User Extension Handler API. More...
struct | User_extensions_Table |
User extension table. More... | |
struct | User_extensions_Switch_control |
Manages the switch callouts. More... | |
struct | User_extensions_Control |
Manages each user extension set. More... | |
Typedefs | |
typedef void | User_extensions_routine |
typedef bool(* | User_extensions_thread_create_extension) (Thread_Control *executing, Thread_Control *created) |
Task create extension. More... | |
typedef void(* | User_extensions_thread_delete_extension) (Thread_Control *executing, Thread_Control *deleted) |
Task delete extension. More... | |
typedef void(* | User_extensions_thread_start_extension) (Thread_Control *executing, Thread_Control *started) |
Task start extension. More... | |
typedef void(* | User_extensions_thread_restart_extension) (Thread_Control *executing, Thread_Control *restarted) |
Task restart extension. More... | |
typedef void(* | User_extensions_thread_switch_extension) (Thread_Control *executing, Thread_Control *heir) |
Task switch extension. More... | |
typedef void(* | User_extensions_thread_begin_extension) (Thread_Control *executing) |
Task begin extension. More... | |
typedef void(* | User_extensions_thread_exitted_extension) (Thread_Control *executing) |
Task exitted extension. More... | |
typedef void(* | User_extensions_fatal_extension) (Internal_errors_Source source, bool is_internal, Internal_errors_t code) |
Fatal error extension. More... | |
typedef void(* | User_extensions_thread_terminate_extension) (Thread_Control *terminated) |
Task termination extension. More... | |
