utf8proc.h
1 /*
2  * Copyright (c) 2009 Public Software Group e. V., Berlin, Germany
3  *
4  * Permission is hereby granted, free of charge, to any person obtaining a
5  * copy of this software and associated documentation files (the "Software"),
6  * to deal in the Software without restriction, including without limitation
7  * the rights to use, copy, modify, merge, publish, distribute, sublicense,
8  * and/or sell copies of the Software, and to permit persons to whom the
9  * Software is furnished to do so, subject to the following conditions:
10  *
11  * The above copyright notice and this permission notice shall be included in
12  * all copies or substantial portions of the Software.
13  *
14  * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
15  * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
16  * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
17  * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
18  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
19  * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
20  * DEALINGS IN THE SOFTWARE.
21  */
22
23
24 /*
25  * File name: utf8proc.h
26  *
27  * Description:
28  * Header files for libutf8proc, which is a mapping tool for UTF-8 strings
29  * with following features:
30  * - decomposing and composing of strings
31  * - replacing compatibility characters with their equivalents
32  * - stripping of "default ignorable characters"
33  * like SOFT-HYPHEN or ZERO-WIDTH-SPACE
34  * - folding of certain characters for string comparison
35  * (e.g. HYPHEN U+2010 and MINUS U+2212 to ASCII "-")
36  * (see "LUMP" option)
37  * - optional rejection of strings containing non-assigned code points
38  * - stripping of control characters
39  * - stripping of character marks (accents, etc.)
40  * - transformation of LF, CRLF, CR and NEL to line-feed (LF)
41  * or to the unicode chararacters for paragraph separation (PS)
42  * or line separation (LS).
43  * - unicode case folding (for case insensitive string comparisons)
44  * - rejection of illegal UTF-8 data
45  * (i.e. UTF-8 encoded UTF-16 surrogates)
46  * - support for korean hangul characters
47  * Unicode Version 5.0.0 is supported.
48  */
49
50
51 #ifndef UTF8PROC_H
52 #define UTF8PROC_H
53
54
55 #include <stdlib.h>
56 #include <sys/types.h>
57 #ifdef _MSC_VER
58 typedef signed char int8_t;
59 typedef unsigned char uint8_t;
60 typedef short int16_t;
61 typedef unsigned short uint16_t;
62 typedef int int32_t;
63 #ifdef _WIN64
64 #define ssize_t __int64
65 #else
66 #define ssize_t int
67 #endif
68 typedef unsigned char bool;
69 enum {false, true};
70 #else
71 #include <stdbool.h>
72 #include <inttypes.h>
73 #endif
74 #include <limits.h>
75
76 #ifdef __cplusplus
77 extern "C" {
78 #endif
79
80 #ifndef SSIZE_MAX
81 #define SSIZE_MAX ((size_t)SIZE_MAX/2)
82 #endif
83
84 #define UTF8PROC_NULLTERM (1<<0)
85 #define UTF8PROC_STABLE (1<<1)
86 #define UTF8PROC_COMPAT (1<<2)
87 #define UTF8PROC_COMPOSE (1<<3)
88 #define UTF8PROC_DECOMPOSE (1<<4)
89 #define UTF8PROC_IGNORE (1<<5)
90 #define UTF8PROC_REJECTNA (1<<6)
91 #define UTF8PROC_NLF2LS (1<<7)
92 #define UTF8PROC_NLF2PS (1<<8)
93 #define UTF8PROC_NLF2LF (UTF8PROC_NLF2LS | UTF8PROC_NLF2PS)
94 #define UTF8PROC_STRIPCC (1<<9)
95 #define UTF8PROC_CASEFOLD (1<<10)
96 #define UTF8PROC_CHARBOUND (1<<11)
97 #define UTF8PROC_LUMP (1<<12)
98 #define UTF8PROC_STRIPMARK (1<<13)
99 /*
100  * Flags being regarded by several functions in the library:
101  * NULLTERM: The given UTF-8 input is NULL terminated.
102  * STABLE: Unicode Versioning Stability has to be respected.
103  * COMPAT: Compatiblity decomposition
104  * (i.e. formatting information is lost)
105  * COMPOSE: Return a result with composed characters.
106  * DECOMPOSE: Return a result with decomposed characters.
107  * IGNORE: Strip "default ignorable characters"
108  * REJECTNA: Return an error, if the input contains unassigned
109  * code points.
110  * NLF2LS: Indicating that NLF-sequences (LF, CRLF, CR, NEL) are
111  * representing a line break, and should be converted to the
112  * unicode character for line separation (LS).
113  * NLF2PS: Indicating that NLF-sequences are representing a paragraph
114  * break, and should be converted to the unicode character for
115  * paragraph separation (PS).
116  * NLF2LF: Indicating that the meaning of NLF-sequences is unknown.
117  * STRIPCC: Strips and/or convers control characters.
118  * NLF-sequences are transformed into space, except if one of
119  * the NLF2LS/PS/LF options is given.
120  * HorizontalTab (HT) and FormFeed (FF) are treated as a
121  * NLF-sequence in this case.
122  * All other control characters are simply removed.
123  * CASEFOLD: Performs unicode case folding, to be able to do a
124  * case-insensitive string comparison.
125  * CHARBOUND: Inserts 0xFF bytes at the beginning of each sequence which
126  * is representing a single grapheme cluster (see UAX#29).
127  * LUMP: Lumps certain characters together
128  * (e.g. HYPHEN U+2010 and MINUS U+2212 to ASCII "-").
129  * (See lump.txt for details.)
130  * If NLF2LF is set, this includes a transformation of
131  * paragraph and line separators to ASCII line-feed (LF).
132  * STRIPMARK: Strips all character markings
133  * (non-spacing, spacing and enclosing) (i.e. accents)
134  * NOTE: this option works only with COMPOSE or DECOMPOSE
135  */
136
137 #define UTF8PROC_ERROR_NOMEM -1
138 #define UTF8PROC_ERROR_OVERFLOW -2
139 #define UTF8PROC_ERROR_INVALIDUTF8 -3
140 #define UTF8PROC_ERROR_NOTASSIGNED -4
141 #define UTF8PROC_ERROR_INVALIDOPTS -5
142 /*
143  * Error codes being returned by almost all functions:
144  * ERROR_NOMEM: Memory could not be allocated.
145  * ERROR_OVERFLOW: The given string is too long to be processed.
146  * ERROR_INVALIDUTF8: The given string is not a legal UTF-8 string.
147  * ERROR_NOTASSIGNED: The REJECTNA flag was set,
148  * and an unassigned code point was found.
149  * ERROR_INVALIDOPTS: Invalid options have been used.
150  */
151
152 typedef int16_t utf8proc_propval_t;
153 typedef struct utf8proc_property_struct {
154  utf8proc_propval_t category;
155  utf8proc_propval_t combining_class;
156  utf8proc_propval_t bidi_class;
157  utf8proc_propval_t decomp_type;
158  const int32_t *decomp_mapping;
159  unsigned bidi_mirrored:1;
160  int32_t uppercase_mapping;
161  int32_t lowercase_mapping;
162  int32_t titlecase_mapping;
163  int32_t comb1st_index;
164  int32_t comb2nd_index;
165  unsigned comp_exclusion:1;
166  unsigned ignorable:1;
167  unsigned control_boundary:1;
168  unsigned extend:1;
169  const int32_t *casefold_mapping;
171
172 #define UTF8PROC_CATEGORY_LU 1
173 #define UTF8PROC_CATEGORY_LL 2
174 #define UTF8PROC_CATEGORY_LT 3
175 #define UTF8PROC_CATEGORY_LM 4
176 #define UTF8PROC_CATEGORY_LO 5
177 #define UTF8PROC_CATEGORY_MN 6
178 #define UTF8PROC_CATEGORY_MC 7
179 #define UTF8PROC_CATEGORY_ME 8
180 #define UTF8PROC_CATEGORY_ND 9
181 #define UTF8PROC_CATEGORY_NL 10
182 #define UTF8PROC_CATEGORY_NO 11
183 #define UTF8PROC_CATEGORY_PC 12
184 #define UTF8PROC_CATEGORY_PD 13
185 #define UTF8PROC_CATEGORY_PS 14
186 #define UTF8PROC_CATEGORY_PE 15
187 #define UTF8PROC_CATEGORY_PI 16
188 #define UTF8PROC_CATEGORY_PF 17
189 #define UTF8PROC_CATEGORY_PO 18
190 #define UTF8PROC_CATEGORY_SM 19
191 #define UTF8PROC_CATEGORY_SC 20
192 #define UTF8PROC_CATEGORY_SK 21
193 #define UTF8PROC_CATEGORY_SO 22
194 #define UTF8PROC_CATEGORY_ZS 23
195 #define UTF8PROC_CATEGORY_ZL 24
196 #define UTF8PROC_CATEGORY_ZP 25
197 #define UTF8PROC_CATEGORY_CC 26
198 #define UTF8PROC_CATEGORY_CF 27
199 #define UTF8PROC_CATEGORY_CS 28
200 #define UTF8PROC_CATEGORY_CO 29
201 #define UTF8PROC_CATEGORY_CN 30
202 #define UTF8PROC_BIDI_CLASS_L 1
203 #define UTF8PROC_BIDI_CLASS_LRE 2
204 #define UTF8PROC_BIDI_CLASS_LRO 3
205 #define UTF8PROC_BIDI_CLASS_R 4
206 #define UTF8PROC_BIDI_CLASS_AL 5
207 #define UTF8PROC_BIDI_CLASS_RLE 6
208 #define UTF8PROC_BIDI_CLASS_RLO 7
209 #define UTF8PROC_BIDI_CLASS_PDF 8
210 #define UTF8PROC_BIDI_CLASS_EN 9
211 #define UTF8PROC_BIDI_CLASS_ES 10
212 #define UTF8PROC_BIDI_CLASS_ET 11
213 #define UTF8PROC_BIDI_CLASS_AN 12
214 #define UTF8PROC_BIDI_CLASS_CS 13
215 #define UTF8PROC_BIDI_CLASS_NSM 14
216 #define UTF8PROC_BIDI_CLASS_BN 15
217 #define UTF8PROC_BIDI_CLASS_B 16
218 #define UTF8PROC_BIDI_CLASS_S 17
219 #define UTF8PROC_BIDI_CLASS_WS 18
220 #define UTF8PROC_BIDI_CLASS_ON 19
221 #define UTF8PROC_DECOMP_TYPE_FONT 1
222 #define UTF8PROC_DECOMP_TYPE_NOBREAK 2
223 #define UTF8PROC_DECOMP_TYPE_INITIAL 3
224 #define UTF8PROC_DECOMP_TYPE_MEDIAL 4
225 #define UTF8PROC_DECOMP_TYPE_FINAL 5
226 #define UTF8PROC_DECOMP_TYPE_ISOLATED 6
227 #define UTF8PROC_DECOMP_TYPE_CIRCLE 7
228 #define UTF8PROC_DECOMP_TYPE_SUPER 8
229 #define UTF8PROC_DECOMP_TYPE_SUB 9
230 #define UTF8PROC_DECOMP_TYPE_VERTICAL 10
231 #define UTF8PROC_DECOMP_TYPE_WIDE 11
232 #define UTF8PROC_DECOMP_TYPE_NARROW 12
233 #define UTF8PROC_DECOMP_TYPE_SMALL 13
234 #define UTF8PROC_DECOMP_TYPE_SQUARE 14
235 #define UTF8PROC_DECOMP_TYPE_FRACTION 15
236 #define UTF8PROC_DECOMP_TYPE_COMPAT 16
237
238 extern const int8_t utf8proc_utf8class[256];
239
240 const char *utf8proc_version(void);
241
242 const char *utf8proc_errmsg(ssize_t errcode);
243 /*
244  * Returns a static error string for the given error code.
245  */
246
247 ssize_t utf8proc_iterate(const uint8_t *str, ssize_t strlen, int32_t *dst);
248 /*
249  * Reads a single char from the UTF-8 sequence being pointed to by 'str'.
250  * The maximum number of bytes read is 'strlen', unless 'strlen' is
251  * negative.
252  * If a valid unicode char could be read, it is stored in the variable
253  * being pointed to by 'dst', otherwise that variable will be set to -1.
254  * In case of success the number of bytes read is returned, otherwise a
255  * negative error code is returned.
256  */
257
258 bool utf8proc_codepoint_valid(int32_t uc);
259 /*
260  * Returns 1, if the given unicode code-point is valid, otherwise 0.
261  */
262
263 ssize_t utf8proc_encode_char(int32_t uc, uint8_t *dst);
264 /*
265  * Encodes the unicode char with the code point 'uc' as an UTF-8 string in
266  * the byte array being pointed to by 'dst'. This array has to be at least
267  * 4 bytes long.
268  * In case of success the number of bytes written is returned,
269  * otherwise 0.
270  * This function does not check if 'uc' is a valid unicode code point.
271  */
272
273 const utf8proc_property_t *utf8proc_get_property(int32_t uc);
274 /*
275  * Returns a pointer to a (constant) struct containing information about
276  * the unicode char with the given code point 'uc'.
277  * If the character is not existent a pointer to a special struct is
278  * returned, where 'category' is a NULL pointer.
279  * WARNING: The parameter 'uc' has to be in the range of 0x0000 to
280  * 0x10FFFF, otherwise the program might crash!
281  */
282
283 ssize_t utf8proc_decompose_char(
284  int32_t uc, int32_t *dst, ssize_t bufsize,
285  int options, int *last_boundclass
286 );
287 /*
288  * Writes a decomposition of the unicode char 'uc' into the array being
289  * pointed to by 'dst'.
290  * Following flags in the 'options' field are regarded:
291  * REJECTNA: an unassigned unicode code point leads to an error
292  * IGNORE: "default ignorable" chars are stripped
293  * CASEFOLD: unicode casefolding is applied
294  * COMPAT: replace certain characters with their
295  * compatibility decomposition
296  * CHARBOUND: Inserts 0xFF bytes before each grapheme cluster
297  * LUMP: lumps certain different characters together
298  * STRIPMARK: removes all character marks
299  * The pointer 'last_boundclass' has to point to an integer variable which
300  * is storing the last character boundary class, if the CHARBOUND option
301  * is used.
302  * In case of success the number of chars written is returned,
303  * in case of an error, a negative error code is returned.
304  * If the number of written chars would be bigger than 'bufsize',
305  * the buffer (up to 'bufsize') has inpredictable data, and the needed
306  * buffer size is returned.
307  * WARNING: The parameter 'uc' has to be in the range of 0x0000 to
308  * 0x10FFFF, otherwise the program might crash!
309  */
310
311 ssize_t utf8proc_decompose(
312  const uint8_t *str, ssize_t strlen,
313  int32_t *buffer, ssize_t bufsize, int options
314 );
315 /*
316  * Does the same as 'utf8proc_decompose_char', but acts on a whole UTF-8
317  * string, and orders the decomposed sequences correctly.
318  * If the NULLTERM flag in 'options' is set, processing will be stopped,
319  * when a NULL byte is encounted, otherwise 'strlen' bytes are processed.
320  * The result in form of unicode code points is written into the buffer
321  * being pointed to by 'buffer', having the length of 'bufsize' entries.
322  * In case of success the number of chars written is returned,
323  * in case of an error, a negative error code is returned.
324  * If the number of written chars would be bigger than 'bufsize',
325  * the buffer (up to 'bufsize') has inpredictable data, and the needed
326  * buffer size is returned.
327  */
328
329 ssize_t utf8proc_reencode(int32_t *buffer, ssize_t length, int options);
330 /*
331  * Reencodes the sequence of unicode characters given by the pointer
332  * 'buffer' and 'length' as UTF-8.
333  * The result is stored in the same memory area where the data is read.
334  * Following flags in the 'options' field are regarded:
335  * NLF2LS: converts LF, CRLF, CR and NEL into LS
336  * NLF2PS: converts LF, CRLF, CR and NEL into PS
337  * NLF2LF: converts LF, CRLF, CR and NEL into LF
338  * STRIPCC: strips or converts all non-affected control characters
339  * COMPOSE: tries to combine decomposed characters into composite
340  * characters
341  * STABLE: prohibits combining characters which would violate
342  * the unicode versioning stability
343  * In case of success the length of the resulting UTF-8 string is
344  * returned, otherwise a negative error code is returned.
345  * WARNING: The amount of free space being pointed to by 'buffer', has to
346  * exceed the amount of the input data by one byte, and the
347  * entries of the array pointed to by 'str' have to be in the
348  * range of 0x0000 to 0x10FFFF, otherwise the program might
349  * crash!
350  */
351
352 ssize_t utf8proc_map(
353  const uint8_t *str, ssize_t strlen, uint8_t **dstptr, int options
354 );
355 /*
356  * Maps the given UTF-8 string being pointed to by 'str' to a new UTF-8
357  * string, which is allocated dynamically, and afterwards pointed to by
358  * the pointer being pointed to by 'dstptr'.
359  * If the NULLTERM flag in the 'options' field is set, the length is
360  * determined by a NULL terminator, otherwise the parameter 'strlen' is
361  * evaluated to determine the string length, but in any case the result
362  * will be NULL terminated (though it might contain NULL characters
363  * before). Other flags in the 'options' field are passed to the functions
364  * defined above, and regarded as described.
365  * In case of success the length of the new string is returned,
366  * otherwise a negative error code is returned.
367  * NOTICE: The memory of the new UTF-8 string will have been allocated with
368  * 'malloc', and has theirfore to be freed with 'free'.
369  */
370
371 uint8_t *utf8proc_NFD(const uint8_t *str);
372 uint8_t *utf8proc_NFC(const uint8_t *str);
373 uint8_t *utf8proc_NFKD(const uint8_t *str);
374 uint8_t *utf8proc_NFKC(const uint8_t *str);
375 /*
376  * Returns a pointer to newly allocated memory of a NFD, NFC, NFKD or NFKC
377  * normalized version of the null-terminated string 'str'.
378  */
379
380 #ifdef __cplusplus
381 }
382 #endif
383
384 #endif
385
Definition: utf8proc.h:154
