libnetworking
netinet
tcp_debug.h
1
2
* Copyright (c) 1982, 1986, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
* 4. Neither the name of the University nor the names of its contributors
14
* may be used to endorse or promote products derived from this software
15
* without specific prior written permission.
16
17
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27
* SUCH DAMAGE.
28
29
* @(#)tcp_debug.h 8.1 (Berkeley) 6/10/93
30
* $FreeBSD: src/sys/netinet/tcp_debug.h,v 1.17 2009/02/13 15:14:43 luigi Exp $
31
32
33
34
#ifndef _NETINET_TCP_DEBUG_H_
35
#define _NETINET_TCP_DEBUG_H_
36
37
netinet/tcpip.h
/* struct tcpiphdr */
38
netinet/tcp_var.h
/* struct tcpcb */
39
40
struct
tcp_debug {
41
uint32_t td_time;
/* network format */
42
short
td_act;
43
short
td_ostate;
44
caddr_t td_tcb;
45
struct
tcpiphdr td_ti;
46
short
td_req;
47
struct
tcpcb td_cb;
48
49
50
#define TA_INPUT 0
51
#define TA_OUTPUT 1
52
#define TA_USER 2
53
#define TA_RESPOND 3
54
#define TA_DROP 4
55
56
#ifdef TANAMES
57
static
const
char
*tanames[] =
58
"input"
"output"
"user"
"respond"
"drop"
59
#endif
60
61
#define TCP_NDEBUG 100
62
63
#ifndef _KERNEL
64
/* XXX common variables for broken applications. */
65
struct
tcp_debug tcp_debug[TCP_NDEBUG];
66
int
tcp_debx;
67
#endif
68
69
#endif
/* !_NETINET_TCP_DEBUG_H_ */
tcpip.h
tcp_var.h
