#define | mode_t __mode_t |
#define | off_t __off_t |
#define | PROT_NONE 0x00 /* no permissions */ |
#define | PROT_READ 0x01 /* pages can be read */ |
#define | PROT_WRITE 0x02 /* pages can be written */ |
#define | PROT_EXEC 0x04 /* pages can be executed */ |
#define | MAP_SHARED 0x0001 /* share changes */ |
#define | MAP_PRIVATE 0x0002 /* changes are private */ |
#define | MAP_FIXED 0x0010 /* map addr must be exactly as requested */ |
#define | MAP_RENAME 0x0020 /* Sun: rename private pages to file */ |
#define | MAP_NORESERVE 0x0040 /* Sun: don't reserve needed swap area */ |
#define | MAP_INHERIT 0x0080 /* region is retained after exec */ |
#define | MAP_HASSEMAPHORE 0x0200 /* region may contain semaphores */ |
#define | MAP_TRYFIXED 0x0400 /* attempt hint address, even within break */ |
#define | MAP_WIRED 0x0800 /* mlock() mapping when it is established */ |
#define | MAP_FILE 0x0000 /* map from file (default) */ |
#define | MAP_ANON 0x1000 /* allocated from memory, swap space */ |
#define | MAP_ALIGNED(n) ((n) << MAP_ALIGNMENT_SHIFT) |
#define | MAP_ALIGNMENT_SHIFT 24 |
#define | MAP_ALIGNMENT_MASK MAP_ALIGNED(0xff) |
#define | MAP_ALIGNMENT_64KB MAP_ALIGNED(16) /* 2^16 */ |
#define | MAP_ALIGNMENT_16MB MAP_ALIGNED(24) /* 2^24 */ |
#define | MAP_ALIGNMENT_4GB MAP_ALIGNED(32) /* 2^32 */ |
#define | MAP_ALIGNMENT_1TB MAP_ALIGNED(40) /* 2^40 */ |
#define | MAP_ALIGNMENT_256TB MAP_ALIGNED(48) /* 2^48 */ |
#define | MAP_ALIGNMENT_64PB MAP_ALIGNED(56) /* 2^56 */ |
#define | MAP_FAILED ((void *) -1) /* mmap() failed */ |
#define | MS_ASYNC 0x01 /* perform asynchronous writes */ |
#define | MS_INVALIDATE 0x02 /* invalidate cached data */ |
#define | MS_SYNC 0x04 /* perform synchronous writes */ |
#define | MCL_CURRENT 0x01 /* lock all pages currently mapped */ |
#define | MCL_FUTURE 0x02 /* lock all pages mapped in the future */ |
__BEGIN_DECLS void * | mmap (void *, size_t, int, int, int, off_t) |
int | munmap (void *, size_t) |
int | mprotect (void *, size_t, int) |
int | msync (void *, size_t, int) __RENAME(__msync13) |
int | mlock (const void *, size_t) |
int | munlock (const void *, size_t) |
int | mlockall (int) |
int | munlockall (void) |
