resolv.h
1 /*
2  * Copyright (c) 1983, 1987, 1989
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 3. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  */
29
30 /*
31  * Copyright (c) 2004 by Internet Systems Consortium, Inc. ("ISC")
32  * Portions Copyright (c) 1996-1999 by Internet Software Consortium.
33  *
34  * Permission to use, copy, modify, and distribute this software for any
35  * purpose with or without fee is hereby granted, provided that the above
36  * copyright notice and this permission notice appear in all copies.
37  *
38  * THE SOFTWARE IS PROVIDED "AS IS" AND ISC DISCLAIMS ALL WARRANTIES
39  * WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
40  * MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL ISC BE LIABLE FOR
41  * ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
42  * WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
43  * ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT
44  * OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
45  */
46
47 /*%
48  * @(#)resolv.h 8.1 (Berkeley) 6/2/93
49  * $FreeBSD: release/9.0.0/include/resolv.h 203964 2010-02-16 19:39:50Z imp $
50  */
51
52 #ifndef _RESOLV_H_
53 #define _RESOLV_H_
54
55 #include <sys/param.h>
56 #include <sys/types.h>
57 #include <sys/cdefs.h>
58 #include <stdio.h>
59 #include <netinet/in.h> /* struct in_addr */
60
61 /*%
62  * Revision information. This is the release date in YYYYMMDD format.
63  * It can change every day so the right thing to do with it is use it
64  * in preprocessor commands such as "#if (__RES > 19931104)". Do not
65  * compare for equality; rather, use it to determine whether your resolver
66  * is new enough to contain a certain feature.
67  */
68
69 #define __RES 19960801
70
71 /*%
72  * This used to be defined in res_query.c, now it's in herror.c. It was
73  * never extern'd by any *.h file before it was placed here. herror.c is
74  * part of libresolv.a even though it might make more sense in libnetdb.a
75  * or even libnet.a.
76  */
77
78 extern int h_errno;
79
80 /*%
81  * Resolver configuration file.
82  * Normally not present, but may contain the address of the
83  * initial name server(s) to query and the domain search list.
84  */
85
86 #ifndef _PATH_RESCONF
87 #define _PATH_RESCONF "/etc/resolv.conf"
88 #endif
89
90 typedef enum { res_goahead, res_nextns, res_modified, res_done, res_error }
91  res_sendhookact;
92
93 typedef res_sendhookact (*res_send_qhook)(struct sockaddr_in * const *ns,
94  const u_char **query,
95  int *querylen,
96  u_char *ans,
97  int anssiz,
98  int *resplen);
99
100 typedef res_sendhookact (*res_send_rhook)(const struct sockaddr_in *ns,
101  const u_char *query,
102  int querylen,
103  u_char *ans,
104  int anssiz,
105  int *resplen);
106
107 struct res_sym {
108  int number; /*%< Identifying number, like T_MX */
109  const char * name; /*%< Its symbolic name, like "MX" */
110  const char * humanname; /*%< Its fun name, like "mail exchanger" */
111 };
112
113 /*%
114  * Global defines and variables for resolver stub.
115  */
116 #define MAXNS 3 /*%< max # name servers we'll track */
117 #define MAXDFLSRCH 3 /*%< # default domain levels to try */
118 #define MAXDNSRCH 6 /*%< max # domains in search path */
119 #define LOCALDOMAINPARTS 2 /*%< min levels in name that is "local" */
120 #define RES_TIMEOUT 5 /*%< min. seconds between retries */
121 #define MAXRESOLVSORT 10 /*%< number of net to sort on */
122 #define RES_MAXNDOTS 15 /*%< should reflect bit field size */
123
124 struct __res_state {
125  int retrans; /*%< retransmission time interval */
126  int retry; /*%< number of times to retransmit */
127  u_long options; /*%< option flags - see below. */
128  int nscount; /*%< number of name servers */
129  struct sockaddr_in
130  nsaddr_list[MAXNS]; /*%< address of name server */
131 #define nsaddr nsaddr_list[0] /*%< for backward compatibility */
132  u_short id; /*%< current message id */
133  char *dnsrch[MAXDNSRCH+1]; /*%< components of domain to search */
134  char defdname[256]; /*%< default domain (deprecated) */
135  u_long pfcode; /*%< RES_PRF_ flags - see below. */
136  unsigned ndots:4; /*%< threshold for initial abs. query */
137  unsigned nsort:4; /*%< number of elements in sort_list[] */
138  char unused[3];
139  struct {
140  struct in_addr addr;
141  u_int32_t mask;
142  } sort_list[MAXRESOLVSORT];
143  char pad[72]; /* on an i386 this means 512b total */
144 };
145
146 typedef struct __res_state *res_state;
147
148 /*%
149  * Resolver options (keep these in synch with res_debug.c, please)
150  */
151 #define RES_INIT 0x00000001 /*%< address initialized */
152 #define RES_DEBUG 0x00000002 /*%< print debug messages */
153 #define RES_AAONLY 0x00000004 /*%< authoritative answers only (!IMPL)*/
154 #define RES_USEVC 0x00000008 /*%< use virtual circuit */
155 #define RES_PRIMARY 0x00000010 /*%< query primary server only (!IMPL) */
156 #define RES_IGNTC 0x00000020 /*%< ignore truncation errors */
157 #define RES_RECURSE 0x00000040 /*%< recursion desired */
158 #define RES_DEFNAMES 0x00000080 /*%< use default domain name */
159 #define RES_STAYOPEN 0x00000100 /*%< Keep TCP socket open */
160 #define RES_DNSRCH 0x00000200 /*%< search up local domain tree */
161 #define RES_INSECURE1 0x00000400 /*%< type 1 security disabled */
162 #define RES_INSECURE2 0x00000800 /*%< type 2 security disabled */
163 #define RES_NOALIASES 0x00001000 /*%< shuts off HOSTALIASES feature */
164 #define RES_USE_INET6 0x00002000 /*%< use/map IPv6 in gethostbyname() */
165 #define RES_NOTLDQUERY 0x00004000 /*%< Don't query TLD names */
166
167 #define RES_DEFAULT (RES_RECURSE | RES_DEFNAMES | \
168  RES_DNSRCH)
169
170 /*%
171  * Resolver "pfcode" values. Used by dig.
172  */
173 #define RES_PRF_STATS 0x00000001
174 #define RES_PRF_UPDATE 0x00000002
175 #define RES_PRF_CLASS 0x00000004
176 #define RES_PRF_CMD 0x00000008
177 #define RES_PRF_QUES 0x00000010
178 #define RES_PRF_ANS 0x00000020
179 #define RES_PRF_AUTH 0x00000040
180 #define RES_PRF_ADD 0x00000080
181 #define RES_PRF_HEAD1 0x00000100
182 #define RES_PRF_HEAD2 0x00000200
183 #define RES_PRF_TTLID 0x00000400
184 #define RES_PRF_HEADX 0x00000800
185 #define RES_PRF_QUERY 0x00001000
186 #define RES_PRF_REPLY 0x00002000
187 #define RES_PRF_INIT 0x00004000
188 /* 0x00008000 */
189
190 #define fp_nquery __fp_nquery
191 #define fp_query __fp_query
192 #define hostalias __hostalias
193 #define p_query __p_query
194 #define res_close __res_close
195 #define res_init __res_init
196 #define res_isourserver __res_isourserver
197 #define res_mkquery __res_mkquery
198 #define res_query __res_query
199 #define res_querydomain __res_querydomain
200 #define res_search __res_search
201 #define res_send __res_send
202
203 __BEGIN_DECLS
204 void fp_nquery(const u_char *, int, FILE *);
205 void fp_query(const u_char *, FILE *);
206 const char * hostalias(const char *);
207 void p_query(const u_char *);
208 void res_close(void);
209 int res_init(void);
210 int res_isourserver(const struct sockaddr_in *);
211 int res_mkquery(int, const char *, int, int, const u_char *,
212  int, const u_char *, u_char *, int);
213 int res_query(const char *, int, int, u_char *, int);
214 int res_querydomain(const char *, const char *, int, int,
215  u_char *, int);
216 int res_search(const char *, int, int, u_char *, int);
217 int res_send(const u_char *, int, u_char *, int);
218 __END_DECLS
219
220 extern struct __res_state _res;
221
222
223 extern const struct res_sym __p_class_syms[];
224 extern const struct res_sym __p_type_syms[];
225
226 /* Private routines shared between libc/net, named, nslookup and others. */
227 #define b64_ntop __b64_ntop
228 #define b64_pton __b64_pton
229 #define dn_comp __dn_comp
230 #define dn_count_labels __dn_count_labels
231 #define dn_expand __dn_expand
232 #define dn_skipname __dn_skipname
233 #define fp_resstat __fp_resstat
234 #define loc_aton __loc_aton
235 #define loc_ntoa __loc_ntoa
236 #define p_cdname __p_cdname
237 #define p_cdnname __p_cdnname
238 #define fp_resstat __fp_resstat
239 #define p_class __p_class
240 #define p_fqname __p_fqname
241 #define p_fqnname __p_fqnname
242 #define p_option __p_option
243 #define p_secstodate __p_secstodate
244 #define p_section __p_section
245 #define p_time __p_time
246 #define p_type __p_type
247 #define putlong __putlong
248 #define putshort __putshort
249 #define res_dnok __res_dnok
250 #define res_hnok __res_hnok
251 #define res_mailok __res_mailok
252 #define res_nameinquery __res_nameinquery
253 #define res_ownok __res_ownok
254 #define res_queriesmatch __res_queriesmatch
255 #define res_randomid __res_randomid
256 #define sym_ntop __sym_ntop
257 #define sym_ntos __sym_ntos
258 #define sym_ston __sym_ston
259 #define res_send_setqhook __res_send_setqhook
260 #define res_send_setrhook __res_send_setrhook
261 #define res_mkupdate __res_mkupdate
262 #define res_mkupdrec __res_mkupdrec
263 #define res_freeupdrec __res_freeupdrec
264
265 __BEGIN_DECLS
266 int res_hnok(const char *);
267 int res_ownok(const char *);
268 int res_mailok(const char *);
269 int res_dnok(const char *);
270 int sym_ston(const struct res_sym *, const char *, int *);
271 const char * sym_ntos(const struct res_sym *, int, int *);
272 const char * sym_ntop(const struct res_sym *, int, int *);
273 int b64_ntop(u_char const *, size_t, char *, size_t);
274 int b64_pton(char const *, u_char *, size_t);
275 int loc_aton(const char *, u_char *);
276 const char * loc_ntoa(const u_char *, char *);
277 int dn_skipname(const u_char *, const u_char *);
278 void fp_resstat(struct __res_state *, FILE *);
279 void putlong(u_int32_t, u_char *);
280 void putshort(u_int16_t, u_char *);
281 const char * p_class(int);
282 const char * p_time(u_int32_t);
283 const char * p_type(int);
284 const u_char * p_cdnname(const u_char *, const u_char *, int, FILE *);
285 const u_char * p_cdname(const u_char *, const u_char *, FILE *);
286 const u_char * p_fqnname(const u_char *, const u_char *, int, char *, int);
287 const u_char * p_fqname(const u_char *, const u_char *, FILE *);
288 const char * p_option(u_long);
289 char * p_secstodate(u_long);
290 int dn_count_labels(const char *);
291 int dn_comp(const char *, u_char *, int, u_char **, u_char **);
292 int dn_expand(const u_char *, const u_char *, const u_char *,
293  char *, int);
294 u_int res_randomid(void);
295 int res_nameinquery(const char *, int, int, const u_char *,
296  const u_char *);
297 int res_queriesmatch(const u_char *, const u_char *,
298  const u_char *, const u_char *);
299 const char * p_section(int, int);
300 void res_send_setqhook(res_send_qhook);
301 void res_send_setrhook(res_send_rhook);
302
303 /* XXX The following depend on the ns_updrec typedef in arpa/nameser.h */
304 #ifdef _ARPA_NAMESER_H_
305 int res_update (ns_updrec *);
306 int res_mkupdate (ns_updrec *, u_char *, int);
307 ns_updrec * res_mkupdrec (int, const char *, u_int, u_int, u_long);
308 void res_freeupdrec (ns_updrec *);
309 #endif
310 __END_DECLS
311
312 #endif /* !_RESOLV_H_ */
Definition: in.h:74
Definition: nameser.h:220
Definition: inet.h:93
Definition: resolv.h:125
Definition: resolv.h:108
