mongoose.h
1 // Copyright (c) 2004-2012 Sergey Lyubka
2 //
3 // Permission is hereby granted, free of charge, to any person obtaining a copy
4 // of this software and associated documentation files (the "Software"), to deal
5 // in the Software without restriction, including without limitation the rights
6 // to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
7 // copies of the Software, and to permit persons to whom the Software is
8 // furnished to do so, subject to the following conditions:
9 //
10 // The above copyright notice and this permission notice shall be included in
11 // all copies or substantial portions of the Software.
12 //
13 // THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
14 // IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
15 // FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
16 // AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
17 // LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
18 // OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
19 // THE SOFTWARE.
20
21 #ifndef MONGOOSE_HEADER_INCLUDED
22 #define MONGOOSE_HEADER_INCLUDED
23
24 #include <stdio.h>
25 #include <stddef.h>
26
27 #ifdef __cplusplus
28 extern "C" {
29 #endif // __cplusplus
30
31 struct mg_context; // Handle for the HTTP service itself
32 struct mg_connection; // Handle for the individual connection
33
34
35 // This structure contains information about the HTTP request.
36 struct mg_request_info {
37  const char *request_method; // "GET", "POST", etc
38  const char *uri; // URL-decoded URI
39  const char *http_version; // E.g. "1.0", "1.1"
40  const char *query_string; // URL part after '?', not including '?', or NULL
41  const char *remote_user; // Authenticated user, or NULL if no auth used
42  long remote_ip; // Client's IP address
43  int remote_port; // Client's port
44  int is_ssl; // 1 if SSL-ed, 0 if not
45  void *user_data; // User data pointer passed to mg_start()
46  void *conn_data; // Connection-specific user data
47
48  int num_headers; // Number of HTTP headers
49  struct mg_header {
50  const char *name; // HTTP header name
51  const char *value; // HTTP header value
52  } http_headers[64]; // Maximum 64 headers
53 };
54
55
56 // This structure needs to be passed to mg_start(), to let mongoose know
57 // which callbacks to invoke. For detailed description, see
58 // https://github.com/valenok/mongoose/blob/master/UserManual.md
59 struct mg_callbacks {
60  // Called when mongoose has received new HTTP request.
61  // If callback returns non-zero,
62  // callback must process the request by sending valid HTTP headers and body,
63  // and mongoose will not do any further processing.
64  // If callback returns 0, mongoose processes the request itself. In this case,
65  // callback must not send any data to the client.
66  int (*begin_request)(struct mg_connection *);
67
68  // Called when mongoose has finished processing request.
69  void (*end_request)(const struct mg_connection *, int reply_status_code);
70
71  // Called when mongoose is about to log a message. If callback returns
72  // non-zero, mongoose does not log anything.
73  int (*log_message)(const struct mg_connection *, const char *message);
74
75  // Called when mongoose initializes SSL library.
76  int (*init_ssl)(void *ssl_context, void *user_data);
77
78  // Called when websocket request is received, before websocket handshake.
79  // If callback returns 0, mongoose proceeds with handshake, otherwise
80  // cinnection is closed immediately.
81  int (*websocket_connect)(const struct mg_connection *);
82
83  // Called when websocket handshake is successfully completed, and
84  // connection is ready for data exchange.
85  void (*websocket_ready)(struct mg_connection *);
86
87  // Called when data frame has been received from the client.
88  // Parameters:
89  // bits: first byte of the websocket frame, see websocket RFC at
90  // http://tools.ietf.org/html/rfc6455, section 5.2
91  // data, data_len: payload, with mask (if any) already applied.
92  // Return value:
93  // non-0: keep this websocket connection opened.
94  // 0: close this websocket connection.
95  int (*websocket_data)(struct mg_connection *, int bits,
96  char *data, size_t data_len);
97
98  // Called when mongoose tries to open a file. Used to intercept file open
99  // calls, and serve file data from memory instead.
100  // Parameters:
101  // path: Full path to the file to open.
102  // data_len: Placeholder for the file size, if file is served from memory.
103  // Return value:
104  // NULL: do not serve file from memory, proceed with normal file open.
105  // non-NULL: pointer to the file contents in memory. data_len must be
106  // initilized with the size of the memory block.
107  const char * (*open_file)(const struct mg_connection *,
108  const char *path, size_t *data_len);
109
110  // Called when mongoose is about to serve Lua server page (.lp file), if
111  // Lua support is enabled.
112  // Parameters:
113  // lua_context: "lua_State *" pointer.
114  void (*init_lua)(struct mg_connection *, void *lua_context);
115
116  // Called when mongoose has uploaded a file to a temporary directory as a
117  // result of mg_upload() call.
118  // Parameters:
119  // file_file: full path name to the uploaded file.
120  void (*upload)(struct mg_connection *, const char *file_name);
121
122  // Called when mongoose is about to send HTTP error to the client.
123  // Implementing this callback allows to create custom error pages.
124  // Parameters:
125  // status: HTTP error status code.
126  int (*http_error)(struct mg_connection *, int status);
127 };
128
129 // Start web server.
130 //
131 // Parameters:
132 // callbacks: mg_callbacks structure with user-defined callbacks.
133 // options: NULL terminated list of option_name, option_value pairs that
134 // specify Mongoose configuration parameters.
135 //
136 // Side-effects: on UNIX, ignores SIGCHLD and SIGPIPE signals. If custom
137 // processing is required for these, signal handlers must be set up
138 // after calling mg_start().
139 //
140 //
141 // Example:
142 // const char *options[] = {
143 // "document_root", "/var/www",
144 // "listening_ports", "80,443s",
145 // NULL
146 // };
147 // struct mg_context *ctx = mg_start(&my_func, NULL, options);
148 //
149 // Refer to https://github.com/valenok/mongoose/blob/master/UserManual.md
150 // for the list of valid option and their possible values.
151 //
152 // Return:
153 // web server context, or NULL on error.
154 struct mg_context *mg_start(const struct mg_callbacks *callbacks,
155  void *user_data,
156  const char **configuration_options);
157
158
159 // Stop the web server.
160 //
161 // Must be called last, when an application wants to stop the web server and
162 // release all associated resources. This function blocks until all Mongoose
163 // threads are stopped. Context pointer becomes invalid.
164 void mg_stop(struct mg_context *);
165
166
167 // Get the value of particular configuration parameter.
168 // The value returned is read-only. Mongoose does not allow changing
169 // configuration at run time.
170 // If given parameter name is not valid, NULL is returned. For valid
171 // names, return value is guaranteed to be non-NULL. If parameter is not
172 // set, zero-length string is returned.
173 const char *mg_get_option(const struct mg_context *ctx, const char *name);
174
175
176 // Return array of strings that represent valid configuration options.
177 // For each option, option name and default value is returned, i.e. the
178 // number of entries in the array equals to number_of_options x 2.
179 // Array is NULL terminated.
180 const char **mg_get_valid_option_names(void);
181
182
183 // Add, edit or delete the entry in the passwords file.
184 //
185 // This function allows an application to manipulate .htpasswd files on the
186 // fly by adding, deleting and changing user records. This is one of the
187 // several ways of implementing authentication on the server side. For another,
188 // cookie-based way please refer to the examples/chat.c in the source tree.
189 //
190 // If password is not NULL, entry is added (or modified if already exists).
191 // If password is NULL, entry is deleted.
192 //
193 // Return:
194 // 1 on success, 0 on error.
195 int mg_modify_passwords_file(const char *passwords_file_name,
196  const char *domain,
197  const char *user,
198  const char *password);
199
200
201 // Return information associated with the request.
202 struct mg_request_info *mg_get_request_info(struct mg_connection *);
203
204
205 // Send data to the client.
206 // Return:
207 // 0 when the connection has been closed
208 // -1 on error
209 // >0 number of bytes written on success
210 int mg_write(struct mg_connection *, const void *buf, size_t len);
211
212
213 // Send data to a websocket client wrapped in a websocket frame.
214 // It is unsafe to read/write to this connection from another thread.
215 // This function is available when mongoose is compiled with -DUSE_WEBSOCKET
216 //
217 // Return:
218 // 0 when the connection has been closed
219 // -1 on error
220 // >0 number of bytes written on success
221 int mg_websocket_write(struct mg_connection* conn, int opcode,
222  const char *data, size_t data_len);
223
224 // Opcodes, from http://tools.ietf.org/html/rfc6455
225 enum {
226  WEBSOCKET_OPCODE_CONTINUATION = 0x0,
227  WEBSOCKET_OPCODE_TEXT = 0x1,
228  WEBSOCKET_OPCODE_BINARY = 0x2,
229  WEBSOCKET_OPCODE_CONNECTION_CLOSE = 0x8,
230  WEBSOCKET_OPCODE_PING = 0x9,
231  WEBSOCKET_OPCODE_PONG = 0xa
232 };
233
234
235 // Macros for enabling compiler-specific checks for printf-like arguments.
236 #undef PRINTF_FORMAT_STRING
237 #if defined(_MSC_VER) && _MSC_VER >= 1400
238 #include <sal.h>
239 #if defined(_MSC_VER) && _MSC_VER > 1400
240 #define PRINTF_FORMAT_STRING(s) _Printf_format_string_ s
241 #else
242 #define PRINTF_FORMAT_STRING(s) __format_string s
243 #endif
244 #else
245 #define PRINTF_FORMAT_STRING(s) s
246 #endif
247
248 #ifdef __GNUC__
249 #define PRINTF_ARGS(x, y) __attribute__((format(printf, x, y)))
250 #else
251 #define PRINTF_ARGS(x, y)
252 #endif
253
254 // Send data to the client using printf() semantics.
255 //
256 // Works exactly like mg_write(), but allows to do message formatting.
257 int mg_printf(struct mg_connection *,
258  PRINTF_FORMAT_STRING(const char *fmt), ...) PRINTF_ARGS(2, 3);
259
260
261 // Send contents of the entire file together with HTTP headers.
262 void mg_send_file(struct mg_connection *conn, const char *path);
263
264
265 // Read data from the remote end, return number of bytes read.
266 // Return:
267 // 0 connection has been closed by peer. No more data could be read.
268 // < 0 read error. No more data could be read from the connection.
269 // > 0 number of bytes read into the buffer.
270 int mg_read(struct mg_connection *, void *buf, size_t len);
271
272
273 // Get the value of particular HTTP header.
274 //
275 // This is a helper function. It traverses request_info->http_headers array,
276 // and if the header is present in the array, returns its value. If it is
277 // not present, NULL is returned.
278 const char *mg_get_header(const struct mg_connection *, const char *name);
279
280
281 // Get a value of particular form variable.
282 //
283 // Parameters:
284 // data: pointer to form-uri-encoded buffer. This could be either POST data,
285 // or request_info.query_string.
286 // data_len: length of the encoded data.
287 // var_name: variable name to decode from the buffer
288 // dst: destination buffer for the decoded variable
289 // dst_len: length of the destination buffer
290 //
291 // Return:
292 // On success, length of the decoded variable.
293 // On error:
294 // -1 (variable not found).
295 // -2 (destination buffer is NULL, zero length or too small to hold the
296 // decoded variable).
297 //
298 // Destination buffer is guaranteed to be '\0' - terminated if it is not
299 // NULL or zero length.
300 int mg_get_var(const char *data, size_t data_len,
301  const char *var_name, char *dst, size_t dst_len);
302
303 // Fetch value of certain cookie variable into the destination buffer.
304 //
305 // Destination buffer is guaranteed to be '\0' - terminated. In case of
306 // failure, dst[0] == '\0'. Note that RFC allows many occurrences of the same
307 // parameter. This function returns only first occurrence.
308 //
309 // Return:
310 // On success, value length.
311 // On error:
312 // -1 (either "Cookie:" header is not present at all or the requested
313 // parameter is not found).
314 // -2 (destination buffer is NULL, zero length or too small to hold the
315 // value).
316 int mg_get_cookie(const char *cookie, const char *var_name,
317  char *buf, size_t buf_len);
318
319
320 // Download data from the remote web server.
321 // host: host name to connect to, e.g. "foo.com", or "10.12.40.1".
322 // port: port number, e.g. 80.
323 // use_ssl: wether to use SSL connection.
324 // error_buffer, error_buffer_size: error message placeholder.
325 // request_fmt,...: HTTP request.
326 // Return:
327 // On success, valid pointer to the new connection, suitable for mg_read().
328 // On error, NULL. error_buffer contains error message.
329 // Example:
330 // char ebuf[100];
331 // struct mg_connection *conn;
332 // conn = mg_download("google.com", 80, 0, ebuf, sizeof(ebuf),
333 // "%s", "GET / HTTP/1.0\r\nHost: google.com\r\n\r\n");
334 struct mg_connection *mg_download(const char *host, int port, int use_ssl,
335  char *error_buffer, size_t error_buffer_size,
336  PRINTF_FORMAT_STRING(const char *request_fmt),
337  ...) PRINTF_ARGS(6, 7);
338
339
340 // Close the connection opened by mg_download().
341 void mg_close_connection(struct mg_connection *conn);
342
343
344 // File upload functionality. Each uploaded file gets saved into a temporary
345 // file and MG_UPLOAD event is sent.
346 // Return number of uploaded files.
347 int mg_upload(struct mg_connection *conn, const char *destination_dir);
348
349
350 // Convenience function -- create detached thread.
351 // Return: 0 on success, non-0 on error.
352 typedef void * (*mg_thread_func_t)(void *);
353 int mg_start_thread(mg_thread_func_t f, void *p);
354
355
356 // Return builtin mime type for the given file name.
357 // For unrecognized extensions, "text/plain" is returned.
358 const char *mg_get_builtin_mime_type(const char *file_name);
359
360
361 // Return Mongoose version.
362 const char *mg_version(void);
363
364 // URL-decode input buffer into destination buffer.
365 // 0-terminate the destination buffer.
366 // form-url-encoded data differs from URI encoding in a way that it
367 // uses '+' as character for space, see RFC 1866 section 8.2.1
368 // http://ftp.ics.uci.edu/pub/ietf/html/rfc1866.txt
369 // Return: length of the decoded data, or -1 if dst buffer is too small.
370 int mg_url_decode(const char *src, int src_len, char *dst,
371  int dst_len, int is_form_url_encoded);
372
373 // MD5 hash given strings.
374 // Buffer 'buf' must be 33 bytes long. Varargs is a NULL terminated list of
375 // ASCIIz strings. When function returns, buf will contain human-readable
376 // MD5 hash. Example:
377 // char buf[33];
378 // mg_md5(buf, "aa", "bb", NULL);
379 char *mg_md5(char buf[33], ...);
380
381
382 #ifdef __cplusplus
383 }
384 #endif // __cplusplus
385
386 #endif // MONGOOSE_HEADER_INCLUDED
Definition: media-server.c:33
Definition: domain.h:45
Definition: mongoose.h:60
Definition: mongoose.h:37
Definition: mongoose.c:526
Definition: mongoose.c:505
Definition: mongoose.h:50
