score
cpu
or1k
score
or1k.h
1
5
6
* This file contains information pertaining to the OR1K processor.
7
8
* COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary@gmail.com>
9
10
* Based on code with the following copyright...
11
* COPYRIGHT (c) 1989-1999, 2010.
12
* On-Line Applications Research Corporation (OAR).
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#ifndef _RTEMS_SCORE_OR1K_H
20
#define _RTEMS_SCORE_OR1K_H
21
22
#ifdef __cplusplus
23
extern
"C"
24
#endif
25
26
27
* This file contains the information required to build
28
* RTEMS for a particular member of the OR1K family.
29
* It does this by setting variables to indicate which
30
* implementation dependent features are present in a particular
31
* member of the family.
32
33
* This is a good place to list all the known CPU models
34
* that this port supports and which RTEMS CPU model they correspond
35
* to.
36
37
38
39
* Define the name of the CPU family and specific model.
40
41
42
#define CPU_NAME "OR1K"
43
#define CPU_MODEL_NAME "OR1200"
44
45
#ifdef __cplusplus
46
47
#endif
48
49
#endif
/* _RTEMS_SCORE_OR1K_H */
