nfsdiskless.h
1 /*
2  * Copyright (c) 1991, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * This code is derived from software contributed to Berkeley by
6  * Rick Macklem at The University of Guelph.
7  *
8  * Redistribution and use in source and binary forms, with or without
9  * modification, are permitted provided that the following conditions
10  * are met:
11  * 1. Redistributions of source code must retain the above copyright
12  * notice, this list of conditions and the following disclaimer.
13  * 2. Redistributions in binary form must reproduce the above copyright
14  * notice, this list of conditions and the following disclaimer in the
15  * documentation and/or other materials provided with the distribution.
16  * 4. Neither the name of the University nor the names of its contributors
17  * may be used to endorse or promote products derived from this software
18  * without specific prior written permission.
19  *
20  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
21  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
24  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
25  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
26  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
27  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
28  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
29  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
30  * SUCH DAMAGE.
31  *
32  * @(#)nfsdiskless.h 8.1 (Berkeley) 6/10/93
33  */
34
35 #ifndef _NFS_NFSDISKLESS_H_
36 #define _NFS_NFSDISKLESS_H_
37
38 #include <netinet/in.h> /* struct sockaddr_in */
39 #include <net/if.h>
40 #include <nfs/nfsproto.h> /* NFSX_V3FHMAX */
41 #include <nfsclient/nfsargs.h> /* struct nfs_args */
42
43 /*
44  * Structure that must be initialized for a diskless nfs client.
45  * This structure is used by nfs_mountroot() to set up the root and swap
46  * vnodes plus do a partial ifconfig(8) and route(8) so that the critical net
47  * interface can communicate with the server.
48  * The primary bootstrap is expected to fill in the appropriate fields before
49  * starting the kernel. Whether or not the swap area is nfs mounted is determined
50  * by the value in swdevt[0]. (equal to NODEV --> swap over nfs)
51  * Currently only works for AF_INET protocols.
52  * NB: All fields are stored in net byte order to avoid hassles with
53  * client/server byte ordering differences.
54  */
55
56 /*
57  * I have defined a new structure that can handle an NFS Version 3 file handle
58  * but the kernel still expects the old Version 2 one to be provided. The
59  * changes required in nfs_vfsops.c for using the new are documented there in
60  * comments. (I felt that breaking network booting code by changing this
61  * structure would not be prudent at this time, since almost all servers are
62  * still Version 2 anyhow.)
63  */
64 struct nfsv3_diskless {
65  struct ifaliasreq myif; /* Default interface */
66  struct sockaddr_in mygateway; /* Default gateway */
67  struct nfs_args swap_args; /* Mount args for swap file */
68  int swap_fhsize; /* Size of file handle */
69  u_char swap_fh[NFSX_V3FHMAX]; /* Swap file's file handle */
70  struct sockaddr_in swap_saddr; /* Address of swap server */
71  char swap_hostnam[MNAMELEN]; /* Host name for mount pt */
72  int swap_nblks; /* Size of server swap file */
73  struct ucred swap_ucred; /* Swap credentials */
74  struct nfs_args root_args; /* Mount args for root fs */
75  int root_fhsize; /* Size of root file handle */
76  u_char root_fh[NFSX_V3FHMAX]; /* File handle of root dir */
77  struct sockaddr_in root_saddr; /* Address of root server */
78  char root_hostnam[MNAMELEN]; /* Host name for mount pt */
79  long root_time; /* Timestamp of root fs */
80  char my_hostnam[MAXHOSTNAMELEN]; /* Client host name */
81 };
82
83 struct nfs_diskless {
84  struct ifaliasreq myif; /* Default interface */
85  struct sockaddr_in mygateway; /* Default gateway */
86  struct nfs_args swap_args; /* Mount args for swap file */
87  u_char swap_fh[NFSX_V2FH]; /* Swap file's file handle */
88  struct sockaddr_in swap_saddr; /* Address of swap server */
89  char swap_hostnam[MNAMELEN]; /* Host name for mount pt */
90  int swap_nblks; /* Size of server swap file */
91  struct ucred swap_ucred; /* Swap credentials */
92  struct nfs_args root_args; /* Mount args for root fs */
93  u_char root_fh[NFSX_V2FH]; /* File handle of root dir */
94  struct sockaddr_in root_saddr; /* Address of root server */
95  char root_hostnam[MNAMELEN]; /* Host name for mount pt */
96  long root_time; /* Timestamp of root fs */
97  char my_hostnam[MAXHOSTNAMELEN]; /* Client host name */
98 };
99
100 #endif
Definition: ucred.h:47
Definition: nfsdiskless.h:65
Definition: in.h:74
Definition: nfsdiskless.h:84
Definition: nfsargs.h:44
