score
cpu
or1k
asm.h
1
11
12
* NOTE: The spacing in the use of these macros
13
* is critical to them working as advertised.
14
15
* COPYRIGHT:
16
17
* This file is based on similar code found in newlib available
18
* from ftp.cygnus.com. The file which was used had no copyright
19
* notice. This file is freely distributable as long as the source
20
* of the file is noted. This file is:
21
22
* COPYRIGHT (c) 1994-1997.
23
* On-Line Applications Research Corporation (OAR).
24
25
26
27
#ifndef __OR1K_ASM_h
28
#define __OR1K_ASM_h
29
30
31
* Indicate we are in an assembly file and get the basic CPU definitions.
32
33
34
#ifndef ASM
35
#define ASM
36
#endif
37
38
rtems/score/or1k.h
39
40
41
* Recent versions of GNU cpp define variables which indicate the
42
* need for underscores and percents. If not using GNU cpp or
43
* the version does not support this, then you will obviously
44
* have to define these as appropriate.
45
46
47
#ifndef __USER_LABEL_PREFIX__
48
#define __USER_LABEL_PREFIX__ _
49
#endif
50
51
#ifndef __REGISTER_PREFIX__
52
#define __REGISTER_PREFIX__
53
#endif
54
55
/* ANSI concatenation macros. */
56
57
#define CONCAT1(a, b) CONCAT2(a, b)
58
#define CONCAT2(a, b) a ## b
59
60
/* Use the right prefix for global labels. */
61
62
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
63
64
/* Use the right prefix for registers. */
65
66
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
67
68
69
* define macros for all of the registers on this CPU
70
71
* EXAMPLE: #define d0 REG (d0)
72
73
74
75
* Define macros to handle section beginning and ends.
76
77
78
79
#define BEGIN_CODE_DCL .text
80
#define END_CODE_DCL
81
#define BEGIN_DATA_DCL .data
82
#define END_DATA_DCL
83
#define BEGIN_CODE .text
84
#define END_CODE
85
#define BEGIN_DATA
86
#define END_DATA
87
#define BEGIN_BSS
88
#define END_BSS
89
#define END
90
91
92
* Following must be tailor for a particular flavor of the C compiler.
93
* They may need to put underscores in front of the symbols.
94
95
96
#define PUBLIC(sym) .global SYM (sym)
97
#define EXTERN(sym) .global SYM (sym)
98
99
#endif
or1k.h
