplus
25
extern
"C"
26
#endif
27
28
29
* This file contains the information required to build
30
* RTEMS for a particular member of the NO CPU family.
31
* It does this by setting variables to indicate which
32
* implementation dependent features are present in a particular
33
* member of the family.
34
35
* This is a good place to list all the known CPU models
36
* that this port supports and which RTEMS CPU model they correspond
37
* to.
38
39
40
#if defined(rtems_multilib)
41
42
* Figure out all CPU Model Feature Flags based upon compiler
43
* predefines.
44
45
#define CPU_MODEL_NAME "rtems_multilib"
46
#define V850_HAS_FPU 0
47
#define V850_HAS_BYTE_SWAP_INSTRUCTION 0
48
49
#elif defined(__v850e2v3__)
50
#define CPU_MODEL_NAME "v850e2v3"
51
#define V850_HAS_FPU 1
52
#define V850_HAS_BYTE_SWAP_INSTRUCTION 1
53
54
#elif defined(__v850e2__)
55
#define CPU_MODEL_NAME "v850e2"
56
57
58
59
#elif defined(__v850es__)
60
#define CPU_MODEL_NAME "v850es"
61
62
63
64
#elif defined(__v850e1__)
65
#define CPU_MODEL_NAME "v850e1"
66
67
68
69
#elif defined(__v850e__)
70
#define CPU_MODEL_NAME "v850e"
71
72
73
74
#else
75
#define CPU_MODEL_NAME "v850"
76
77
78
79
#endif
80
81
82
* Define the name of the CPU family.
83
84
#define CPU_NAME "v850 CPU"
85
86
87
* Method to set the Program Status Word (PSW)
88
89
#define v850_set_psw( _psw ) \
90
__asm__ __volatile__( "ldsr %0, psw" : : "r" (_psw) )
91
92
93
* Method to obtain the Program Status Word (PSW)
94
95
#define v850_get_psw( _psw ) \
96
__asm__ __volatile__( "stsr psw, %0" : "=&r" (_psw) )
97
98
99
* Masks and bits in the Program Status Word (PSW)
100
101
#define V850_PSW_ZERO_MASK 0x01
102
#define V850_PSW_IS_ZERO 0x01
103
#define V850_PSW_IS_NOT 0x00
104
105
#define V850_PSW_SIGN_MASK 0x02
106
#define V850_PSW_SIGN_IS_NEGATIVE 0x02
107
#define V850_PSW_SIGN_IS_ZERO_OR_POSITIVE 0x00
108
109
#define V850_PSW_OVERFLOW_MASK 0x02
110
#define V850_PSW_OVERFLOW_OCCURRED 0x02
111
#define V850_PSW_OVERFLOW_DID_NOT_OCCUR 0x00
112
113
#define V850_PSW_CARRY_OR_BORROW_MASK 0x04
114
#define V850_PSW_CARRY_OR_BORROW_OCCURRED 0x04
115
#define V850_PSW_CARRY_OR_BORROW_DID_NOT_OCCUR 0x00
116
117
#define V850_PSW_SATURATION_MASK 0x10
118
#define V850_PSW_SATURATION_OCCURRED 0x10
119
#define V850_PSW_SATURATION_DID_NOT_OCCUR 0x00
120
121
#define V850_PSW_INTERRUPT_DISABLE_MASK 0x20
122
#define V850_PSW_INTERRUPT_DISABLE 0x20
123
#define V850_PSW_INTERRUPT_ENABLE 0x00
124
125
#define V850_PSW_EXCEPTION_IN_PROCESS_MASK 0x40
126
#define V850_PSW_EXCEPTION_IN_PROCESS 0x40
127
#define V850_PSW_EXCEPTION_NOT_IN_PROCESS 0x00
128
129
#define V850_PSW_NMI_IN_PROCESS_MASK 0x80
130
#define V850_PSW_NMI_IN_PROCESS 0x80
131
#define V850_PSW_NMI_NOT_IN_PROCESS 0x00
132
133
#ifdef __cplusplus
134
135
#endif
136
137
#endif
/* _RTEMS_SCORE_V850_H */
