radix.h
1 /*
2  * Copyright (c) 1988, 1989, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)radix.h 8.2 (Berkeley) 10/31/94
30  * $FreeBSD: src/sys/net/radix.h,v 1.25 2004/04/18 11:48:35 luigi Exp $
31  */
32
33 #ifndef _RADIX_H_
34 #define _RADIX_H_
35
36 /*
37  * Radix search tree node layout.
38  */
39
40 struct radix_node {
41  struct radix_mask *rn_mklist; /* list of masks contained in subtree */
42  struct radix_node *rn_parent; /* parent */
43  short rn_bit; /* bit offset; -1-index(netmask) */
44  char rn_bmask; /* node: mask for bit test*/
45  u_char rn_flags; /* enumerated next */
46 #define RNF_NORMAL 1 /* leaf contains normal route */
47 #define RNF_ROOT 2 /* leaf is root leaf for tree */
48 #define RNF_ACTIVE 4 /* This node is alive (for rtfree) */
49  union {
50  struct { /* leaf only data: */
51  caddr_t rn_Key; /* object of search */
52  caddr_t rn_Mask; /* netmask, if present */
53  struct radix_node *rn_Dupedkey;
54  } rn_leaf;
55  struct { /* node only data: */
56  int rn_Off; /* where to start compare */
57  struct radix_node *rn_L;/* progeny */
58  struct radix_node *rn_R;/* progeny */
59  } rn_node;
60  } rn_u;
61 #ifdef RN_DEBUG
62  int rn_info;
63  struct radix_node *rn_twin;
64  struct radix_node *rn_ybro;
65 #endif
66 };
67
68 #define rn_dupedkey rn_u.rn_leaf.rn_Dupedkey
69 #define rn_key rn_u.rn_leaf.rn_Key
70 #define rn_mask rn_u.rn_leaf.rn_Mask
71 #define rn_offset rn_u.rn_node.rn_Off
72 #define rn_left rn_u.rn_node.rn_L
73 #define rn_right rn_u.rn_node.rn_R
74
75 /*
76  * Annotations to tree concerning potential routes applying to subtrees.
77  */
78
79 struct radix_mask {
80  short rm_bit; /* bit offset; -1-index(netmask) */
81  char rm_unused; /* cf. rn_bmask */
82  u_char rm_flags; /* cf. rn_flags */
83  struct radix_mask *rm_mklist; /* more masks to try */
84  union {
85  caddr_t rmu_mask; /* the mask */
86  struct radix_node *rmu_leaf; /* for normal routes */
87  } rm_rmu;
88  int rm_refs; /* # of references to this struct */
89 };
90
91 #define rm_mask rm_rmu.rmu_mask
92 #define rm_leaf rm_rmu.rmu_leaf /* extra field would make 32 bytes */
93
94 #define MKGet(m) {\
95  if (rn_mkfreelist) {\
96  m = rn_mkfreelist; \
97  rn_mkfreelist = (m)->rm_mklist; \
98  } else \
99  R_Malloc(m, struct radix_mask *, sizeof (*(m))); }\
100
101 #define MKFree(m) { (m)->rm_mklist = rn_mkfreelist; rn_mkfreelist = (m);}
102
103 typedef int walktree_f_t(struct radix_node *, void *);
104
105 struct radix_node_head {
106  struct radix_node *rnh_treetop;
107  int rnh_addrsize; /* permit, but not require fixed keys */
108  int rnh_pktsize; /* permit, but not require fixed keys */
109  struct radix_node *(*rnh_addaddr) /* add based on sockaddr */
110  (void *v, void *mask,
111  struct radix_node_head *head, struct radix_node nodes[]);
112  struct radix_node *(*rnh_addpkt) /* add based on packet hdr */
113  (void *v, void *mask,
114  struct radix_node_head *head, struct radix_node nodes[]);
115  struct radix_node *(*rnh_deladdr) /* remove based on sockaddr */
116  (void *v, void *mask, struct radix_node_head *head);
117  struct radix_node *(*rnh_delpkt) /* remove based on packet hdr */
118  (void *v, void *mask, struct radix_node_head *head);
119  struct radix_node *(*rnh_matchaddr) /* locate based on sockaddr */
120  (void *v, struct radix_node_head *head);
121  struct radix_node *(*rnh_lookup) /* locate based on sockaddr */
122  (void *v, void *mask, struct radix_node_head *head);
123  struct radix_node *(*rnh_matchpkt) /* locate based on packet hdr */
124  (void *v, struct radix_node_head *head);
125  int (*rnh_walktree) /* traverse tree */
126  (struct radix_node_head *head, walktree_f_t *f, void *w);
127  int (*rnh_walktree_from) /* traverse tree below a */
128  (struct radix_node_head *head, void *a, void *m,
129  walktree_f_t *f, void *w);
130  void (*rnh_close) /* do something when the last ref drops */
131  (struct radix_node *rn, struct radix_node_head *head);
132  struct radix_node rnh_nodes[3]; /* empty tree for common case */
133 };
134
135 #ifndef _KERNEL
136 #define Bcmp(a, b, n) bcmp(((char *)(a)), ((char *)(b)), (n))
137 #define Bcopy(a, b, n) bcopy(((char *)(a)), ((char *)(b)), (unsigned)(n))
138 #define Bzero(p, n) bzero((char *)(p), (int)(n));
139 #define R_Malloc(p, t, n) (p = (t) malloc((unsigned int)(n)))
140 #define R_Zalloc(p, t, n) (p = (t) calloc(1,(unsigned int)(n)))
141 #define Free(p) free((char *)p);
142 #else
143 #define Bcmp(a, b, n) bcmp(((caddr_t)(a)), ((caddr_t)(b)), (unsigned)(n))
144 #define Bcopy(a, b, n) bcopy(((caddr_t)(a)), ((caddr_t)(b)), (unsigned)(n))
145 #define Bzero(p, n) bzero((caddr_t)(p), (unsigned)(n));
146 #define R_Malloc(p, t, n) (p = (t) malloc((unsigned long)(n), M_RTABLE, M_DONTWAIT))
147 #define Free(p) free((caddr_t)p, M_RTABLE);
148 #endif /*_KERNEL*/
149
150 void rn_init(void);
151 int rn_inithead(void **, int);
152 int rn_refines(void *, void *);
153 struct radix_node
154  *rn_addmask(void *, int, int),
155  *rn_addroute (void *, void *, struct radix_node_head *,
156  struct radix_node [2]),
157  *rn_delete(void *, void *, struct radix_node_head *),
158  *rn_lookup (void *v_arg, void *m_arg,
159  struct radix_node_head *head),
160  *rn_match(void *, struct radix_node_head *);
161
162 #endif /* _RADIX_H_ */
Definition: radix.h:106
Definition: radix.h:80
Definition: radix.h:41
