endian.h
1
8 #ifndef _RTEMS_ENDIAN_H
9 #define _RTEMS_ENDIAN_H
10
11 #include <rtems/score/cpu.h>
12
13 /*
14  * BSD-style endian declaration
15  */
16 #define BIG_ENDIAN 4321
17 #define LITTLE_ENDIAN 1234
18
19 #ifndef BYTE_ORDER
20 #if CPU_BIG_ENDIAN
21 # define BYTE_ORDER BIG_ENDIAN
22 #elif CPU_LITTLE_ENDIAN
23 # define BYTE_ORDER LITTLE_ENDIAN
24 #else
25 # error "Can't decide which end is which!"
26 #endif
27 #endif
28
29 #if ( CPU_BIG_ENDIAN == TRUE )
30
31 /*
32  * Very simply on big endian CPUs
33  */
34
35 static inline uint32_t ntohl( uint32_t _x )
36 {
37  return _x;
38 }
39
40 static inline uint16_t ntohs( uint16_t _x )
41 {
42  return _x;
43 }
44
45 static inline uint32_t htonl( uint32_t _x )
46 {
47  return _x;
48 }
49
50 static inline uint16_t htons( uint16_t _x )
51 {
52  return _x;
53 }
54
55 #define NTOHS(x)
56 #define HTONS(x)
57 #define NTOHL(x)
58 #define HTONL(x)
59
60 #elif ( CPU_LITTLE_ENDIAN == TRUE )
61
62 /*
63  * A little more complicated on little endian CPUs
64  */
65
66 static inline uint32_t ntohl( uint32_t _x )
67 {
68  return CPU_swap_u32(_x);
69 }
70
71 static inline uint16_t ntohs( uint16_t _x )
72 {
73  return CPU_swap_u16(_x);
74 }
75
76 static inline uint32_t htonl( uint32_t _x )
77 {
78  return CPU_swap_u32(_x);
79 }
80
81 static inline uint16_t htons( uint16_t _x )
82 {
83  return CPU_swap_u16(_x);
84 }
85
86 #define NTOHS(x) (x) = ntohs(x)
87 #define HTONS(x) (x) = htons(x)
88 #define NTOHL(x) (x) = ntohl(x)
89 #define HTONL(x) (x) = htonl(x)
90
91 #else
92 #error "Unknown endian-ness for this cpu"
93 #endif
94
95 static inline uint16_t rtems_uint16_from_little_endian( const uint8_t *data)
96 {
97  uint16_t value = 0;
98  int i;
99
100  for (i = 1; i >= 0; --i) {
101  value = (uint16_t) ((value << 8) + data [i]);
102  }
103
104  return value;
105 }
106
107 static inline uint32_t rtems_uint32_from_little_endian( const uint8_t *data)
108 {
109  uint32_t value = 0;
110  int i;
111
112  for (i = 3; i >= 0; --i) {
113  value = (value << 8) + data [i];
114  }
115
116  return value;
117 }
118
119 static inline uint64_t rtems_uint64_from_little_endian( const uint8_t *data)
120 {
121  uint64_t value = 0;
122  int i;
123
124  for (i = 7; i >= 0; --i) {
125  value = (value << 8) + (uint64_t) data [i];
126  }
127
128  return value;
129 }
130
131 static inline uint16_t rtems_uint16_from_big_endian( const uint8_t *data)
132 {
133  uint16_t value = 0;
134  int i;
135
136  for (i = 0; i < 2; ++i) {
137  value = (uint16_t) ((value << 8) + data [i]);
138  }
139
140  return value;
141 }
142
143 static inline uint32_t rtems_uint32_from_big_endian( const uint8_t *data)
144 {
145  uint32_t value = 0;
146  int i;
147
148  for (i = 0; i < 4; ++i) {
149  value = (value << 8) + (uint32_t) data [i];
150  }
151
152  return value;
153 }
154
155 static inline uint64_t rtems_uint64_from_big_endian( const uint8_t *data)
156 {
157  uint64_t value = 0;
158  int i;
159
160  for (i = 0; i < 8; ++i) {
161  value = (value << 8) + (uint64_t) data [i];
162  }
163
164  return value;
165 }
166
167 static inline void rtems_uint16_to_little_endian( uint16_t value, uint8_t *data)
168 {
169  int i;
170
171  for (i = 0; i < 2; ++i) {
172  data [i] = (uint8_t) value;
173  value >>= 8;
174  }
175 }
176
177 static inline void rtems_uint32_to_little_endian( uint32_t value, uint8_t *data)
178 {
179  int i;
180
181  for (i = 0; i < 4; ++i) {
182  data [i] = (uint8_t) value;
183  value >>= 8;
184  }
185 }
186
187 static inline void rtems_uint64_to_little_endian( uint64_t value, uint8_t *data)
188 {
189  int i;
190
191  for (i = 0; i < 8; ++i) {
192  data [i] = (uint8_t) value;
193  value >>= 8;
194  }
195 }
196
197 static inline void rtems_uint16_to_big_endian( uint16_t value, uint8_t *data)
198 {
199  int i;
200
201  for (i = 1; i >= 0; --i) {
202  data [i] = (uint8_t) value;
203  value >>= 8;
204  }
205 }
206
207 static inline void rtems_uint32_to_big_endian( uint32_t value, uint8_t *data)
208 {
209  int i;
210
211  for (i = 3; i >= 0; --i) {
212  data [i] = (uint8_t) value;
213  value >>= 8;
214  }
215 }
216
217 static inline void rtems_uint64_to_big_endian( uint64_t value, uint8_t *data)
218 {
219  int i;
220
221  for (i = 7; i >= 0; --i) {
222  data [i] = (uint8_t) value;
223  value >>= 8;
224  }
225 }
226
227 #endif /* _RTEMS_ENDIAN_H */
