score
cpu
sparc64
score
sparc64.h
1
11
12
* COPYRIGHT (c) 1989-1999. On-Line Applications Research Corporation (OAR).
13
14
* This file is based on the SPARC sparc.h file. Modifications are made
15
* to support the SPARC64 processor.
16
* COPYRIGHT (c) 2010. Gedare Bloom.
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef _RTEMS_SCORE_SPARC_H
24
#define _RTEMS_SCORE_SPARC_H
25
26
#ifdef __cplusplus
27
extern
"C"
28
#endif
29
30
31
* This file contains the information required to build
32
* RTEMS for a particular member of the "sparc" family. It does
33
* this by setting variables to indicate which implementation
34
* dependent features are present in a particular member
35
* of the family.
36
37
* Currently recognized feature flags:
38
39
* + SPARC_HAS_FPU
40
* 0 - no HW FPU
41
* 1 - has HW FPU (assumed to be compatible w/90C602)
42
43
* + SPARC_HAS_BITSCAN
44
* 0 - does not have scan instructions
45
* 1 - has scan instruction (not currently implemented)
46
47
* + SPARC_NUMBER_OF_REGISTER_WINDOWS
48
* 8 is the most common number supported by SPARC implementations.
49
* SPARC_PSR_CWP_MASK is derived from this value.
50
51
52
53
* Some higher end SPARCs have a bitscan instructions. It would
54
* be nice to take advantage of them. Right now, there is no
55
* port to a CPU model with this feature and no (untested) code
56
* that is based on this feature flag.
57
58
59
#define SPARC_HAS_BITSCAN 0
60
61
62
* This should be OK until a port to a higher end SPARC processor
63
* is made that has more than 8 register windows. If this cannot
64
* be determined based on multilib settings (v7/v8/v9), then the
65
* cpu_asm.S code that depends on this will have to move to libcpu.
66
67
* SPARC v9 supports from 3 to 32 register windows.
68
* N_REG_WINDOWS = 8 on UltraSPARC T1 (impl. dep. #2-V8).
69
70
71
#define SPARC_NUMBER_OF_REGISTER_WINDOWS 8
72
73
74
* This should be determined based on some soft float derived
75
* cpp predefine but gcc does not currently give us that information.
76
77
78
79
#if defined(_SOFT_FLOAT)
80
#define SPARC_HAS_FPU 0
81
#else
82
#define SPARC_HAS_FPU 1
83
#endif
84
85
#if SPARC_HAS_FPU
86
#define CPU_MODEL_NAME "w/FPU"
87
#else
88
#define CPU_MODEL_NAME "w/soft-float"
89
#endif
90
91
92
* Define the name of the CPU family.
93
94
95
#define CPU_NAME "SPARC"
96
97
98
* Miscellaneous constants
99
100
101
102
* The PSR is deprecated and deleted.
103
104
* The following registers represent fields of the PSR:
105
* PIL - Processor Interrupt Level register
106
* CWP - Current Window Pointer register
107
* VER - Version register
108
* CCR - Condition Codes Register
109
* PSTATE - Processor State register
110
111
112
113
* PSTATE masks and starting bit positions
114
115
* NOTE: Reserved bits are ignored.
116
117
118
#define SPARC_PSTATE_AG_MASK 0x00000001
/* bit 0 */
119
#define SPARC_PSTATE_IE_MASK 0x00000002
/* bit 1 */
120
#define SPARC_PSTATE_PRIV_MASK 0x00000004
/* bit 2 */
121
#define SPARC_PSTATE_AM_MASK 0x00000008
/* bit 3 */
122
#define SPARC_PSTATE_PEF_MASK 0x00000010
/* bit 4 */
123
#define SPARC_PSTATE_MM_MASK 0x00000040
/* bit 6 */
124
#define SPARC_PSTATE_TLE_MASK 0x00000100
/* bit 8 */
125
#define SPARC_PSTATE_CLE_MASK 0x00000200
/* bit 9 */
126
127
#define SPARC_PSTATE_AG_BIT_POSITION 0
/* bit 0 */
128
#define SPARC_PSTATE_IE_BIT_POSITION 1
/* bit 1 */
129
#define SPARC_PSTATE_PRIV_BIT_POSITION 2
/* bit 2 */
130
#define SPARC_PSTATE_AM_BIT_POSITION 3
/* bit 3 */
131
#define SPARC_PSTATE_PEF_BIT_POSITION 4
/* bit 4 */
132
#define SPARC_PSTATE_MM_BIT_POSITION 6
/* bit 6 */
133
#define SPARC_PSTATE_TLE_BIT_POSITION 8
/* bit 8 */
134
#define SPARC_PSTATE_CLE_BIT_POSITION 9
/* bit 9 */
135
136
#define SPARC_FPRS_FEF_MASK 0x0100
/* bit 2 */
137
#define SPARC_FPRS_FEF_BIT_POSITION 2
/* bit 2 */
138
139
#define SPARC_TSTATE_IE_MASK 0x00000200
/* bit 9 */
140
141
#define SPARC_SOFTINT_TM_MASK 0x00000001
/* bit 0 */
142
#define SPARC_SOFTINT_SM_MASK 0x00010000
/* bit 16 */
143
#define SPARC_SOFTINT_TM_BIT_POSITION 1
/* bit 0 */
144
#define SPARC_SOFTINT_SM_BIT_POSITION 17
/* bit 16 */
145
146
#define STACK_BIAS (2047)
147
148
#ifdef ASM
149
150
151
* To enable the FPU we need to set both PSTATE.pef and FPRS.fef
152
153
154
#define sparc64_enable_FPU(rtmp1) \
155
rdpr %pstate, rtmp1; \
156
or rtmp1, SPARC_PSTATE_PEF_MASK, rtmp1; \
157
wrpr %g0, rtmp1, %pstate; \
158
rd %fprs, rtmp1; \
159
or rtmp1, SPARC_FPRS_FEF_MASK, rtmp1; \
160
wr %g0, rtmp1, %fprs
161
162
163
#endif
164
165
#ifndef ASM
166
167
168
* Standard nop
169
170
171
#define nop() \
172
do { \
173
__asm__ volatile ( "nop" ); \
174
} while ( 0 )
175
176
177
* Get and set the pstate
178
179
180
#define sparc64_get_pstate( _pstate ) \
181
do { \
182
(_pstate) = 0; \
183
__asm__ volatile( "rdpr %%pstate, %0" : "=r" (_pstate) : "0" (_pstate) ); \
184
} while ( 0 )
185
186
#define sparc64_set_pstate( _pstate ) \
187
do { \
188
__asm__ volatile ( \
189
"wrpr %%g0, %0, %%pstate " : "=r" ((_pstate)) : "0" ((_pstate)) ); \
190
} while ( 0 )
191
192
193
* Get and set the PIL
194
195
196
#define sparc64_get_pil( _pil ) \
197
do { \
198
(_pil) = 0; \
199
__asm__ volatile( "rdpr %%pil, %0" : "=r" (_pil) : "0" (_pil) ); \
200
} while ( 0 )
201
202
#define sparc64_set_pil( _pil ) \
203
do { \
204
__asm__ volatile ( "wrpr %%g0, %0, %%pil " : "=r" ((_pil)) : "0" ((_pil)) ); \
205
} while ( 0 )
206
207
208
209
* Get and set the TBA
210
211
212
#define sparc64_get_tba( _tba ) \
213
do { \
214
(_tba) = 0;
/* to avoid unitialized warnings */
215
__asm__ volatile( "rdpr %%tba, %0" : "=r" (_tba) : "0" (_tba) ); \
216
} while ( 0 )
217
218
#define sparc64_set_tba( _tba ) \
219
do { \
220
__asm__ volatile( "wrpr %%g0, %0, %%tba" : "=r" (_tba) : "0" (_tba) ); \
221
} while ( 0 )
222
223
224
* Get and set the TL (trap level)
225
226
227
#define sparc64_get_tl( _tl ) \
228
do { \
229
(_tl) = 0;
230
__asm__ volatile( "rdpr %%tl, %0" : "=r" (_tl) : "0" (_tl) ); \
231
} while ( 0 )
232
233
#define sparc64_set_tl( _tl ) \
234
do { \
235
__asm__ volatile( "wrpr %%g0, %0, %%tl" : "=r" (_tl) : "0" (_tl) ); \
236
} while ( 0 )
237
238
239
240
* read the stick register
241
242
* Note:
243
* stick asr=24, mnemonic=stick
244
* Note: stick does not appear to be a valid ASR for US3, although it is
245
* implemented in US3i.
246
247
#define sparc64_read_stick( _stick ) \
248
do { \
249
(_stick) = 0; \
250
__asm__ volatile( "rd %%stick, %0" : "=r" (_stick) : "0" (_stick) ); \
251
} while ( 0 )
252
253
254
* write the stick_cmpr register
255
256
* Note:
257
* stick_cmpr asr=25, mnemonic=stick_cmpr
258
* Note: stick_cmpr does not appear to be a valid ASR for US3, although it is
259
260
261
#define sparc64_write_stick_cmpr( _stick_cmpr ) \
262
do { \
263
__asm__ volatile( "wr %%g0, %0, %%stick_cmpr" : "=r" (_stick_cmpr) \
264
: "0" (_stick_cmpr) ); \
265
} while ( 0 )
266
267
268
* read the Tick register
269
270
#define sparc64_read_tick( _tick ) \
271
do { \
272
(_tick) = 0; \
273
__asm__ volatile( "rd %%tick, %0" : "=r" (_tick) : "0" (_tick) ); \
274
} while ( 0 )
275
276
277
* write the tick_cmpr register
278
279
#define sparc64_write_tick_cmpr( _tick_cmpr ) \
280
do { \
281
__asm__ volatile( "wr %%g0, %0, %%tick_cmpr" : "=r" (_tick_cmpr) \
282
: "0" (_tick_cmpr) ); \
283
} while ( 0 )
284
285
286
* Clear the softint register.
287
288
* sun4u and sun4v: softint_clr asr = 21, with mnemonic clear_softint
289
290
#define sparc64_clear_interrupt_bits( _bit_mask ) \
291
do { \
292
__asm__ volatile( "wr %%g0, %0, %%clear_softint" : "=r" (_bit_mask) \
293
: "0" (_bit_mask)); \
294
} while ( 0 )
295
296
/************* DEPRECATED ****************/
297
/* Note: Although the y register is deprecated, gcc still uses it */
298
299
* Get and set the Y
300
301
302
#define sparc_get_y( _y ) \
303
do { \
304
__asm__ volatile( "rd %%y, %0" : "=r" (_y) : "0" (_y) ); \
305
} while ( 0 )
306
307
#define sparc_set_y( _y ) \
308
do { \
309
__asm__ volatile( "wr %0, %%y" : "=r" (_y) : "0" (_y) ); \
310
} while ( 0 )
311
312
/************* /DEPRECATED ****************/
313
314
315
* Manipulate the interrupt level in the pstate
316
317
318
uint32_t sparc_disable_interrupts(
void
319
void
sparc_enable_interrupts(uint32_t);
320
321
#define sparc_flash_interrupts( _level ) \
322
do { \
323
uint32_t _ignored; \
324
325
sparc_enable_interrupts( (_level) ); \
326
_ignored = sparc_disable_interrupts(); \
327
(void) _ignored; \
328
} while ( 0 )
329
330
#define sparc64_get_interrupt_level( _level ) \
331
do { \
332
_level = 0; \
333
sparc64_get_pil( _level ); \
334
} while ( 0 )
335
336
#endif
/* !ASM */
337
338
#ifdef __cplusplus
339
340
#endif
341
342
#endif
/* _RTEMS_SCORE_SPARC_H */
