POSIX FIFO/pipe File System Support. More...
#include <rtems/libio.h>
struct | pipe_control |
Typedefs | |
typedef struct pipe_control | pipe_control_t |
int | pipe_create (int filsdes[2]) |
Create an anonymous pipe. More... | |
void | pipe_release (pipe_control_t **pipep, rtems_libio_t *iop) |
Release a pipe. More... | |
int | fifo_open (pipe_control_t **pipep, rtems_libio_t *iop) |
File system open. More... | |
ssize_t | pipe_read (pipe_control_t *pipe, void *buffer, size_t count, rtems_libio_t *iop) |
File system read. More... | |
ssize_t | pipe_write (pipe_control_t *pipe, const void *buffer, size_t count, rtems_libio_t *iop) |
File system write. More... | |
int | pipe_ioctl (pipe_control_t *pipe, ioctl_command_t cmd, void *buffer, rtems_libio_t *iop) |
File system Input/Output control. More... | |
This include file defines the interface to the POSIX FIFO/pipe file system support.
