semtranslatereturncode.c File Reference
Semaphore Translate Core Mutex and Semaphore Return Code. More...
Include dependency graph for semtranslatereturncode.c:
const rtems_status_code _Semaphore_Translate_core_mutex_return_code_ []
const rtems_status_code _Semaphore_Translate_core_semaphore_return_code_ []
Variable Documentation
◆ _Semaphore_Translate_core_mutex_return_code_
const rtems_status_code _Semaphore_Translate_core_mutex_return_code_[]
Initial value:
This is the status to indicate that a blocking directive timed out.
Definition: status.h:75
This is the status to indicate successful completion.
Definition: status.h:50
This is the status to indicate that the caller is not the owner of the resource.
Definition: status.h:150
This is the status to indicate that an invalid thread priority was provided.
Definition: status.h:133
This is the status to indicate the the object was deleted while the task was blocked waiting...
Definition: status.h:80
This is the status to indicate that the request was not satisfied.
Definition: status.h:105
◆ _Semaphore_Translate_core_semaphore_return_code_
const rtems_status_code _Semaphore_Translate_core_semaphore_return_code_[]
Initial value:
This is the status to indicate that an internal RTEMS inconsistency was detected. ...
Definition: status.h:162
