score
cpu
moxie
score
moxie.h
1
5
6
* This file contains information pertaining to the Moxie processor.
7
8
* COPYRIGHT (c) 2011, 2013
9
* Anthony Green
10
11
* Based on code with the following copyright...
12
* COPYRIGHT (c) 1989-1999, 2010.
13
* On-Line Applications Research Corporation (OAR).
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
20
#ifndef _RTEMS_SCORE_MOXIE_H
21
#define _RTEMS_SCORE_MOXIE_H
22
23
#ifdef __cplusplus
24
extern
"C"
25
#endif
26
27
28
* This file contains the information required to build
29
* RTEMS for a particular member of the "moxie"
30
* family when executing in protected mode. It does
31
* this by setting variables to indicate which implementation
32
* dependent features are present in a particular member
33
* of the family.
34
35
36
#define CPU_NAME "Moxie"
37
#define CPU_MODEL_NAME "MoxieLite"
38
39
#ifdef __cplusplus
40
41
#endif
42
43
#endif
