asm.h
1
17 /*
18  * COPYRIGHT:
19  *
20  * This file is based on similar code found in newlib available
21  * from ftp.cygnus.com. The file which was used had no copyright
22  * notice. This file is freely distributable as long as the source
23  * of the file is noted. This file is:
24  *
25  * COPYRIGHT (c) 1994-1997.
26  * On-Line Applications Research Corporation (OAR).
27  */
28 /* @(#)asm.h 03/15/96 1.1 */
29
30 #ifndef _RTEMS_ASM_H
31 #define _RTEMS_ASM_H
32
33 /*
34  * Indicate we are in an assembly file and get the basic CPU definitions.
35  */
36
37 #ifndef ASM
38 #define ASM
39 #endif
40 #include <rtems/system.h>
41 #include <rtems/score/cpuopts.h>
42 #include <rtems/score/mips.h>
43
44 /*
45  * Recent versions of GNU cpp define variables which indicate the
46  * need for underscores and percents. If not using GNU cpp or
47  * the version does not support this, then you will obviously
48  * have to define these as appropriate.
49  */
50
51 #ifndef __USER_LABEL_PREFIX__
52 #define __USER_LABEL_PREFIX__ _
53 #endif
54
55 #ifndef __REGISTER_PREFIX__
56 #define __REGISTER_PREFIX__
57 #endif
58
59 #include <rtems/concat.h>
60
61 /* Use the right prefix for global labels. */
62
63 #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
64
65 /* Use the right prefix for registers. */
66
67 #define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
68
69 /*
70  * define macros for all of the registers on this CPU
71  *
72  * EXAMPLE: #define d0 REG (d0)
73  */
74
75 /*
76  * Define macros to handle section beginning and ends.
77  */
78
79
80 #define BEGIN_CODE_DCL .text
81 #define END_CODE_DCL
82 #define BEGIN_DATA_DCL .data
83 #define END_DATA_DCL
84 #define BEGIN_CODE .text
85 #define END_CODE
86 #define BEGIN_DATA
87 #define END_DATA
88 #define BEGIN_BSS
89 #define END_BSS
90 #define END
91
92 /*
93  * Following must be tailor for a particular flavor of the C compiler.
94  * They may need to put underscores in front of the symbols.
95  */
96
97 #define PUBLIC(sym) .globl SYM (sym)
98 #define EXTERN(sym) .globl SYM (sym)
99
100 /*
101  * Debugger macros for assembly language routines. Allows the
102  * programmer to set up the necessary stack frame info
103  * required by debuggers to do stack traces.
104  */
105
106 #ifndef XDS
107 #define FRAME(name,frm_reg,offset,ret_reg) \
108  .globl name; \
109  .ent name; \
110 name:; \
111  .frame frm_reg,offset,ret_reg
112 #define ENDFRAME(name) \
113  .end name
114 #else
115 #define FRAME(name,frm_reg,offset,ret_reg) \
116  .globl _##name;\
117 _##name:
118 #define ENDFRAME(name)
119 #endif /* XDS */
120
121 /*
122  * Hardware Floating Point Registers
123  */
124
125 #define R_FP0 0
126 #define R_FP1 1
127 #define R_FP2 2
128 #define R_FP3 3
129 #define R_FP4 4
130 #define R_FP5 5
131 #define R_FP6 6
132 #define R_FP7 7
133 #define R_FP8 8
134 #define R_FP9 9
135 #define R_FP10 10
136 #define R_FP11 11
137 #define R_FP12 12
138 #define R_FP13 13
139 #define R_FP14 14
140 #define R_FP15 15
141 #define R_FP16 16
142 #define R_FP17 17
143 #define R_FP18 18
144 #define R_FP19 19
145 #define R_FP20 20
146 #define R_FP21 21
147 #define R_FP22 22
148 #define R_FP23 23
149 #define R_FP24 24
150 #define R_FP25 25
151 #define R_FP26 26
152 #define R_FP27 27
153 #define R_FP28 28
154 #define R_FP29 29
155 #define R_FP30 30
156 #define R_FP31 31
157
158 #endif
159 /* end of include file */
160
This include file defines ANSI concatenation macros.
Information Included in Every Function in the Executive.
Information to build RTEMS for a "no cpu" while in protected mode.
