nfsproto.h
1 /*
2  * Copyright (c) 1989, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * This code is derived from software contributed to Berkeley by
6  * Rick Macklem at The University of Guelph.
7  *
8  * Redistribution and use in source and binary forms, with or without
9  * modification, are permitted provided that the following conditions
10  * are met:
11  * 1. Redistributions of source code must retain the above copyright
12  * notice, this list of conditions and the following disclaimer.
13  * 2. Redistributions in binary form must reproduce the above copyright
14  * notice, this list of conditions and the following disclaimer in the
15  * documentation and/or other materials provided with the distribution.
16  * 4. Neither the name of the University nor the names of its contributors
17  * may be used to endorse or promote products derived from this software
18  * without specific prior written permission.
19  *
20  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
21  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
24  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
25  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
26  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
27  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
28  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
29  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
30  * SUCH DAMAGE.
31  *
32  * @(#)nfsproto.h 8.2 (Berkeley) 3/30/95
33  * $FreeBSD: src/sys/nfs/nfsproto.h,v 1.11 2005/01/07 01:45:50 imp Exp $
34  */
35
36
37 #ifndef _NFS_NFSPROTO_H_
38 #define _NFS_NFSPROTO_H_
39
40 #include <sys/mount.h> /* fhandle_t */
41
42 /*
43  * nfs definitions as per the Version 2 and 3 specs
44  */
45
46 /*
47  * Constants as defined in the Sun NFS Version 2 and 3 specs.
48  * "NFS: Network File System Protocol Specification" RFC1094
49  * and in the "NFS: Network File System Version 3 Protocol
50  * Specification"
51  */
52
53 #define NFS_PORT 2049
54 #define NFS_PROG 100003
55 #define NFS_VER2 2
56 #define NFS_VER3 3
57 #define NFS_V2MAXDATA 8192
58 #define NFS_MAXDGRAMDATA 16384
59 #define NFS_MAXDATA 32768
60 #define NFS_MAXPATHLEN 1024
61 #define NFS_MAXNAMLEN 255
62 #define NFS_MAXPKTHDR 404
63 #define NFS_MAXPACKET (NFS_MAXPKTHDR + NFS_MAXDATA)
64 #define NFS_MINPACKET 20
65 #define NFS_FABLKSIZE 512 /* Size in bytes of a block wrt fa_blocks */
66
67 /* Stat numbers for rpc returns (version 2 and 3) */
68 #define NFS_OK 0
69 #define NFSERR_PERM 1
70 #define NFSERR_NOENT 2
71 #define NFSERR_IO 5
72 #define NFSERR_NXIO 6
73 #define NFSERR_ACCES 13
74 #define NFSERR_EXIST 17
75 #define NFSERR_XDEV 18 /* Version 3 only */
76 #define NFSERR_NODEV 19
77 #define NFSERR_NOTDIR 20
78 #define NFSERR_ISDIR 21
79 #define NFSERR_INVAL 22 /* Version 3 only */
80 #define NFSERR_FBIG 27
81 #define NFSERR_NOSPC 28
82 #define NFSERR_ROFS 30
83 #define NFSERR_MLINK 31 /* Version 3 only */
84 #define NFSERR_NAMETOL 63
85 #define NFSERR_NOTEMPTY 66
86 #define NFSERR_DQUOT 69
87 #define NFSERR_STALE 70
88 #define NFSERR_REMOTE 71 /* Version 3 only */
89 #define NFSERR_WFLUSH 99 /* Version 2 only */
90 #define NFSERR_BADHANDLE 10001 /* The rest Version 3, 4 only */
91 #define NFSERR_NOT_SYNC 10002
92 #define NFSERR_BAD_COOKIE 10003
93 #define NFSERR_NOTSUPP 10004
94 #define NFSERR_TOOSMALL 10005
95 #define NFSERR_SERVERFAULT 10006
96 #define NFSERR_BADTYPE 10007
97 #define NFSERR_JUKEBOX 10008
98 #define NFSERR_TRYLATER NFSERR_JUKEBOX
99 #define NFSERR_STALEWRITEVERF 30001 /* Fake return for nfs_commit() */
100
101
102
103 #define NFSERR_RETVOID 0x20000000 /* Return void, not error */
104 #define NFSERR_AUTHERR 0x40000000 /* Mark an authentication error */
105 #define NFSERR_RETERR 0x80000000 /* Mark an error return for V3 */
106
107 /* Sizes in bytes of various nfs rpc components */
108 #define NFSX_UNSIGNED 4
109
110 /* specific to NFS Version 2 */
111 #define NFSX_V2FH 32
112 #define NFSX_V2FATTR 68
113 #define NFSX_V2SATTR 32
114 #define NFSX_V2COOKIE 4
115 #define NFSX_V2STATFS 20
116
117 /* specific to NFS Version 3 */
118 #define NFSX_V3FH (sizeof (fhandle_t)) /* size this server uses */
119 #define NFSX_V3FHMAX 64 /* max. allowed by protocol */
120 #define NFSX_V3FATTR 84
121 #define NFSX_V3SATTR 60 /* max. all fields filled in */
122 #define NFSX_V3SRVSATTR (sizeof (struct nfsv3_sattr))
123 #define NFSX_V3POSTOPATTR (NFSX_V3FATTR + NFSX_UNSIGNED)
124 #define NFSX_V3WCCDATA (NFSX_V3POSTOPATTR + 8 * NFSX_UNSIGNED)
125 #define NFSX_V3COOKIEVERF 8
126 #define NFSX_V3WRITEVERF 8
127 #define NFSX_V3CREATEVERF 8
128 #define NFSX_V3STATFS 52
129 #define NFSX_V3FSINFO 48
130 #define NFSX_V3PATHCONF 24
131
132 /* variants for both versions */
133 #define NFSX_FH(v3) ((v3) ? (NFSX_V3FHMAX + NFSX_UNSIGNED) : \
134  NFSX_V2FH)
135 #define NFSX_SRVFH(v3) ((v3) ? NFSX_V3FH : NFSX_V2FH)
136 #define NFSX_FATTR(v3) ((v3) ? NFSX_V3FATTR : NFSX_V2FATTR)
137 #define NFSX_PREOPATTR(v3) ((v3) ? (7 * NFSX_UNSIGNED) : 0)
138 #define NFSX_POSTOPATTR(v3) ((v3) ? (NFSX_V3FATTR + NFSX_UNSIGNED) : 0)
139 #define NFSX_POSTOPORFATTR(v3) ((v3) ? (NFSX_V3FATTR + NFSX_UNSIGNED) : \
140  NFSX_V2FATTR)
141 #define NFSX_WCCDATA(v3) ((v3) ? NFSX_V3WCCDATA : 0)
142 #define NFSX_WCCORFATTR(v3) ((v3) ? NFSX_V3WCCDATA : NFSX_V2FATTR)
143 #define NFSX_SATTR(v3) ((v3) ? NFSX_V3SATTR : NFSX_V2SATTR)
144 #define NFSX_COOKIEVERF(v3) ((v3) ? NFSX_V3COOKIEVERF : 0)
145 #define NFSX_WRITEVERF(v3) ((v3) ? NFSX_V3WRITEVERF : 0)
146 #define NFSX_READDIR(v3) ((v3) ? (5 * NFSX_UNSIGNED) : \
147  (2 * NFSX_UNSIGNED))
148 #define NFSX_STATFS(v3) ((v3) ? NFSX_V3STATFS : NFSX_V2STATFS)
149
150 /* nfs rpc procedure numbers (before version mapping) */
151 #define NFSPROC_NULL 0
152 #define NFSPROC_GETATTR 1
153 #define NFSPROC_SETATTR 2
154 #define NFSPROC_LOOKUP 3
155 #define NFSPROC_ACCESS 4
156 #define NFSPROC_READLINK 5
157 #define NFSPROC_READ 6
158 #define NFSPROC_WRITE 7
159 #define NFSPROC_CREATE 8
160 #define NFSPROC_MKDIR 9
161 #define NFSPROC_SYMLINK 10
162 #define NFSPROC_MKNOD 11
163 #define NFSPROC_REMOVE 12
164 #define NFSPROC_RMDIR 13
165 #define NFSPROC_RENAME 14
166 #define NFSPROC_LINK 15
167 #define NFSPROC_READDIR 16
168 #define NFSPROC_READDIRPLUS 17
169 #define NFSPROC_FSSTAT 18
170 #define NFSPROC_FSINFO 19
171 #define NFSPROC_PATHCONF 20
172 #define NFSPROC_COMMIT 21
173 #define NFSPROC_NOOP 22
174 #define NFS_NPROCS 23
175
176 /* Actual Version 2 procedure numbers */
177 #define NFSV2PROC_NULL 0
178 #define NFSV2PROC_GETATTR 1
179 #define NFSV2PROC_SETATTR 2
180 #define NFSV2PROC_NOOP 3
181 #define NFSV2PROC_ROOT NFSV2PROC_NOOP /* Obsolete */
182 #define NFSV2PROC_LOOKUP 4
183 #define NFSV2PROC_READLINK 5
184 #define NFSV2PROC_READ 6
185 #define NFSV2PROC_WRITECACHE NFSV2PROC_NOOP /* Obsolete */
186 #define NFSV2PROC_WRITE 8
187 #define NFSV2PROC_CREATE 9
188 #define NFSV2PROC_REMOVE 10
189 #define NFSV2PROC_RENAME 11
190 #define NFSV2PROC_LINK 12
191 #define NFSV2PROC_SYMLINK 13
192 #define NFSV2PROC_MKDIR 14
193 #define NFSV2PROC_RMDIR 15
194 #define NFSV2PROC_READDIR 16
195 #define NFSV2PROC_STATFS 17
196
197 /*
198  * Constants used by the Version 3 protocol for various RPCs
199  */
200 #define NFSV3SATTRTIME_DONTCHANGE 0
201 #define NFSV3SATTRTIME_TOSERVER 1
202 #define NFSV3SATTRTIME_TOCLIENT 2
203
204 #define NFSV3ACCESS_READ 0x01
205 #define NFSV3ACCESS_LOOKUP 0x02
206 #define NFSV3ACCESS_MODIFY 0x04
207 #define NFSV3ACCESS_EXTEND 0x08
208 #define NFSV3ACCESS_DELETE 0x10
209 #define NFSV3ACCESS_EXECUTE 0x20
210
211 #define NFSV3WRITE_UNSTABLE 0
212 #define NFSV3WRITE_DATASYNC 1
213 #define NFSV3WRITE_FILESYNC 2
214
215 #define NFSV3CREATE_UNCHECKED 0
216 #define NFSV3CREATE_GUARDED 1
217 #define NFSV3CREATE_EXCLUSIVE 2
218
219 #define NFSV3FSINFO_LINK 0x01
220 #define NFSV3FSINFO_SYMLINK 0x02
221 #define NFSV3FSINFO_HOMOGENEOUS 0x08
222 #define NFSV3FSINFO_CANSETTIME 0x10
223
224 /* File types */
225 typedef enum { NFNON=0, NFREG=1, NFDIR=2, NFBLK=3, NFCHR=4, NFLNK=5,
226  NFSOCK=6, NFFIFO=7 } nfstype;
227
228 /* Structs for common parts of the rpc's */
229 /*
230  * File Handle (32 bytes for version 2), variable up to 64 for version 3.
231  * File Handles of up to NFS_SMALLFH in size are stored directly in the
232  * nfs node, whereas larger ones are malloc'd. (This never happens when
233  * NFS_SMALLFH is set to 64.)
234  * NFS_SMALLFH should be in the range of 32 to 64 and be divisible by 4.
235  */
236 #ifndef NFS_SMALLFH
237 #define NFS_SMALLFH 64
238 #endif
239 union nfsfh {
240  fhandle_t fh_generic;
241  u_char fh_bytes[NFS_SMALLFH];
242 };
243 typedef union nfsfh nfsfh_t;
244
245 struct nfsv2_time {
246  u_int32_t nfsv2_sec;
247  u_int32_t nfsv2_usec;
248 };
249 typedef struct nfsv2_time nfstime2;
250
251 struct nfsv3_time {
252  u_int32_t nfsv3_sec;
253  u_int32_t nfsv3_nsec;
254 };
255 typedef struct nfsv3_time nfstime3;
256
257 /*
258  * Quads are defined as arrays of 2 longs to ensure dense packing for the
259  * protocol and to facilitate xdr conversion.
260  */
261 struct nfs_uquad {
262  u_int32_t nfsuquad[2];
263 };
264 typedef struct nfs_uquad nfsuint64;
265
266 /*
267  * Used to convert between two u_longs and a u_quad_t.
268  */
269 union nfs_quadconvert {
270  u_int32_t lval[2];
271  u_quad_t qval;
272 };
273 typedef union nfs_quadconvert nfsquad_t;
274
275 /*
276  * NFS Version 3 special file number.
277  */
278 struct nfsv3_spec {
279  u_int32_t specdata1;
280  u_int32_t specdata2;
281 };
282 typedef struct nfsv3_spec nfsv3spec;
283
284 /*
285  * File attributes and setable attributes. These structures cover both
286  * NFS version 2 and the version 3 protocol. Note that the union is only
287  * used so that one pointer can refer to both variants. These structures
288  * go out on the wire and must be densely packed, so no quad data types
289  * are used. (all fields are longs or u_longs or structures of same)
290  * NB: You can't do sizeof(struct nfs_fattr), you must use the
291  * NFSX_FATTR(v3) macro.
292  */
293 struct nfs_fattr {
294  u_int32_t fa_type;
295  u_int32_t fa_mode;
296  u_int32_t fa_nlink;
297  u_int32_t fa_uid;
298  u_int32_t fa_gid;
299  union {
300  struct {
301  u_int32_t nfsv2fa_size;
302  u_int32_t nfsv2fa_blocksize;
303  u_int32_t nfsv2fa_rdev;
304  u_int32_t nfsv2fa_blocks;
305  u_int32_t nfsv2fa_fsid;
306  u_int32_t nfsv2fa_fileid;
307  nfstime2 nfsv2fa_atime;
308  nfstime2 nfsv2fa_mtime;
309  nfstime2 nfsv2fa_ctime;
310  } fa_nfsv2;
311  struct {
312  nfsuint64 nfsv3fa_size;
313  nfsuint64 nfsv3fa_used;
314  nfsv3spec nfsv3fa_rdev;
315  nfsuint64 nfsv3fa_fsid;
316  nfsuint64 nfsv3fa_fileid;
317  nfstime3 nfsv3fa_atime;
318  nfstime3 nfsv3fa_mtime;
319  nfstime3 nfsv3fa_ctime;
320  } fa_nfsv3;
321  } fa_un;
322 };
323
324 /* and some ugly defines for accessing union components */
325 #define fa2_size fa_un.fa_nfsv2.nfsv2fa_size
326 #define fa2_blocksize fa_un.fa_nfsv2.nfsv2fa_blocksize
327 #define fa2_rdev fa_un.fa_nfsv2.nfsv2fa_rdev
328 #define fa2_blocks fa_un.fa_nfsv2.nfsv2fa_blocks
329 #define fa2_fsid fa_un.fa_nfsv2.nfsv2fa_fsid
330 #define fa2_fileid fa_un.fa_nfsv2.nfsv2fa_fileid
331 #define fa2_atime fa_un.fa_nfsv2.nfsv2fa_atime
332 #define fa2_mtime fa_un.fa_nfsv2.nfsv2fa_mtime
333 #define fa2_ctime fa_un.fa_nfsv2.nfsv2fa_ctime
334 #define fa3_size fa_un.fa_nfsv3.nfsv3fa_size
335 #define fa3_used fa_un.fa_nfsv3.nfsv3fa_used
336 #define fa3_rdev fa_un.fa_nfsv3.nfsv3fa_rdev
337 #define fa3_fsid fa_un.fa_nfsv3.nfsv3fa_fsid
338 #define fa3_fileid fa_un.fa_nfsv3.nfsv3fa_fileid
339 #define fa3_atime fa_un.fa_nfsv3.nfsv3fa_atime
340 #define fa3_mtime fa_un.fa_nfsv3.nfsv3fa_mtime
341 #define fa3_ctime fa_un.fa_nfsv3.nfsv3fa_ctime
342
343 struct nfsv2_sattr {
344  u_int32_t sa_mode;
345  u_int32_t sa_uid;
346  u_int32_t sa_gid;
347  u_int32_t sa_size;
348  nfstime2 sa_atime;
349  nfstime2 sa_mtime;
350 };
351
352 /*
353  * NFS Version 3 sattr structure for the new node creation case.
354  */
355 struct nfsv3_sattr {
356  u_int32_t sa_modetrue;
357  u_int32_t sa_mode;
358  u_int32_t sa_uidfalse;
359  u_int32_t sa_gidfalse;
360  u_int32_t sa_sizefalse;
361  u_int32_t sa_atimetype;
362  nfstime3 sa_atime;
363  u_int32_t sa_mtimetype;
364  nfstime3 sa_mtime;
365 };
366
367 struct nfs_statfs {
368  union {
369  struct {
370  u_int32_t nfsv2sf_tsize;
371  u_int32_t nfsv2sf_bsize;
372  u_int32_t nfsv2sf_blocks;
373  u_int32_t nfsv2sf_bfree;
374  u_int32_t nfsv2sf_bavail;
375  } sf_nfsv2;
376  struct {
377  nfsuint64 nfsv3sf_tbytes;
378  nfsuint64 nfsv3sf_fbytes;
379  nfsuint64 nfsv3sf_abytes;
380  nfsuint64 nfsv3sf_tfiles;
381  nfsuint64 nfsv3sf_ffiles;
382  nfsuint64 nfsv3sf_afiles;
383  u_int32_t nfsv3sf_invarsec;
384  } sf_nfsv3;
385  } sf_un;
386 };
387
388 #define sf_tsize sf_un.sf_nfsv2.nfsv2sf_tsize
389 #define sf_bsize sf_un.sf_nfsv2.nfsv2sf_bsize
390 #define sf_blocks sf_un.sf_nfsv2.nfsv2sf_blocks
391 #define sf_bfree sf_un.sf_nfsv2.nfsv2sf_bfree
392 #define sf_bavail sf_un.sf_nfsv2.nfsv2sf_bavail
393 #define sf_tbytes sf_un.sf_nfsv3.nfsv3sf_tbytes
394 #define sf_fbytes sf_un.sf_nfsv3.nfsv3sf_fbytes
395 #define sf_abytes sf_un.sf_nfsv3.nfsv3sf_abytes
396 #define sf_tfiles sf_un.sf_nfsv3.nfsv3sf_tfiles
397 #define sf_ffiles sf_un.sf_nfsv3.nfsv3sf_ffiles
398 #define sf_afiles sf_un.sf_nfsv3.nfsv3sf_afiles
399 #define sf_invarsec sf_un.sf_nfsv3.nfsv3sf_invarsec
400
401 struct nfsv3_fsinfo {
402  u_int32_t fs_rtmax;
403  u_int32_t fs_rtpref;
404  u_int32_t fs_rtmult;
405  u_int32_t fs_wtmax;
406  u_int32_t fs_wtpref;
407  u_int32_t fs_wtmult;
408  u_int32_t fs_dtpref;
409  nfsuint64 fs_maxfilesize;
410  nfstime3 fs_timedelta;
411  u_int32_t fs_properties;
412 };
413
414 struct nfsv3_pathconf {
415  u_int32_t pc_linkmax;
416  u_int32_t pc_namemax;
417  u_int32_t pc_notrunc;
418  u_int32_t pc_chownrestricted;
419  u_int32_t pc_caseinsensitive;
420  u_int32_t pc_casepreserving;
421 };
422
423 #endif
Definition: nfsproto.h:279
Definition: nfsproto.h:344
Definition: nfsproto.h:252
Definition: nfsproto.h:415
Definition: nfsproto.h:246
Definition: nfsproto.h:240
Definition: nfsproto.h:368
Definition: mount.h:107
Definition: nfsproto.h:262
Definition: nfsproto.h:356
Definition: nfsproto.h:402
Definition: nfsproto.h:294
Definition: nfsproto.h:270
