udp_var.h
1 /*
2  * Copyright (c) 1982, 1986, 1989, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)udp_var.h 8.1 (Berkeley) 6/10/93
30  * $FreeBSD: src/sys/netinet/udp_var.h,v 1.29 2005/01/07 01:45:45 imp Exp $
31  */
32
33
34 #ifndef _NETINET_UDP_VAR_H_
35 #define _NETINET_UDP_VAR_H_
36
37 #include <netinet/ip_var.h> /* struct ipovly */
38 #include <netinet/udp.h> /* struct udphdr */
39
40 /*
41  * UDP kernel structures and variables.
42  */
43 struct udpiphdr {
44  struct ipovly ui_i; /* overlaid ip structure */
45  struct udphdr ui_u; /* udp header */
46 };
47 #define ui_next ui_i.ih_next
48 #define ui_prev ui_i.ih_prev
49 #define ui_x1 ui_i.ih_x1
50 #define ui_pr ui_i.ih_pr
51 #define ui_len ui_i.ih_len
52 #define ui_src ui_i.ih_src
53 #define ui_dst ui_i.ih_dst
54 #define ui_sport ui_u.uh_sport
55 #define ui_dport ui_u.uh_dport
56 #define ui_ulen ui_u.uh_ulen
57 #define ui_sum ui_u.uh_sum
58
59 struct udpstat {
60  /* input statistics: */
61  u_long udps_ipackets; /* total input packets */
62  u_long udps_hdrops; /* packet shorter than header */
63  u_long udps_badsum; /* checksum error */
64  u_long udps_badlen; /* data length larger than packet */
65  u_long udps_noport; /* no socket on port */
66  u_long udps_noportbcast; /* of above, arrived as broadcast */
67  u_long udps_fullsock; /* not delivered, input socket full */
68  u_long udpps_pcbcachemiss; /* input packets missing pcb cache */
69  u_long udpps_pcbhashmiss; /* input packets not for hashed pcb */
70  /* output statistics: */
71  u_long udps_opackets; /* total output packets */
72 };
73
74 /*
75  * Names for UDP sysctl objects
76  */
77 #define UDPCTL_CHECKSUM 1 /* checksum UDP packets */
78 #define UDPCTL_STATS 2 /* statistics (read-only) */
79 #define UDPCTL_MAXDGRAM 3 /* max datagram size */
80 #define UDPCTL_RECVSPACE 4 /* default receive buffer space */
81 #define UDPCTL_PCBLIST 5 /* list of PCBs for UDP sockets */
82 #define UDPCTL_MAXID 6
83
84 #define UDPCTL_NAMES { \
85  { 0, 0 }, \
86  { "checksum", CTLTYPE_INT }, \
87  { "stats", CTLTYPE_STRUCT }, \
88  { "maxdgram", CTLTYPE_INT }, \
89  { "recvspace", CTLTYPE_INT }, \
90 }
91
92 #ifdef _KERNEL
93 SYSCTL_DECL(_net_inet_udp);
94
95 extern struct inpcbhead udb;
96 extern struct inpcbinfo udbinfo;
97 extern struct udpstat udpstat;
98
99 void udp_ctlinput(int, struct sockaddr *, void *);
100 void udp_init(void);
101 void udp_input(struct mbuf *, int);
102 int udp_usrreq(struct socket *,
103  int, struct mbuf *, struct mbuf *, struct mbuf *);
104 #endif
105
106 #endif
Definition: socketvar.h:49
Definition: udp.h:44
Definition: in_pcb.h:102
Definition: socket.h:180
Definition: ip_var.h:43
Definition: udp_var.h:44
Definition: mbuf.h:103
