Macros | Functions
syslog.h File Reference
#include <sys/cdefs.h>
#include <stdarg.h>
Include dependency graph for syslog.h:
#define _PATH_LOG   "/var/run/log"
#define _PATH_OLDLOG   "/dev/log" /* backward compatibility */
#define LOG_EMERG   0 /* system is unusable */
#define LOG_ALERT   1 /* action must be taken immediately */
#define LOG_CRIT   2 /* critical conditions */
#define LOG_ERR   3 /* error conditions */
#define LOG_WARNING   4 /* warning conditions */
#define LOG_NOTICE   5 /* normal but significant condition */
#define LOG_INFO   6 /* informational */
#define LOG_DEBUG   7 /* debug-level messages */
#define LOG_PRIMASK   0x07 /* mask to extract priority part (internal) */
#define LOG_PRI(p)   ((p) & LOG_PRIMASK)
#define LOG_MAKEPRI(fac, pri)   ((fac) | (pri))
#define LOG_KERN   (0<<3) /* kernel messages */
#define LOG_USER   (1<<3) /* random user-level messages */
#define LOG_MAIL   (2<<3) /* mail system */
#define LOG_DAEMON   (3<<3) /* system daemons */
#define LOG_AUTH   (4<<3) /* authorization messages */
#define LOG_SYSLOG   (5<<3) /* messages generated internally by syslogd */
#define LOG_LPR   (6<<3) /* line printer subsystem */
#define LOG_NEWS   (7<<3) /* network news subsystem */
#define LOG_UUCP   (8<<3) /* UUCP subsystem */
#define LOG_CRON   (9<<3) /* clock daemon */
#define LOG_AUTHPRIV   (10<<3) /* authorization messages (private) */
#define LOG_FTP   (11<<3) /* ftp daemon */
#define LOG_NTP   (12<<3) /* NTP subsystem */
#define LOG_LOCAL0   (16<<3) /* reserved for local use */
#define LOG_LOCAL1   (17<<3) /* reserved for local use */
#define LOG_LOCAL2   (18<<3) /* reserved for local use */
#define LOG_LOCAL3   (19<<3) /* reserved for local use */
#define LOG_LOCAL4   (20<<3) /* reserved for local use */
#define LOG_LOCAL5   (21<<3) /* reserved for local use */
#define LOG_LOCAL6   (22<<3) /* reserved for local use */
#define LOG_LOCAL7   (23<<3) /* reserved for local use */
#define LOG_NFACILITIES   24 /* current number of facilities */
#define LOG_FACMASK   0x03f8 /* mask to extract facility part */
#define LOG_FAC(p)   (((p) & LOG_FACMASK) >> 3)
#define LOG_MASK(pri)   (1 << (pri)) /* mask for one priority */
#define LOG_UPTO(pri)   ((1 << ((pri)+1)) - 1) /* all priorities through pri */
#define LOG_PID   0x01 /* log the pid with each message */
#define LOG_CONS   0x02 /* log on the console if errors in sending */
#define LOG_ODELAY   0x04 /* delay open until first syslog() (default) */
#define LOG_NDELAY   0x08 /* don't delay open */
#define LOG_NOWAIT   0x10 /* don't wait for console forks: DEPRECATED */
#define LOG_PERROR   0x20 /* log to stderr as well */
__BEGIN_DECLS void closelog (void)
void openlog (const char *, int, int)
int setlogmask (int)
void syslog (int, const char *,...)
void vsyslog (int, const char *, va_list)
