#define | ATOMIC_ORDER_RELAXED CPU_ATOMIC_ORDER_RELAXED |
#define | ATOMIC_ORDER_ACQUIRE CPU_ATOMIC_ORDER_ACQUIRE |
#define | ATOMIC_ORDER_RELEASE CPU_ATOMIC_ORDER_RELEASE |
#define | ATOMIC_ORDER_ACQ_REL CPU_ATOMIC_ORDER_ACQ_REL |
#define | ATOMIC_ORDER_SEQ_CST CPU_ATOMIC_ORDER_SEQ_CST |
#define | ATOMIC_INITIALIZER_UINT(value) CPU_ATOMIC_INITIALIZER_UINT( value ) |
#define | ATOMIC_INITIALIZER_ULONG(value) CPU_ATOMIC_INITIALIZER_ULONG( value ) |
#define | ATOMIC_INITIALIZER_PTR(value) CPU_ATOMIC_INITIALIZER_PTR( value ) |
#define | ATOMIC_INITIALIZER_FLAG CPU_ATOMIC_INITIALIZER_FLAG |
#define | _Atomic_Fence(order) _CPU_atomic_Fence( order ) |
#define | _Atomic_Init_uint(obj, desired) _CPU_atomic_Init_uint( obj, desired ) |
#define | _Atomic_Init_ulong(obj, desired) _CPU_atomic_Init_ulong( obj, desired ) |
#define | _Atomic_Init_ptr(obj, desired) _CPU_atomic_Init_ptr( obj, desired ) |
#define | _Atomic_Load_uint(obj, order) _CPU_atomic_Load_uint( obj, order ) |
#define | _Atomic_Load_ulong(obj, order) _CPU_atomic_Load_ulong( obj, order ) |
#define | _Atomic_Load_ptr(obj, order) _CPU_atomic_Load_ptr( obj, order ) |
#define | _Atomic_Store_uint(obj, desr, order) _CPU_atomic_Store_uint( obj, desr, order ) |
#define | _Atomic_Store_ulong(obj, desr, order) _CPU_atomic_Store_ulong( obj, desr, order ) |
#define | _Atomic_Store_ptr(obj, desr, order) _CPU_atomic_Store_ptr( obj, desr, order ) |
#define | _Atomic_Fetch_add_uint(obj, arg, order) _CPU_atomic_Fetch_add_uint( obj, arg, order ) |
#define | _Atomic_Fetch_add_ulong(obj, arg, order) _CPU_atomic_Fetch_add_ulong( obj, arg, order ) |
#define | _Atomic_Fetch_add_ptr(obj, arg, order) _CPU_atomic_Fetch_add_ptr( obj, arg, order ) |
#define | _Atomic_Fetch_sub_uint(obj, arg, order) _CPU_atomic_Fetch_sub_uint( obj, arg, order ) |
#define | _Atomic_Fetch_sub_ulong(obj, arg, order) _CPU_atomic_Fetch_sub_ulong( obj, arg, order ) |
#define | _Atomic_Fetch_sub_ptr(obj, arg, order) _CPU_atomic_Fetch_sub_ptr( obj, arg, order ) |
#define | _Atomic_Fetch_or_uint(obj, arg, order) _CPU_atomic_Fetch_or_uint( obj, arg, order ) |
#define | _Atomic_Fetch_or_ulong(obj, arg, order) _CPU_atomic_Fetch_or_ulong( obj, arg, order ) |
#define | _Atomic_Fetch_or_ptr(obj, arg, order) _CPU_atomic_Fetch_or_ptr( obj, arg, order ) |
#define | _Atomic_Fetch_and_uint(obj, arg, order) _CPU_atomic_Fetch_and_uint( obj, arg, order ) |
#define | _Atomic_Fetch_and_ulong(obj, arg, order) _CPU_atomic_Fetch_and_ulong( obj, arg, order ) |
#define | _Atomic_Fetch_and_ptr(obj, arg, order) _CPU_atomic_Fetch_and_ptr( obj, arg, order ) |
#define | _Atomic_Exchange_uint(obj, desr, order) _CPU_atomic_Exchange_uint( obj, desr, order ) |
#define | _Atomic_Exchange_ulong(obj, desr, order) _CPU_atomic_Exchange_ulong( obj, desr, order ) |
#define | _Atomic_Exchange_ptr(obj, desr, order) _CPU_atomic_Exchange_ptr( obj, desr, order ) |
#define | _Atomic_Compare_exchange_uint(obj, expected, desired, succ, fail) _CPU_atomic_Compare_exchange_uint( obj, expected, desired, succ, fail ) |
#define | _Atomic_Compare_exchange_ulong(obj, expected, desired, succ, fail) _CPU_atomic_Compare_exchange_ulong( obj, expected, desired, succ, fail ) |
#define | _Atomic_Compare_exchange_ptr(obj, expected, desired, succ, fail) _CPU_atomic_Compare_exchange_ptr( obj, expected, desired, succ, fail ) |
#define | _Atomic_Flag_clear(obj, order) _CPU_atomic_Flag_clear( obj, order ) |
#define | _Atomic_Flag_test_and_set(obj, order) _CPU_atomic_Flag_test_and_set( obj, order ) |
