pmap_prot.h
1 /*
2  * Sun RPC is a product of Sun Microsystems, Inc. and is provided for
3  * unrestricted use provided that this legend is included on all tape
4  * media and as a part of the software program in whole or part. Users
5  * may copy or modify Sun RPC without charge, but are not authorized
6  * to license or distribute it to anyone else except as part of a product or
7  * program developed by the user.
8  *
9  * SUN RPC IS PROVIDED AS IS WITH NO WARRANTIES OF ANY KIND INCLUDING THE
10  * WARRANTIES OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR
11  * PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE OR TRADE PRACTICE.
12  *
13  * Sun RPC is provided with no support and without any obligation on the
14  * part of Sun Microsystems, Inc. to assist in its use, correction,
15  * modification or enhancement.
16  *
17  * SUN MICROSYSTEMS, INC. SHALL HAVE NO LIABILITY WITH RESPECT TO THE
18  * INFRINGEMENT OF COPYRIGHTS, TRADE SECRETS OR ANY PATENTS BY SUN RPC
19  * OR ANY PART THEREOF.
20  *
21  * In no event will Sun Microsystems, Inc. be liable for any lost revenue
22  * or profits or other special, indirect and consequential damages, even if
23  * Sun has been advised of the possibility of such damages.
24  *
25  * Sun Microsystems, Inc.
26  * 2550 Garcia Avenue
27  * Mountain View, California 94043
28  *
29  * from: @(#)pmap_prot.h 1.14 88/02/08 SMI
30  * from: @(#)pmap_prot.h 2.1 88/07/29 4.0 RPCSRC
31  * $FreeBSD: src/include/rpc/pmap_prot.h,v 1.10 1999/08/27 23:45:04 peter Exp $
32  */
33
34 /*
35  * pmap_prot.h
36  * Protocol for the local binder service, or pmap.
37  *
38  * Copyright (C) 1984, Sun Microsystems, Inc.
39  *
40  * The following procedures are supported by the protocol:
41  *
42  * PMAPPROC_NULL() returns ()
43  * takes nothing, returns nothing
44  *
45  * PMAPPROC_SET(struct pmap) returns (bool_t)
46  * TRUE is success, FALSE is failure. Registers the tuple
47  * [prog, vers, prot, port].
48  *
49  * PMAPPROC_UNSET(struct pmap) returns (bool_t)
50  * TRUE is success, FALSE is failure. Un-registers pair
51  * [prog, vers]. prot and port are ignored.
52  *
53  * PMAPPROC_GETPORT(struct pmap) returns (long unsigned).
54  * 0 is failure. Otherwise returns the port number where the pair
55  * [prog, vers] is registered. It may lie!
56  *
57  * PMAPPROC_DUMP() RETURNS (struct pmaplist *)
58  *
59  * PMAPPROC_CALLIT(unsigned, unsigned, unsigned, string<>)
60  * RETURNS (port, string<>);
61  * usage: encapsulatedresults = PMAPPROC_CALLIT(prog, vers, proc, encapsulatedargs);
62  * Calls the procedure on the local machine. If it is not registered,
63  * this procedure is quite; ie it does not return error information!!!
64  * This procedure only is supported on rpc/udp and calls via
65  * rpc/udp. This routine only passes null authentication parameters.
66  * This file has no interface to xdr routines for PMAPPROC_CALLIT.
67  *
68  * The service supports remote procedure calls on udp/ip or tcp/ip socket 111.
69  */
70
71 #ifndef _RPC_PMAPPROT_H
72 #define _RPC_PMAPPROT_H
73 #include <sys/cdefs.h>
74 #include <rpc/xdr.h>
75
76 #define PMAPPORT ((u_short)111)
77 #define PMAPPROG ((u_long)100000)
78 #define PMAPVERS ((u_long)2)
79 #define PMAPVERS_PROTO ((u_long)2)
80 #define PMAPVERS_ORIG ((u_long)1)
81 #define PMAPPROC_NULL ((u_long)0)
82 #define PMAPPROC_SET ((u_long)1)
83 #define PMAPPROC_UNSET ((u_long)2)
84 #define PMAPPROC_GETPORT ((u_long)3)
85 #define PMAPPROC_DUMP ((u_long)4)
86 #define PMAPPROC_CALLIT ((u_long)5)
87
88 struct pmap {
89  long unsigned pm_prog;
90  long unsigned pm_vers;
91  long unsigned pm_prot;
92  long unsigned pm_port;
93 };
94
95 struct pmaplist {
96  struct pmap pml_map;
97  struct pmaplist *pml_next;
98 };
99
100 __BEGIN_DECLS
101 extern bool_t xdr_pmap (XDR *, struct pmap *);
102 extern bool_t xdr_pmaplist (XDR *, struct pmaplist **);
103 __END_DECLS
104
105 #endif /* !_RPC_PMAPPROT_H */
Definition: pmap_prot.h:96
Definition: xdr.h:104
Definition: pmap_prot.h:89
