rtems_libi2c_bus_ops_ Struct Reference
rtems_status_code(* init )(rtems_libi2c_bus_t *bushdl)
rtems_status_code(* send_start )(rtems_libi2c_bus_t *bushdl)
rtems_status_code(* send_stop )(rtems_libi2c_bus_t *bushdl)
rtems_status_code(* send_addr )(rtems_libi2c_bus_t *bushdl, uint32_t addr, int rw)
int(* read_bytes )(rtems_libi2c_bus_t *bushdl, unsigned char *bytes, int nbytes)
int(* write_bytes )(rtems_libi2c_bus_t *bushdl, unsigned char *bytes, int nbytes)
int(* ioctl )(rtems_libi2c_bus_t *bushdl, int cmd, void *buffer)
