un.h
1 /*
2  * Copyright (c) 1982, 1986, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)un.h 8.3 (Berkeley) 2/19/95
30  * $FreeBSD: src/sys/sys/un.h,v 1.29 2005/04/13 00:01:46 mdodd Exp $
31  */
32
33
34 #ifndef _SYS_UN_H_
35 #define _SYS_UN_H_
36
37 #include <sys/cdefs.h>
38 #include <rtems/bsdnet/_types.h>
39
40 #ifndef _SA_FAMILY_T_DECLARED
41 typedef __sa_family_t sa_family_t;
42 #define _SA_FAMILY_T_DECLARED
43 #endif
44
45 /*
46  * Definitions for UNIX IPC domain.
47  */
48 struct sockaddr_un {
49  unsigned char sun_len; /* sockaddr len including null */
50  sa_family_t sun_family; /* AF_UNIX */
51  char sun_path[104]; /* path name (gag) */
52 };
53
54 #if __BSD_VISIBLE
55
56 /* Socket options. */
57 #define LOCAL_PEERCRED 0x001 /* retrieve peer credentials */
58 #define LOCAL_CREDS 0x002 /* pass credentials to receiver */
59 #define LOCAL_CONNWAIT 0x004 /* connects block until accepted */
60
61 #ifdef _KERNEL
62 struct mbuf;
63 struct socket;
64 struct sockopt;
65
66 #else /* !_KERNEL */
67
68 /* actual length of an initialized sockaddr_un */
69 #define SUN_LEN(su) \
70  (sizeof(*(su)) - sizeof((su)->sun_path) + strlen((su)->sun_path))
71
72 #endif /* _KERNEL */
73
74 #endif /* __BSD_VISIBLE */
75
76 #endif /* !_SYS_UN_H_ */
Definition: socketvar.h:49
Definition: un.h:49
Definition: mbuf.h:103
