tcp_var.h
1 /*
2  * Copyright (c) 1982, 1986, 1993, 1994, 1995
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)tcp_var.h 8.4 (Berkeley) 5/24/95
30  * $FreeBSD: src/sys/netinet/tcp_var.h,v 1.121 2005/04/21 20:11:01 ps Exp $
31  */
32
33 #ifndef _NETINET_TCP_VAR_H_
34 #define _NETINET_TCP_VAR_H_
35
36 #include <netinet/tcp.h>
37
38 /*
39  * Kernel variables for tcp.
40  */
41
42 #ifdef __BSD_VISIBLE
43 #include <netinet/tcp_timer.h> /* TCPT_NTIMERS */
44
45 /*
46  * Tcp control block, one per tcp; fields:
47  */
48 struct tcpcb {
49  struct tcpiphdr *seg_next; /* sequencing queue */
50  struct tcpiphdr *seg_prev;
51  int t_state; /* state of this connection */
52  u_int t_flags;
53 #define TF_ACKNOW 0x000001 /* ack peer immediately */
54 #define TF_DELACK 0x000002 /* ack, but try to delay it */
55 #define TF_NODELAY 0x000004 /* don't delay packets to coalesce */
56 #define TF_NOOPT 0x000008 /* don't use tcp options */
57 #define TF_SENTFIN 0x000010 /* have sent FIN */
58 #define TF_REQ_SCALE 0x000020 /* have/will request window scaling */
59 #define TF_RCVD_SCALE 0x000040 /* other side has requested scaling */
60 #define TF_REQ_TSTMP 0x000080 /* have/will request timestamps */
61 #define TF_RCVD_TSTMP 0x000100 /* a timestamp was received in SYN */
62 #define TF_SACK_PERMIT 0x000200 /* other side said I could SACK */
63 #define TF_NEEDSYN 0x000400 /* send SYN (implicit state) */
64 #define TF_NEEDFIN 0x000800 /* send FIN (implicit state) */
65 #define TF_NOPUSH 0x001000 /* don't push */
66 #define TF_REQ_CC 0x002000 /* have/will request CC */
67 #define TF_RCVD_CC 0x004000 /* a CC was received in SYN */
68 #define TF_SENDCCNEW 0x008000 /* send CCnew instead of CC in SYN */
69 #define TF_MORETOCOME 0x010000 /* More data to be appended to sock */
70 #define TF_LQ_OVERFLOW 0x020000 /* listen queue overflow */
71 #define TF_LASTIDLE 0x040000 /* connection was previously idle */
72 #define TF_RXWIN0SENT 0x080000 /* sent a receiver win 0 in response */
73 #define TF_FASTRECOVERY 0x100000 /* in NewReno Fast Recovery */
74 #define TF_WASFRECOVERY 0x200000 /* was in NewReno Fast Recovery */
75 #define TF_SIGNATURE 0x400000 /* require MD5 digests (RFC2385) */
76  int t_force; /* 1 if forcing out a byte */
77  int t_timer[TCPT_NTIMERS]; /* tcp timers */
78  int t_rxtshift; /* log(2) of rexmt exp. backoff */
79  int t_rxtcur; /* current retransmit value */
80  int t_dupacks; /* consecutive dup acks recd */
81  u_int t_maxseg; /* maximum segment size */
82  u_int t_maxopd; /* mss plus options */
83  struct tcpiphdr *t_template; /* skeletal packet for transmit */
84  struct inpcb *t_inpcb; /* back pointer to internet pcb */
85 /*
86  * The following fields are used as in the protocol specification.
87  * See RFC783, Dec. 1981, page 21.
88  */
89 /* send sequence variables */
90  tcp_seq snd_una; /* send unacknowledged */
91  tcp_seq snd_max; /* highest sequence number sent;
92  * used to recognize retransmits
93  */
94  tcp_seq snd_nxt; /* send next */
95  tcp_seq snd_up; /* send urgent pointer */
96
97  tcp_seq snd_wl1; /* window update seg seq number */
98  tcp_seq snd_wl2; /* window update seg ack number */
99  tcp_seq iss; /* initial send sequence number */
100  tcp_seq irs; /* initial receive sequence number */
101
102  tcp_seq rcv_nxt; /* receive next */
103  tcp_seq rcv_adv; /* advertised window */
104  u_long rcv_wnd; /* receive window */
105  tcp_seq rcv_up; /* receive urgent pointer */
106
107  u_long snd_wnd; /* send window */
108 /*
109  * Additional variables for this implementation.
110  */
111 /* congestion control (for slow start, source quench, retransmit after loss) */
112  u_long snd_cwnd; /* congestion-controlled window */
113  u_long snd_ssthresh; /* snd_cwnd size threshold for
114  * for slow start exponential to
115  * linear switch
116  */
117 /*
118  * transmit timing stuff. See below for scale of srtt and rttvar.
119  * "Variance" is actually smoothed difference.
120  */
121  u_int t_idle; /* inactivity time */
122  int t_rtt; /* round trip time */
123  tcp_seq t_rtseq; /* sequence number being timed */
124  int t_srtt; /* smoothed round-trip time */
125  int t_rttvar; /* variance in round-trip time */
126  u_int t_rttmin; /* minimum rtt allowed */
127  u_long max_sndwnd; /* largest window peer has offered */
128
129  int t_softerror; /* possible error not yet reported */
130 /* out-of-band data */
131  char t_oobflags; /* have some */
132  char t_iobc; /* input character */
133 #define TCPOOB_HAVEDATA 0x01
134 #define TCPOOB_HADDATA 0x02
135 /* RFC 1323 variables */
136  u_char snd_scale; /* window scaling for send window */
137  u_char rcv_scale; /* window scaling for recv window */
138  u_char request_r_scale; /* pending window scaling */
139  u_char requested_s_scale;
140  u_long ts_recent; /* timestamp echo data */
141
142  u_long ts_recent_age; /* when last updated */
143  tcp_seq last_ack_sent;
144 /* RFC 1644 variables */
145  tcp_cc cc_send; /* send connection count */
146  tcp_cc cc_recv; /* receive connection count */
147  u_long t_duration; /* connection duration */
148
149 /* TUBA stuff */
150  caddr_t t_tuba_pcb; /* next level down pcb for TCP over z */
151 /* More RTT stuff */
152  u_long t_rttupdated; /* number of times rtt sampled */
153 };
154
155 /*
156  * Structure to hold TCP options that are only used during segment
157  * processing (in tcp_input), but not held in the tcpcb.
158  * It's basically used to reduce the number of parameters
159  * to tcp_dooptions.
160  */
161 struct tcpopt {
162  u_long to_flags; /* which options are present */
163 #define TOF_TS 0x0001 /* timestamp */
164 #define TOF_CC 0x0002 /* CC and CCnew are exclusive */
165 #define TOF_CCNEW 0x0004
166 #define TOF_CCECHO 0x0008
167 #define TOF_MSS 0x0010
168 #define TOF_SCALE 0x0020
169 #define TOF_SIGNATURE 0x0040 /* signature option present */
170 #define TOF_SIGLEN 0x0080 /* signature length valid (RFC2385) */
171 #define TOF_SACK 0x0100 /* Peer sent SACK option */
172  u_int32_t to_tsval;
173  u_int32_t to_tsecr;
174  tcp_cc to_cc; /* holds CC or CCnew */
175  tcp_cc to_ccecho;
176 };
177
178 /*
179  * The TAO cache entry which is stored in the protocol family specific
180  * portion of the route metrics.
181  */
182 struct rmxp_tao {
183  tcp_cc tao_cc; /* latest CC in valid SYN */
184  tcp_cc tao_ccsent; /* latest CC sent to peer */
185  u_short tao_mssopt; /* peer's cached MSS */
186 };
187 #define rmx_taop(r) ((struct rmxp_tao *)(r).rmx_filler)
188
189 #define intotcpcb(ip) ((struct tcpcb *)(ip)->inp_ppcb)
190 #define intotw(ip) ((struct tcptw *)(ip)->inp_ppcb)
191 #define sototcpcb(so) (intotcpcb(sotoinpcb(so)))
192 #endif /* __BSD_VISIBLE */
193
194 /*
195  * The smoothed round-trip time and estimated variance
196  * are stored as fixed point numbers scaled by the values below.
197  * For convenience, these scales are also used in smoothing the average
198  * (smoothed = (1/scale)sample + ((scale-1)/scale)smoothed).
199  * With these scales, srtt has 3 bits to the right of the binary point,
200  * and thus an "ALPHA" of 0.875. rttvar has 2 bits to the right of the
201  * binary point, and is smoothed with an ALPHA of 0.75.
202  */
203 #define TCP_RTT_SCALE 32 /* multiplier for srtt; 3 bits frac. */
204 #define TCP_RTT_SHIFT 5 /* shift for srtt; 3 bits frac. */
205 #define TCP_RTTVAR_SCALE 16 /* multiplier for rttvar; 2 bits */
206 #define TCP_RTTVAR_SHIFT 4 /* shift for rttvar; 2 bits */
207 #define TCP_DELTA_SHIFT 2 /* see tcp_input.c */
208
209 /*
210  * The initial retransmission should happen at rtt + 4 * rttvar.
211  * Because of the way we do the smoothing, srtt and rttvar
212  * will each average +1/2 tick of bias. When we compute
213  * the retransmit timer, we want 1/2 tick of rounding and
214  * 1 extra tick because of +-1/2 tick uncertainty in the
215  * firing of the timer. The bias will give us exactly the
216  * 1.5 tick we need. But, because the bias is
217  * statistical, we have to test that we don't drop below
218  * the minimum feasible timer (which is 2 ticks).
219  * This version of the macro adapted from a paper by Lawrence
220  * Brakmo and Larry Peterson which outlines a problem caused
221  * by insufficient precision in the original implementation,
222  * which results in inappropriately large RTO values for very
223  * fast networks.
224  */
225 #define TCP_REXMTVAL(tp) \
226  ((((tp)->t_srtt >> (TCP_RTT_SHIFT - TCP_DELTA_SHIFT)) \
227  + (tp)->t_rttvar) >> TCP_DELTA_SHIFT)
228
229 /* XXX
230  * We want to avoid doing m_pullup on incoming packets but that
231  * means avoiding dtom on the tcp reassembly code. That in turn means
232  * keeping an mbuf pointer in the reassembly queue (since we might
233  * have a cluster). As a quick hack, the source & destination
234  * port numbers (which are no longer needed once we've located the
235  * tcpcb) are overlayed with an mbuf pointer.
236  */
237 #if (defined(__GNUC__) && (defined(__arm__) || defined(__mips__)))
238 #define STR32_UNALGN(ti,m) \
239  (ti)->ti_sport = (unsigned short)(((unsigned int) m & 0xffff0000) >> 16); \
240  (ti)->ti_dport = (unsigned short) ((unsigned int) m & 0x0000ffff);
241 #define LD32_UNALGN(ti,m) \
242  m = (struct mbuf *)((((unsigned int) (ti)->ti_sport) << 16) | ( (unsigned int)(ti)->ti_dport));
243
244 #else
245 #define REASS_MBUF(ti) (*(struct mbuf **)&((ti)->ti_t))
246 #endif
247
248 /*
249  * TCP statistics.
250  * Many of these should be kept per connection,
251  * but that's inconvenient at the moment.
252  */
253 struct tcpstat {
254  u_long tcps_connattempt; /* connections initiated */
255  u_long tcps_accepts; /* connections accepted */
256  u_long tcps_connects; /* connections established */
257  u_long tcps_drops; /* connections dropped */
258  u_long tcps_conndrops; /* embryonic connections dropped */
259  u_long tcps_closed; /* conn. closed (includes drops) */
260  u_long tcps_segstimed; /* segs where we tried to get rtt */
261  u_long tcps_rttupdated; /* times we succeeded */
262  u_long tcps_delack; /* delayed acks sent */
263  u_long tcps_timeoutdrop; /* conn. dropped in rxmt timeout */
264  u_long tcps_rexmttimeo; /* retransmit timeouts */
265  u_long tcps_persisttimeo; /* persist timeouts */
266  u_long tcps_keeptimeo; /* keepalive timeouts */
267  u_long tcps_keepprobe; /* keepalive probes sent */
268  u_long tcps_keepdrops; /* connections dropped in keepalive */
269
270  u_long tcps_sndtotal; /* total packets sent */
271  u_long tcps_sndpack; /* data packets sent */
272  u_long tcps_sndbyte; /* data bytes sent */
273  u_long tcps_sndrexmitpack; /* data packets retransmitted */
274  u_long tcps_sndrexmitbyte; /* data bytes retransmitted */
275  u_long tcps_sndacks; /* ack-only packets sent */
276  u_long tcps_sndprobe; /* window probes sent */
277  u_long tcps_sndurg; /* packets sent with URG only */
278  u_long tcps_sndwinup; /* window update-only packets sent */
279  u_long tcps_sndctrl; /* control (SYN|FIN|RST) packets sent */
280
281  u_long tcps_rcvtotal; /* total packets received */
282  u_long tcps_rcvpack; /* packets received in sequence */
283  u_long tcps_rcvbyte; /* bytes received in sequence */
284  u_long tcps_rcvbadsum; /* packets received with ccksum errs */
285  u_long tcps_rcvbadoff; /* packets received with bad offset */
286  u_long tcps_rcvshort; /* packets received too short */
287  u_long tcps_rcvduppack; /* duplicate-only packets received */
288  u_long tcps_rcvdupbyte; /* duplicate-only bytes received */
289  u_long tcps_rcvpartduppack; /* packets with some duplicate data */
290  u_long tcps_rcvpartdupbyte; /* dup. bytes in part-dup. packets */
291  u_long tcps_rcvoopack; /* out-of-order packets received */
292  u_long tcps_rcvoobyte; /* out-of-order bytes received */
293  u_long tcps_rcvpackafterwin; /* packets with data after window */
294  u_long tcps_rcvbyteafterwin; /* bytes rcvd after window */
295  u_long tcps_rcvafterclose; /* packets rcvd after "close" */
296  u_long tcps_rcvwinprobe; /* rcvd window probe packets */
297  u_long tcps_rcvdupack; /* rcvd duplicate acks */
298  u_long tcps_rcvacktoomuch; /* rcvd acks for unsent data */
299  u_long tcps_rcvackpack; /* rcvd ack packets */
300  u_long tcps_rcvackbyte; /* bytes acked by rcvd acks */
301  u_long tcps_rcvwinupd; /* rcvd window update packets */
302  u_long tcps_pawsdrop; /* segments dropped due to PAWS */
303  u_long tcps_predack; /* times hdr predict ok for acks */
304  u_long tcps_preddat; /* times hdr predict ok for data pkts */
305  u_long tcps_pcbcachemiss;
306  u_long tcps_cachedrtt; /* times cached RTT in route updated */
307  u_long tcps_cachedrttvar; /* times cached rttvar updated */
308  u_long tcps_cachedssthresh; /* times cached ssthresh updated */
309  u_long tcps_usedrtt; /* times RTT initialized from route */
310  u_long tcps_usedrttvar; /* times RTTVAR initialized from rt */
311  u_long tcps_usedssthresh; /* times ssthresh initialized from rt*/
312  u_long tcps_persistdrop; /* timeout in persist state */
313  u_long tcps_badsyn; /* bogus SYN, e.g. premature ACK */
314  u_long tcps_mturesent; /* resends due to MTU discovery */
315  u_long tcps_listendrop; /* listen queue overflows */
316 };
317
318 /*
319  * TCB structure exported to user-land via sysctl(3).
320  * Evil hack: declare only if in_pcb.h and sys/socketvar.h have been
321  * included. Not all of our clients do.
322  */
323 #if defined(_NETINET_IN_PCB_H_) && defined(_SYS_SOCKETVAR_H_)
324 struct xtcpcb {
325  size_t xt_len;
326  struct inpcb xt_inp;
327  struct tcpcb xt_tp;
328 #if 0
329  struct xsocket xt_socket;
330  u_quad_t xt_alignment_hack;
331 #endif
332 };
333 #endif
334
335 /*
336  * Names for TCP sysctl objects
337  */
338 #define TCPCTL_DO_RFC1323 1 /* use RFC-1323 extensions */
339 #define TCPCTL_DO_RFC1644 2 /* use RFC-1644 extensions */
340 #define TCPCTL_MSSDFLT 3 /* MSS default */
341 #define TCPCTL_STATS 4 /* statistics (read-only) */
342 #define TCPCTL_RTTDFLT 5 /* default RTT estimate */
343 #define TCPCTL_KEEPIDLE 6 /* keepalive idle timer */
344 #define TCPCTL_KEEPINTVL 7 /* interval to send keepalives */
345 #define TCPCTL_SENDSPACE 8 /* send buffer space */
346 #define TCPCTL_RECVSPACE 9 /* receive buffer space */
347 #define TCPCTL_KEEPINIT 10 /* timeout for establishing syn */
348 #define TCPCTL_PCBLIST 11 /* list of all outstanding PCBs */
349 #define TCPCTL_MAXID 12
350
351 #define TCPCTL_NAMES { \
352  { 0, 0 }, \
353  { "rfc1323", CTLTYPE_INT }, \
354  { "rfc1644", CTLTYPE_INT }, \
355  { "mssdflt", CTLTYPE_INT }, \
356  { "stats", CTLTYPE_STRUCT }, \
357  { "rttdflt", CTLTYPE_INT }, \
358  { "keepidle", CTLTYPE_INT }, \
359  { "keepintvl", CTLTYPE_INT }, \
360  { "sendspace", CTLTYPE_INT }, \
361  { "recvspace", CTLTYPE_INT }, \
362  { "keepinit", CTLTYPE_INT }, \
363 }
364
365 #ifdef _KERNEL
366 #ifdef SYSCTL_DECL
367 SYSCTL_DECL(_net_inet_tcp);
368 #endif
369
370 extern struct inpcbhead tcb; /* head of queue of active tcpcb's */
371 extern struct inpcbinfo tcbinfo;
372 extern struct tcpstat tcpstat; /* tcp statistics */
373 extern int tcp_mssdflt; /* XXX */
374 extern u_long tcp_now; /* for RFC 1323 timestamps */
375
376 void tcp_canceltimers(struct tcpcb *);
377 struct tcpcb *
378  tcp_close(struct tcpcb *);
379 void tcp_ctlinput(int, struct sockaddr *, void *);
380 int tcp_ctloutput(int, struct socket *, int, int, struct mbuf **);
381 struct tcpcb *
382  tcp_drop(struct tcpcb *, int);
383 void tcp_drain(void);
384 void tcp_fasttimo(void);
385 struct rmxp_tao *
386  tcp_gettaocache(struct inpcb *);
387 void tcp_init(void);
388 void tcp_input(struct mbuf *, int);
389 void tcp_mss(struct tcpcb *, int);
390 int tcp_mssopt(struct tcpcb *);
391 void tcp_mtudisc(struct inpcb *, int);
392 struct tcpcb *
393  tcp_newtcpcb(struct inpcb *);
394 int tcp_output(struct tcpcb *);
395 void tcp_quench(struct inpcb *, int);
396 void tcp_respond(struct tcpcb *,
397  struct tcpiphdr *, struct mbuf *, tcp_seq, tcp_seq, int);
398 struct rtentry *
399  tcp_rtlookup(struct inpcb *);
400 void tcp_setpersist(struct tcpcb *);
401 void tcp_slowtimo(void);
402 struct tcpiphdr *
403  tcp_template(struct tcpcb *);
404 struct tcpcb *
405  tcp_timers(struct tcpcb *, int);
406 void tcp_trace(short, short, struct tcpcb *, struct tcpiphdr *, int);
407
408 extern struct pr_usrreqs tcp_usrreqs;
409 extern u_long tcp_sendspace;
410 extern u_long tcp_recvspace;
411
412 #endif /* _KERNEL */
413
414 #endif /* _NETINET_TCP_VAR_H_ */
Definition: socketvar.h:49
Definition: in_pcb.h:53
Definition: in_pcb.h:102
Definition: socket.h:180
Definition: mbuf.h:103
Definition: route.h:104
