ppp_comp.h
1 /*
2  * ppp-comp.h - Definitions for doing PPP packet compression.
3  */
4 /*
5  * Copyright (c) 1994 The Australian National University.
6  * All rights reserved.
7  *
8  * Permission to use, copy, modify, and distribute this software and its
9  * documentation is hereby granted, provided that the above copyright
10  * notice appears in all copies. This software is provided without any
11  * warranty, express or implied. The Australian National University
12  * makes no representations about the suitability of this software for
13  * any purpose.
14  *
15  * IN NO EVENT SHALL THE AUSTRALIAN NATIONAL UNIVERSITY BE LIABLE TO ANY
16  * PARTY FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES
17  * ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION, EVEN IF
18  * THE AUSTRALIAN NATIONAL UNIVERSITY HAVE BEEN ADVISED OF THE POSSIBILITY
19  * OF SUCH DAMAGE.
20  *
21  * THE AUSTRALIAN NATIONAL UNIVERSITY SPECIFICALLY DISCLAIMS ANY WARRANTIES,
22  * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
23  * AND FITNESS FOR A PARTICULAR PURPOSE. THE SOFTWARE PROVIDED HEREUNDER IS
24  * ON AN "AS IS" BASIS, AND THE AUSTRALIAN NATIONAL UNIVERSITY HAS NO
25  * OBLIGATION TO PROVIDE MAINTENANCE, SUPPORT, UPDATES, ENHANCEMENTS,
26  * OR MODIFICATIONS.
27  * $FreeBSD: src/sys/net/ppp_comp.h,v 1.12 2005/01/07 01:45:35 imp Exp $
28  */
29
30
31 #ifndef _NET_PPP_COMP_H
32 #define _NET_PPP_COMP_H
33
34 /*
35  * The following symbols control whether we include code for
36  * various compression methods.
37  */
38 #ifndef DO_BSD_COMPRESS
39 #define DO_BSD_COMPRESS 0 /* by default, include BSD-Compress */
40 #endif
41 #ifndef DO_DEFLATE
42 #define DO_DEFLATE 0 /* by default, include Deflate */
43 #endif
44 #define DO_PREDICTOR_1 0
45 #define DO_PREDICTOR_2 0
46
47 /*
48  * Structure giving methods for compression/decompression.
49  */
50 #ifdef PACKETPTR
51 struct compressor {
52  int compress_proto; /* CCP compression protocol number */
53
54  /* Allocate space for a compressor (transmit side) */
55  void *(*comp_alloc)(u_char *options, int opt_len);
56  /* Free space used by a compressor */
57  void (*comp_free)(void *state);
58  /* Initialize a compressor */
59  int (*comp_init)(void *state, u_char *options, int opt_len,
60  int unit, int hdrlen, int debug);
61  /* Reset a compressor */
62  void (*comp_reset)(void *state);
63  /* Compress a packet */
64  int (*compress)(void *state, PACKETPTR *mret, PACKETPTR mp,
65  int orig_len, int max_len);
66  /* Return compression statistics */
67  void (*comp_stat)(void *state, struct compstat *stats);
68
69  /* Allocate space for a decompressor (receive side) */
70  void *(*decomp_alloc)(u_char *options, int opt_len);
71  /* Free space used by a decompressor */
72  void (*decomp_free)(void *state);
73  /* Initialize a decompressor */
74  int (*decomp_init)(void *state, u_char *options, int opt_len,
75  int unit, int hdrlen, int mru, int debug);
76  /* Reset a decompressor */
77  void (*decomp_reset)(void *state);
78  /* Decompress a packet. */
79  int (*decompress)(void *state, PACKETPTR mp, PACKETPTR *dmpp);
80  /* Update state for an incompressible packet received */
81  void (*incomp)(void *state, PACKETPTR mp);
82  /* Return decompression statistics */
83  void (*decomp_stat)(void *state, struct compstat *stats);
84 };
85 #endif /* PACKETPTR */
86
87 /*
88  * Return values for decompress routine.
89  * We need to make these distinctions so that we can disable certain
90  * useful functionality, namely sending a CCP reset-request as a result
91  * of an error detected after decompression. This is to avoid infringing
92  * a patent held by Motorola.
93  * Don't you just lurve software patents.
94  */
95 #define DECOMP_OK 0 /* everything went OK */
96 #define DECOMP_ERROR 1 /* error detected before decomp. */
97 #define DECOMP_FATALERROR 2 /* error detected after decomp. */
98
99 /*
100  * CCP codes.
101  */
102 #define CCP_CONFREQ 1
103 #define CCP_CONFACK 2
104 #define CCP_TERMREQ 5
105 #define CCP_TERMACK 6
106 #define CCP_RESETREQ 14
107 #define CCP_RESETACK 15
108
109 /*
110  * Max # bytes for a CCP option
111  */
112 #define CCP_MAX_OPTION_LENGTH 32
113
114 /*
115  * Parts of a CCP packet.
116  */
117 #define CCP_CODE(dp) ((dp)[0])
118 #define CCP_ID(dp) ((dp)[1])
119 #define CCP_LENGTH(dp) (((dp)[2] << 8) + (dp)[3])
120 #define CCP_HDRLEN 4
121
122 #define CCP_OPT_CODE(dp) ((dp)[0])
123 #define CCP_OPT_LENGTH(dp) ((dp)[1])
124 #define CCP_OPT_MINLEN 2
125
126 /*
127  * Definitions for BSD-Compress.
128  */
129 #define CI_BSD_COMPRESS 21 /* config. option for BSD-Compress */
130 #define CILEN_BSD_COMPRESS 3 /* length of config. option */
131
132 /* Macros for handling the 3rd byte of the BSD-Compress config option. */
133 #define BSD_NBITS(x) ((x) & 0x1F) /* number of bits requested */
134 #define BSD_VERSION(x) ((x) >> 5) /* version of option format */
135 #define BSD_CURRENT_VERSION 1 /* current version number */
136 #define BSD_MAKE_OPT(v, n) (((v) << 5) | (n))
137
138 #define BSD_MIN_BITS 9 /* smallest code size supported */
139 #define BSD_MAX_BITS 15 /* largest code size supported */
140
141 /*
142  * Definitions for Deflate.
143  */
144 #define CI_DEFLATE 26 /* config option for Deflate */
145 #define CI_DEFLATE_DRAFT 24 /* value used in original draft RFC */
146 #define CILEN_DEFLATE 4 /* length of its config option */
147
148 #define DEFLATE_MIN_SIZE 8
149 #define DEFLATE_MAX_SIZE 15
150 #define DEFLATE_METHOD_VAL 8
151 #define DEFLATE_SIZE(x) (((x) >> 4) + DEFLATE_MIN_SIZE)
152 #define DEFLATE_METHOD(x) ((x) & 0x0F)
153 #define DEFLATE_MAKE_OPT(w) ((((w) - DEFLATE_MIN_SIZE) << 4) \
154  + DEFLATE_METHOD_VAL)
155 #define DEFLATE_CHK_SEQUENCE 0
156
157 /*
158  * Definitions for other, as yet unsupported, compression methods.
159  */
160 #define CI_PREDICTOR_1 1 /* config option for Predictor-1 */
161 #define CILEN_PREDICTOR_1 2 /* length of its config option */
162 #define CI_PREDICTOR_2 2 /* config option for Predictor-2 */
163 #define CILEN_PREDICTOR_2 2 /* length of its config option */
164
165 #endif /* _NET_PPP_COMP_H */
Definition: ppp_defs.h:128
