Data Structures | Macros
protosw.h File Reference
struct  protosw
#define PR_SLOWHZ   2L /* 2 slow timeouts per second */
#define PR_FASTHZ   5L /* 5 fast timeouts per second */
#define PR_ATOMIC   0x01 /* exchange atomic messages only */
#define PR_ADDR   0x02 /* addresses given with messages */
#define PR_CONNREQUIRED   0x04 /* connection required by protocol */
#define PR_WANTRCVD   0x08 /* want PRU_RCVD calls */
#define PR_RIGHTS   0x10 /* passes capabilities */
#define PR_IMPLOPCL   0x20 /* implied open/close */
#define PR_LASTHDR   0x40 /* enforce ipsec policy; last header */
#define PRU_ATTACH   0 /* attach protocol to up */
#define PRU_DETACH   1 /* detach protocol from up */
#define PRU_BIND   2 /* bind socket to address */
#define PRU_LISTEN   3 /* listen for connection */
#define PRU_CONNECT   4 /* establish connection to peer */
#define PRU_ACCEPT   5 /* accept connection from peer */
#define PRU_DISCONNECT   6 /* disconnect from peer */
#define PRU_SHUTDOWN   7 /* won't send any more data */
#define PRU_RCVD   8 /* have taken data; more room now */
#define PRU_SEND   9 /* send this data */
#define PRU_ABORT   10 /* abort (fast DISCONNECT, DETATCH) */
#define PRU_CONTROL   11 /* control operations on protocol */
#define PRU_SENSE   12 /* return status into m */
#define PRU_RCVOOB   13 /* retrieve out of band data */
#define PRU_SENDOOB   14 /* send out of band data */
#define PRU_SOCKADDR   15 /* fetch socket's address */
#define PRU_PEERADDR   16 /* fetch peer's address */
#define PRU_CONNECT2   17 /* connect two sockets */
#define PRU_FASTTIMO   18 /* 200ms timeout */
#define PRU_SLOWTIMO   19 /* 500ms timeout */
#define PRU_PROTORCV   20 /* receive from below */
#define PRU_PROTOSEND   21 /* send to below */
#define PRU_SEND_EOF   22 /* send and close */
#define PRU_NREQ   22
#define PRC_IFDOWN   0 /* interface transition */
#define PRC_ROUTEDEAD   1 /* select new route if possible ??? */
#define PRC_IFUP   2 /* interface has come back up */
#define PRC_QUENCH2   3 /* DEC congestion bit says slow down */
#define PRC_QUENCH   4 /* some one said to slow down */
#define PRC_MSGSIZE   5 /* message size forced drop */
#define PRC_HOSTDEAD   6 /* host appears to be down */
#define PRC_HOSTUNREACH   7 /* deprecated (use PRC_UNREACH_HOST) */
#define PRC_UNREACH_NET   8 /* no route to network */
#define PRC_UNREACH_HOST   9 /* no route to host */
#define PRC_UNREACH_PROTOCOL   10 /* dst says bad protocol */
#define PRC_UNREACH_PORT   11 /* bad port # */
#define PRC_UNREACH_SRCFAIL   13 /* source route failed */
#define PRC_REDIRECT_NET   14 /* net routing redirect */
#define PRC_REDIRECT_HOST   15 /* host routing redirect */
#define PRC_REDIRECT_TOSNET   16 /* redirect for type of service & net */
#define PRC_REDIRECT_TOSHOST   17 /* redirect for tos & host */
#define PRC_TIMXCEED_INTRANS   18 /* packet lifetime expired in transit */
#define PRC_TIMXCEED_REASS   19 /* lifetime expired on reass q */
#define PRC_PARAMPROB   20 /* header incorrect */
#define PRC_UNREACH_ADMIN_PROHIB   21 /* packet administrativly prohibited */
#define PRC_NCMDS   22
#define PRC_IS_REDIRECT(cmd)   ((cmd) >= PRC_REDIRECT_NET && (cmd) <= PRC_REDIRECT_TOSHOST)
#define PRCO_GETOPT   0
#define PRCO_SETOPT   1
#define PRCO_NCMDS   2
