tcp_seq.h
1 /*
2  * Copyright (c) 1982, 1986, 1993, 1995
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)tcp_seq.h 8.3 (Berkeley) 6/21/95
30  * $FreeBSD: src/sys/netinet/tcp_seq.h,v 1.26 2006/06/18 14:24:12 andre Exp $
31  */
32
33
34 #ifndef _NETINET_TCP_SEQ_H_
35 #define _NETINET_TCP_SEQ_H_
36 /*
37  * TCP sequence numbers are 32 bit integers operated
38  * on with modular arithmetic. These macros can be
39  * used to compare such integers.
40  */
41 #define SEQ_LT(a,b) ((int)((a)-(b)) < 0)
42 #define SEQ_LEQ(a,b) ((int)((a)-(b)) <= 0)
43 #define SEQ_GT(a,b) ((int)((a)-(b)) > 0)
44 #define SEQ_GEQ(a,b) ((int)((a)-(b)) >= 0)
45
46 /* for modulo comparisons of timestamps */
47 #define TSTMP_LT(a,b) ((int)((a)-(b)) < 0)
48 #define TSTMP_GEQ(a,b) ((int)((a)-(b)) >= 0)
49
50 /*
51  * TCP connection counts are 32 bit integers operated
52  * on with modular arithmetic. These macros can be
53  * used to compare such integers.
54  */
55 #define CC_LT(a,b) ((int)((a)-(b)) < 0)
56 #define CC_LEQ(a,b) ((int)((a)-(b)) <= 0)
57 #define CC_GT(a,b) ((int)((a)-(b)) > 0)
58 #define CC_GEQ(a,b) ((int)((a)-(b)) >= 0)
59
60 /* Macro to increment a CC: skip 0 which has a special meaning */
61 #define CC_INC(c) (++(c) == 0 ? ++(c) : (c))
62
63 /*
64  * Macros to initialize tcp sequence numbers for
65  * send and receive from initial send and receive
66  * sequence numbers.
67  */
68 #define tcp_rcvseqinit(tp) \
69  (tp)->rcv_adv = (tp)->rcv_nxt = (tp)->irs + 1
70
71 #define tcp_sendseqinit(tp) \
72  (tp)->snd_una = (tp)->snd_nxt = (tp)->snd_max = (tp)->snd_up = \
73  (tp)->iss
74
75 #define TCP_PAWS_IDLE (uint32_t)(24L * 24L * 60L * 60L * PR_SLOWHZ)
76  /* timestamp wrap-around time */
77
78 #ifdef _KERNEL
79 extern tcp_cc tcp_ccgen; /* global connection count */
80
81 /*
82  * Increment for tcp_iss each second.
83  * This is designed to increment at the standard 250 KB/s,
84  * but with a random component averaging 128 KB.
85  * We also increment tcp_iss by a quarter of this amount
86  * each time we use the value for a new connection.
87  * If defined, the tcp_random18() macro should produce a
88  * number in the range [0-0x3ffff] that is hard to predict.
89  */
90 #ifndef tcp_random18
91 #define tcp_random18() (((uint32_t)random() >> 14) & 0x3ffffL)
92 #endif
93 #define TCP_ISSINCR (uint32_t)(122L*1024L + tcp_random18())
94
95 extern tcp_seq tcp_iss; /* tcp initial send seq # */
96 #else
97 #define TCP_ISSINCR (250*1024) /* increment for tcp_iss each second */
98 #endif /* _KERNEL */
99 #endif /* _NETINET_TCP_SEQ_H_ */
