| #define | NIS_DIR "data" |
| #define | FOLLOW_LINKS (1<<0) /* Follow link objects */ |
| #define | FOLLOW_PATH (1<<1) /* Follow the path in a table */ |
| #define | HARD_LOOKUP (1<<2) /* Block until successful */ |
| #define | ALL_RESULTS (1<<3) /* Retrieve all results */ |
| #define | NO_CACHE (1<<4) /* Do not return 'cached' results */ |
| #define | MASTER_ONLY (1<<5) /* Get value only from master server */ |
| #define | EXPAND_NAME (1<<6) /* Expand partitially qualified names */ |
| #define | RETURN_RESULT (1<<7) /* Return resulting object to client */ |
| #define | ADD_OVERWRITE (1<<8) /* Allow overwrites on ADD */ |
| #define | REM_MULTIPLE (1<<9) /* Allow wildcard deletes */ |
| #define | MOD_SAMEOBJ (1<<10) /* Check modified object before write */ |
| #define | ADD_RESERVED (1<<11) /* Spare ADD semantic */ |
| #define | REM_RESERVED (1<<12) /* Spare REM semantic */ |
| #define | MOD_EXCLUSIVE (1<<13) /* Modify no overwrite on modified keys */ |
| #define | USE_DGRAM (1<<16) /* Use a datagram transport */ |
| #define | NO_AUTHINFO (1<<17) /* Don't bother attaching auth info */ |
| #define | TAG_DEBUG 1 /* set debug level */ |
| #define | TAG_STATS 2 /* Enable/disable statistics */ |
| #define | TAG_GCACHE 3 /* Flush the Group Cache */ |
| #define | TAG_GCACHE_ALL TAG_GCACHE |
| #define | TAG_DCACHE 4 /* Flush the directory cache */ |
| #define | TAG_DCACHE_ONE TAG_DCACHE |
| #define | TAG_OCACHE 5 /* Flush the Object Cache */ |
| #define | TAG_SECURE 6 /* Set the security level */ |
| #define | TAG_TCACHE_ONE 7 /* Flush the table cache */ |
| #define | TAG_DCACHE_ALL 8 /* Flush entire directory cache */ |
| #define | TAG_TCACHE_ALL 9 /* Flush entire table cache */ |
| #define | TAG_GCACHE_ONE 10 /* Flush one group object */ |
| #define | TAG_DCACHE_ONE_REFRESH 11 /* Flush and refresh one DO */ |
| #define | TAG_OPSTATS 2048 /* NIS+ operations statistics */ |
| #define | TAG_THREADS 2049 /* Child process/thread status */ |
| #define | TAG_HEAP 2050 /* Heap usage statistics */ |
| #define | TAG_UPDATES 2051 /* Updates to this service */ |
| #define | TAG_VISIBLE 2052 /* First update that isn't replicated */ |
| #define | TAG_S_DCACHE 2053 /* Directory cache statistics */ |
| #define | TAG_S_OCACHE 2054 /* Object cache statistics */ |
| #define | TAG_S_GCACHE 2055 /* Group cache statistics */ |
| #define | TAG_S_STORAGE 2056 /* Group cache statistics */ |
| #define | TAG_UPTIME 2057 /* Time that server has been up */ |
| #define | TAG_DIRLIST 2058 /* Dir served by this server */ |
| #define | TAG_NISCOMPAT 2059 /* Whether supports NIS compat mode */ |
| #define | TAG_DNSFORWARDING 2060 /* Whether DNS forwarding supported*/ |
| #define | TAG_SECURITY_LEVEL 2061 /* Security level of the server */ |
| #define | TAG_ROOTSERVER 2062 /* Whether root server */ |
| #define | IMPMEM_GROUPS 1 /* Implicit Membership allowed */ |
| #define | RECURS_GROUPS 2 /* Recursive Groups allowed */ |
| #define | NEGMEM_GROUPS 4 /* Negative Groups allowed */ |
